POV-Ray : Newsgroups : povray.binaries.images : Parametric problem: image Server Time
19 Nov 2025 07:01:17 EST (-0500)
  Parametric problem: image (Message 1 to 10 of 13)
Subject: Parametric problem: image
Date: 22 Aug 2015 12:50:00
Message: <web.55d8a721943387b7a3e03fe0@news.povray.org>
http://news.povray.org/povray.general/message/%3Cweb.55d76b3d49d08eec7a3e03fe0%40news.povray.org%3E/#%3Cweb.55d76b3d49d
Download 'parametric.jpg' (243 KB)
Preview of image 'parametric.jpg'
Subject: Re: Parametric problem: image
Date: 22 Aug 2015 16:00:00
Message: <web.55d8d2c1f3deb2877a3e03fe0@news.povray.org>
9d
I waited for the end of a render (It is the notice!!! No material, no photons,
no radio, all - no):
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       1 hours 15 minutes 30 seconds (4530.792 seconds)
              using 4 thread(s) with 16423.073 CPU-seconds total
POV-Ray finished
Truth! It is the finish!
#version 3.7;
#include "functions.inc"
global_settings {
    assumed_gamma 1.000000
sky_sphere {
    pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare data_Parametric_shape_ob = parametric {
    function { cos(v)*(1+cos(u))*sin(v/8) }
    function { sin(u)*sin(v/8)+cos(v/8)*1.5 }
    function { sin(v)*(1+cos(u))*sin(v/8) }
    <0.0000,0.0000>, <6.2800,12.5700>
    contained_by { box{-1, 1} }
    max_gradient 5.000000
    accuracy 0.001000
    precompute 10 x,y,z
object {data_Parametric_shape_ob
    texture {Default_texture}
    matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.000000,
0.000000, 1.000000, -0.000000,  0.000000, 0.000000, 0.000000>
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_distance 25.0000000000
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
Download 'parametric_final.jpg' (138 KB)
Preview of image 'parametric_final.jpg'
Date: 22 Aug 2015 16:26:11
Message: <55d8dae3$1@news.povray.org>
Have you tried increasing the contained_by?
Regards
Date: 22 Aug 2015 17:15:04
Message: <web.55d8e5e3f3deb2877a3e03fe0@news.povray.org>
> Regards
>      Stephen
No!
I don't know an origin of these parameters.
I only try to connect the Blender with Povray.
Therefore I ask for help.
Thanks!
The increase in contained_by normalizes a situation.
Let the user choose.
I wouldn't begin to use objects of parametric in the scenes because of very long
time of a render.
Developers advance the ideas.
Sometimes these ideas incorrect, but I can't interfere
http://www.youtube.com/watch?v=nVO1zDQc5LU
Date: 23 Aug 2015 00:08:36
Message: <55d94744$1@news.povray.org>
>> Regards
>>       Stephen
> No!
> Thanks!
You might want to try min_extent and max_extent to define the
contained_by box (can also be a sphere)
Help 3.3.1.6.5 Functions
min_extent(OBJECT_IDENTIFIER), max_extent(OBJECT_IDENTIFIER). The
min_extent and max_extent return the minimum and maximum coordinates of
a #declared object's bounding box (Corner1 and Corner2), in effect
allowing you to find the dimensions and location of the object.
Note: This is not perfect, in some cases (such as CSG intersections and
differences or isosurfaces) the bounding box does not represent the
actual dimensions of the object.
> time of a render.
Me too :)
True ;-)
I do not understand why you show this
Unless it is an example of this:
Regards
Date: 23 Aug 2015 00:39:51
Message: <55d94e97$1@news.povray.org>
Am 23.08.2015 um 06:08 schrieb Stephen:
>>> Regards
>>>       Stephen
>> No!
>> Thanks!
Unfortunately that won't help with this issue, as min_extent and
max_extent give you the extent of the object's bounding box (rather than
the object itself), which in case of parametrics is in turn simply based
on the contained_by object.
One possible solution would be to evaluate some sample points from the
function set (possibly using an adaptive algorithm), and create the
contained_by box based on the range of the results (with some additional
margin).
Date: 23 Aug 2015 00:53:39
Message: <op.x3s07m0xufxv4h@xena>
I'm not sure if Pov-Ray converts a Parametric to a mesh for rendering. If
it does, then maybe it would be faster if you use the Blender mesh rather
than the Pov-Ray paramtric.
Another reason for the slow speed might be that the camera is placed in a
position that results in too many computations - it almost looks like the
camera is inside the shell or intersecting with the edge of the shell.
-Nekar Xenos-
Date: 23 Aug 2015 01:50:00
Message: <web.55d95efbf3deb2877a3e03fe0@news.povray.org>
> >> Regards
> >>       Stephen
> > No!
> > Thanks!
> > time of a render.
> Me too :)
> True ;-)
> Regards
>      Stephen
Thanks! Yes, you correct understand :)
> >>> Regards
> >>>       Stephen
> >> No!
> >> Thanks!
> margin).
Thanks!
> -Nekar Xenos-
I test all objects at one position of the camera. If the sphere is rendered
quickly, I can't tell that it is rendered slowly.
But, my opinion is only my opinion. Let users decide that such quickly and that
such slowly. I can't use a renderer of Cycles, because very slowly. Others use
and rejoice, are happy.
Also, I give transformations to a renderer not to spend time for writing of the
file.
But, if to convert all objects in mesh, to the Blender it will be heavy
Date: 23 Aug 2015 02:50:02
Message: <web.55d96c08f3deb2877a3e03fe0@news.povray.org>
> -Nekar Xenos-
Certainly, the mesh is rendered very quickly.
On formulas the Blender creates mesh 1 second.
+ click on modifiers button, select modifier and press smooth button.
That with these formulas does Povray taking away more than an hour I don't even
assume. :)
Download 'parametric_to_mesh.jpg' (278 KB)
Preview of image 'parametric_to_mesh.jpg'
Date: 23 Aug 2015 06:29:52
Message: <55d9a0a0@news.povray.org>
Interesting
> margin).
This makes me think that Nekar's idea of creating a mesh is a starting
point.
If LanuHum could create and export a mesh of the object (declared but
not called). PovRay could evaluate its bounding box and use those values
as the parametrics contained by.
Regards
