Did I mess up these two images?
https://www.flickr.com/photos/108839565@N04/25050132394/in/dateposted-public/
https://www.flickr.com/photos/108839565@N04/25654484906/in/dateposted-public/
I've been using StereoPhoto Maker with default settings and the images
are mainly just giving me a headache instead of appearing 3D.
Mike
> Mike
It looks like your offset is to strong.
I use about 25-30 to 1.
25 units from camera to object, 1 unit camera offset between pictures.
Stephen S
>> Mike
> Stephen S
How do you set the offset to xx? I can use the adjust and auto adjust
but cannot see a setting for it.
Regards
In the program used to generate the two pictures (Povray), offset the
camera 25 to 1 between pictures.
For all my anaglyphs I also move the camera_look_at by the same amount.
Stephen S
> Stephen S
I still don't understand. Do you mean I should separate the cameras by 1
unit for every 25 units of distance from the target?
I actually separate the cameras by a fixed angle (5 degrees), with the
target as the center point, instead of a linear distance. What angle
would a 25:1 ratio be?
// Camera
#ifndef (LDXSkipCamera)
#declare camera_eye = 1; // -1 = no eye, 0 = left eye, 1 = right eye
#declare LDXCamAspect = image_width/image_height;
location LDXCameraLoc
sky LDXCameraSky
right LDXCamAspect * < -1,0,0 >
look_at LDXCameraLookAt
angle 57.822403
#switch (camera_eye)
#case (0)
#include "transforms.inc"
translate -LDXCameraLookAt
Axis_Rotate_Trans(y, +5/2)
translate +LDXCameraLookAt
#break
#case (1)
Axis_Rotate_Trans(y, -5/2)
#break
Mike
Yes
The pictures reminds me of to much offset (10 to 1?).
Although there maybe other ways to get this effect.
You are using converging lines, fixed look_at.
I use parallel lines for my work, same viewing plane.
A different 'rule of thumb' may be needed.
I'm happy with my 3d effect, although not always with the subject matter ;-)
Stephen S
You have a strong separation between the two color channels.
Even more pronounced because of the strong black color of the wings.
A little 3d can go along way.
The following pictures with the same first frame, have:
camera at -25y and look_at <0,0,0>
.5 units x second frame
1 unit x
2 units x
For me the first picture looks nice (50 to 1)
Second OK (25 to 1)
Third (12.5 to 1) starting to get strong, making my brain work hard ;-)
Stephen S
Download 'anaglyph_test_scene_50to1_parallel.png' (192 KB)
Download 'anaglyph_test_scene_25to1_parallel.png' (210 KB)
Download 'anaglyph_test_scene_12p5to1_parallel.png' (199 KB)
Preview of image 'anaglyph_test_scene_50to1_parallel.png'
Preview of image 'anaglyph_test_scene_25to1_parallel.png'
Preview of image 'anaglyph_test_scene_12p5to1_parallel.png'
> Stephen S
That is a Duh! on my part. I was thinking about the alignment of the
left and right images in the final image.
Regards
and with same look_at (converging lines).
The third one looks like the problem with ldr_small_shuttle.
Stephen S
Download 'anaglyph_test_scene_50to1_converge.png' (197 KB)
Download 'anaglyph_test_scene_25to1_converge.png' (202 KB)
Download 'anaglyph_test_scene_12p5to1_converge.png' (205 KB)
Preview of image 'anaglyph_test_scene_50to1_converge.png'
Preview of image 'anaglyph_test_scene_25to1_converge.png'
Preview of image 'anaglyph_test_scene_12p5to1_converge.png'
> Stephen S
What's weird is that the stereo renders look fine using my stereoscope,
with the same POV-Ray settings.
Mike
