![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm now working hard on my assignment for my CG class at college, in which I'm
trying to make a realistic earth animation.
I used "difference" to create something like atmosphere right outside earth, and
in which I also used emission for making the atmosphere glow. And this is where
I'm facing a problem.
When I set a light_source from a distance, there is no shadow cast on earth.
Here I paste the source code:
light_source {
<100, 0, 50>
color White
spotlight
fade_distance 100
fade_power 10
point_at <0, 0, 0>
// earth
sphere {
<0, 0, 0>, 3.5
image_map {
jpeg "textures/earth.jpg"
map_type 1
scale 3.5
finish {
ambient 1
diffuse 3
rotate y*-135
rotate x*35
// rotation
rotate <0, 360*clock, 0>
// atmosphere emission
difference {
sphere { <0, 0, 0>, 3.54 }
sphere { <0, 0, 0>, 3.0 }
material {
texture{
pigment { rgbt 1 }
interior {
media {
emission 0.5
//scattering { 5 color rgb 0.01 eccentricity 0.56 }
density {
spherical density_map {
[ 0.0 rgb 0.0 ]
[ 0.5294*0.25e-6 rgb <0.02, 0.05, 0.2>*0.07 ]
[ 0.5294*0.4e-6 rgb <0.02, 0.07, 0.3>*0.32 ]
[ 0.5294*0.5e-6 rgb <0.08, 0.18, 0.4>*0.5 ]
[ 0.5412*0.6e-6 rgb <0.08, 0.18, 0.4>*0.9 ]
[ 0.5471*0.65e-6 rgb <0.08, 0.18, 0.4>*1.5 ]
[ 0.5471*0.675e-6 rgb <0.08, 0.18, 0.4>*4.5 ]
[ 0.5471*0.71e-6 rgb <0.08, 0.18, 0.4>*12 ]
scale 100
hollow on
And below I attach the rendered result for now.
How can I solve this problem? I'd appreciate it if someone could help.
I'm not a native English speaker, so I'm very sorry for my poor English... I
really wish I didn't use impolite expressions!
Thanks.
Download 'earth.png' (584 KB)
Preview of image 'earth.png'
![earth.png](/povray.binaries.images/attachment/%3Cweb.578f8f9966cab3a2e6aba5420%40news.povray.org%3E/earth.png?ttop=443824&toff=1050&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If your atmosphere is emissive - where would the shadow come from?
You've essentially made a hollow spherical light source surrounding your earth.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 20.07.2016 um 16:50 schrieb Kuangy:
Since there is no object to cast any shadows in the scene, I presume
you're referring to the darkening of the night side.
> light_source {
> <100, 0, 50>
> color White
> spotlight
> fade_distance 100
> fade_power 10
> point_at <0, 0, 0>
- Why a spotlight? Also, if you must use a spotlight, you probably want
to override the default settings for the `radius` and `falloff` parameters.
- `fade_power 10` is hopelessly unrealistic; use 2 instead.
- `fade_distance 100` is unrealistic; use the hypothetical radius of the
sun for this parameter instead, and increase the light source's nominal
brightness to counteract the resulting reduction in effective brightness
(using e.g. `color White * 100`).
> // earth
> sphere {
> <0, 0, 0>, 3.5
> texture {
> pigment {
> image_map {
> map_type 1
> scale 3.5
- No need to scale map_type 1 pigments -- in POV-Ray, image maps work
kind of like a projector, extending the pattern into 3D space to
infinity. With map_type 1 being a projection from the coordinate origin,
it is therefore invariant to scaling.
> finish {
> ambient 1
> diffuse 3
- Presuming you're using POV-Ray 3.7, don't use `ambient`; use
`emission` instead.
- Actually, don't use `emission` -- you don't want the earth's surface
to glow, you want it to (diffusely) reflect sunlight.
- `diffuse 3` is hopelessly unrealistic. Presuming your image map uses
realistic brightness levels, anything above `diffuse 1` is physical
nonsense. Use `diffuse 1` if your texture only has a diffuse component;
otherwise (e.g. if you also add highlights and specular reflection for
any reason) use a value below 1.
> interior {
> media {
> emission 0.5
- Don't use `emission` -- you don't actually want the earth to glow, you
want it to scatter sunlight, so use `scattering`.
> density {
> [ 0.0 rgb 0.0 ]
> scale 100
- I suspect that scaling factor could be wrong. Hard to tell though with
the comparatively complicated values in the density map.
Your problem is most likely that your earth glows by itself, while your
sun's effective brightness at the given distance is too low to make any
significant difference.
Doesn't sound poor at all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
[Snip]
Welcome and your English is fine.
You want to use scattering for your atmosphere.
Besides using an image map. You can add a normal map to give some depth
and a spectacular map for the seas. You can find some here
http://planetpixelemporium.com/earth.html
The atmosphere is always tricky to do and I generally cheat and use a
cone behind the planet in line with the camera.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 20.07.2016 um 18:02 schrieb Stephen:
You mean specular, right? ;)
I find atmosphere comparatively easy -- as long as I don't try to add
clouds.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Who rattled your cage? :P
Yes you do, don't you. :(
> clouds.
Clouds are problematic especially in an animation. The simplest way
would be to use an image map.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mr. clipka,
Thank you for your detailed and useful advice.
Here's the new code I rewrote:
// sunlight
light_source {
<100, 0, 40>
color White*100
parallel
fade_distance 10
fade_power 2
point_at <0, 0, 0>
// Earth
sphere {
<0, 0, 0>, 3.5
image_map {
map_type 1
finish {
emission 0.001
diffuse 0.5
rotate y*-135
rotate x*35
// rotation
// Earth clouds
difference {
sphere { <0, 0, 0>, 3.51 }
sphere { <0, 0, 0>, 3.5 }
material {
image_map{
png "textures/earth_cloud.png"
map_type 1
hollow on
// Earth scattering
difference {
material {
texture{
pigment { rgbt 1 }
interior {
media {
scattering {
5
color White
eccentricity 0.56
density {
[ 0.0 rgb 0.0 ]
scale 3.54
hollow on
And here I attach the brand new rendered image, with clouds added on the
surface.
Thank you very much for your advice.
Download 'earth.png' (663 KB)
![earth.png](/povray.binaries.images/attachment/%3Cweb.578fb05180911a1ee6aba5420%40news.povray.org%3E/earth.png?ttop=443824&toff=1050&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 20.07.2016 um 19:06 schrieb Stephen:
OOoooh -- careful! This Code Monkey could accidently type a few lines of
code that make POV-Ray crash specifically on /your/ computer. So stop
talking, human, and hand over the bananas! ;)
>> clouds.
Tried that, and found it looking unconvincing. The best thing I've
managed to come up with so far was a combination of an image map and a
spherical function to create media with a cloud-ish density distribution.
It would be cool if we had a set of cloud image maps epresenting cloud
densities at different altitudes, but I guess such a thing doesn't exist
(yet).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 20/07/16 18:09, Kuangy wrote:
> Mr. clipka,
<snip>
> surface.
Looking good, Kuangy. If you intend to use this as an animation, don't
forget to rotate the clouds (possibly at a slightly different rate to
the earth).
John
It's not about bravery.
It's about doing what I need to do to win
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 20.07.2016 um 19:09 schrieb Kuangy:
> surface.
Hey, wow -- that actually looks really good.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
