Doctor John <j.g### [at] gmailcom> wrote:
> If you intend to use this as an animation, don't
> forget to rotate the clouds (possibly at a slightly different rate to
> the earth).
And spin Earth west to east, note the "-" for that: rotate -360*clock
Unless there's another reason to have the atmosphere not show below Earth's
surface you won't need to use CSG difference, a single sphere alone will be
okay.
I think the answers given already have helped solve the problem.
Texture finish was trouble, as said, and scaling can be done other ways. I would
have began with a sphere {0,1 and then scaled them after image map and media.
Just be aware that media scaled after applied can change the affect,
historically anyway:
sphere {0,1 ... media { ... scale 0.5} scale 10}
Unfortunately I haven't kept up with that subject, I have not done much in
recent years, so please excuse me if media now retains original qualities when
scaling it's containing objects. Maybe it still scales (thickness or thinness).
On 7/20/2016 6:18 PM, clipka wrote:
> Am 20.07.2016 um 19:06 schrieb Stephen:
> OOoooh -- careful! This Code Monkey could accidently type a few lines of
> code that make POV-Ray crash specifically on /your/ computer. So stop
> talking, human, and hand over the bananas! ;)
Interesting that you say that.
When I was working at Taronga Zoo, in Sydney. The keepers in the Monkey
house used bananas as part of their alarm system. Every night they put a
banana beside a window. If in the morning the banana was gone. Then the
monkeys had gotten off of the inner enclosure.
>> Clouds are problematic especially in an animation. The simplest way
>> would be to use an image map.
> Tried that, and found it looking unconvincing. The best thing I've
> managed to come up with so far was a combination of an image map and a
> spherical function to create media with a cloud-ish density distribution.
> It would be cool if we had a set of cloud image maps epresenting cloud
> densities at different altitudes, but I guess such a thing doesn't exist
> (yet).
The big problem that I come up against is that All of these types of
animations are cyclic and our weather system does show the same behaviour.
Regards
> I'm now working hard on my assignment for my CG class at college, in which I'm
> trying to make a realistic earth animation.
> I used "difference" to create something like atmosphere right outside earth, and
> in which I also used emission for making the atmosphere glow. And this is where
> I'm facing a problem.
> When I set a light_source from a distance, there is no shadow cast on earth.
> Here I paste the source code:
> light_source {
> <100, 0, 50>
> color White
> spotlight
> fade_distance 100
> fade_power 10
> point_at <0, 0, 0>
Why use a spotlight?
Why use fading?
Given the distance from the Sun to the Earth, you are better using a
parallel light without any fading. Think about it, the Sun-Earth
distance is over 10000000 times the Earth's radius.
The difference in the illumination over the moon's orbit 's diameter is
effectively negligible.
fade_power ONLY realistic value is 2.
fade_sidtance should be about the appearent diameter of a light's diameter.
If the light becomes to dark, you can increase it's intensity
arbitrarily by as much as you need.
Try this one:
light_source{<100, 0, 50>*10 rgb 2 parallel}
> // earth
> sphere {
> <0, 0, 0>, 3.5
> texture {
> pigment {
> image_map {
> jpeg "textures/earth.jpg"
> map_type 1
> scale 3.5
This scalling is useless.
> finish {
> ambient 1
> diffuse 3
Beter use ambient 0, diffuse 0.6 here.
ambient 1 mean that your earth is actualy glowing.
diffuse 3 mean that it give off 3 times as much light as it receive from
the Sun.
> rotate y*-135
> rotate x*35
> // rotation
> rotate <0, 360*clock, 0>
> // atmosphere emission
> difference {
> sphere { <0, 0, 0>, 3.54 }
> sphere { <0, 0, 0>, 3.0 }
> material {
> texture{
> pigment { rgbt 1 }
> interior {
> media {
> emission 0.5
A GLOWING atmosphere? Last time I checked, Earth's atmosphere scatters
the light and don't emit any.
> //scattering { 5 color rgb 0.01 eccentricity 0.56 }
The proper model is scattering{4 rgb 0.01}
> density {
> spherical density_map {
> [ 0.0 rgb 0.0 ]
> [ 0.5294*0.25e-6 rgb <0.02, 0.05, 0.2>*0.07 ]
> [ 0.5294*0.4e-6 rgb <0.02, 0.07, 0.3>*0.32 ]
> [ 0.5294*0.5e-6 rgb <0.08, 0.18, 0.4>*0.5 ]
> [ 0.5412*0.6e-6 rgb <0.08, 0.18, 0.4>*0.9 ]
> [ 0.5471*0.65e-6 rgb <0.08, 0.18, 0.4>*1.5 ]
> [ 0.5471*0.675e-6 rgb <0.08, 0.18, 0.4>*4.5 ]
> [ 0.5471*0.71e-6 rgb <0.08, 0.18, 0.4>*12 ]
> scale 100
> hollow on
> And below I attach the rendered result for now.
> How can I solve this problem? I'd appreciate it if someone could help.
> I'm not a native English speaker, so I'm very sorry for my poor English... I
> really wish I didn't use impolite expressions!
> Thanks.
