POV-Ray : Newsgroups : povray.binaries.images : BlendPov-alternative: screenshots Server Time
16 Mar 2026 11:31:59 EDT (-0400)
  BlendPov-alternative: screenshots (Message 39 to 48 of 58)
Subject: Re: BlendPov-alternative: screenshots
Date: 8 May 2016 12:55:01
Message: <web.572f6eeba4dc7df27a3e03fe0@news.povray.org>
Round Boxes with Array-modifiers:
Brick walls:
8 second render.
Download 'brick_roundbox.blend.jpg' (390 KB)
Preview of image 'brick_roundbox.blend.jpg'
Date: 12 Aug 2016 11:30:01
Message: <web.57adeb3ba4dc7df27a3e03fe0@news.povray.org>
Texture testing needed.
#declare Finish_Material = finish {
    emission 0
    reflection {
    <1,1,1>
    exponent 1
    falloff 0
    metallic 1    }
#declare Finish_001_Material = finish {
    emission 0.1067
#declare Color_002_Material = pigment{color srgbft <1,1,1,0,1>}
#declare Color_Material = pigment{color srgbft <1,0.1842,0.007459,1,0>}
#declare Color_001_Material = pigment{color srgbft <0.905,1,0.9572,0,0>}
#declare Simple_texture_Material = texture{
    pigment{Color_Material}
#declare Simple_texture_001_Material = texture{
    pigment{Color_001_Material}
    finish{Finish_Material}
#declare Simple_texture_003_Material = texture{
    pigment{Color_002_Material}
#declare Simple_texture_002_Material = texture{
    pigment{color rgb <0.02484,0.01929,0.2569>}
    finish{Finish_001_Material}
#declare Texture_map_002_Material = texture {
    onion
    texture_map {
    #declare ColorRamp_0_Material = texture{pigment{color srgbt
<0.02627,0.007679,0.2254,0>}};
    [0.0 ColorRamp_0_Material]
    #declare ColorRamp_1_Material = texture{pigment{color srgbt
<0.125,0.00651,0.00321,0>}};
    [0.125 ColorRamp_1_Material]
    [0.3857615292072296 Simple_texture_002_Material]
    [0.8940397500991821 Simple_texture_003_Material]
    [1.0 Simple_texture_003_Material]
#declare Texture_map_001_Material = texture {
    wrinkles
    texture_map {
    [0 Simple_texture_Material]
    [1 Simple_texture_001_Material]
#declare Texture_map_Material = texture {
    granite
    texture_map {
    [0 Texture_map_002_Material]
    [1 Texture_map_001_Material]
Download 'textest.jpg' (327 KB)
Preview of image 'textest.jpg'
Date: 13 Aug 2016 02:40:00
Message: <web.57aec011a4dc7df27a3e03fe0@news.povray.org>
Render result: Povray-3.7.0
Download 'for_comparison.jpg' (80 KB)
Preview of image 'for_comparison.jpg'
Date: 24 Aug 2016 15:40:01
Message: <web.57bdf705a4dc7df27a3e03fe0@news.povray.org>
There was nothing
Download 'abstract.jpg' (256 KB)
Preview of image 'abstract.jpg'
Date: 26 Aug 2016 17:10:01
Message: <web.57c0af90a4dc7df27a3e03fe0@news.povray.org>
to clipka.
I used black and white lines image with UV.
I can get the coordinates of each particle.
I can paint any picture...
Download 'part.jpg' (416 KB)
Preview of image 'part.jpg'
Date: 3 Sep 2016 11:25:01
Message: <web.57caea7fa4dc7df27a3e03fe0@news.povray.org>
I discovered a new planet!
I misunderstood clipka, sorry!
He developed his idea.
Creating terrain using particle system with texture clouds as height_map.
Convert to mesh and write as blob
Download 'modelling_terrain.jpg' (387 KB)
Preview of image 'modelling_terrain.jpg'
Date: 3 Sep 2016 12:26:14
Message: <57caf9a6$1@news.povray.org>
Am 03.09.2016 um 17:21 schrieb LanuHum:
Mistakes are the root of creativity.
Have fun!
Date: 3 Sep 2016 13:25:01
Message: <web.57cb06d0a4dc7df27a3e03fe0@news.povray.org>
> Have fun!
Date: 4 Sep 2016 11:00:01
Message: <web.57cc367ca4dc7df27a3e03fe0@news.povray.org>
Below I used hgpovray with tessellation bourke object previous scene.
At the top I again write object as blob.
Download 'bourke.jpg' (458 KB)
Preview of image 'bourke.jpg'
Date: 4 Sep 2016 11:14:40
Message: <57cc3a60$1@news.povray.org>
A higher horizontal resolution might helps a bit (vertical one is ok)
(increase the accuracy for the two horizontal vector)
You might also enjoy some "precision" (such as "precision 16", number of extra sample
along a segment along which one vertex is in and the other is out)
