POV-Ray : Newsgroups : povray.binaries.images : Parametric problem: image Server Time
1 Jul 2024 00:11:48 EDT (-0400)
  Parametric problem: image (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Parametric problem: image
Date: 22 Aug 2015 17:15:04
Message: <web.55d8e5e3f3deb2877a3e03fe0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> On 8/22/2015 8:55 PM, LanuHum wrote:
> >      contained_by { box{-1, 1} }
> Have you tried increasing the contained_by?
> Regards
>      Stephen
No!
I don't know an origin of these parameters.
I only try to connect the Blender with Povray.
Therefore I ask for help.
Thanks!
The increase in contained_by normalizes a situation.
Let the user choose.
I wouldn't begin to use objects of parametric in the scenes because of very long
time of a render.
Developers advance the ideas.
Sometimes these ideas incorrect, but I can't interfere
http://www.youtube.com/watch?v=nVO1zDQc5LU
Date: 23 Aug 2015 00:08:36
Message: <55d94744$1@news.povray.org>
>> Regards
>>       Stephen
> No!
> Thanks!
You might want to try min_extent and max_extent to define the
contained_by box (can also be a sphere)
Help 3.3.1.6.5 Functions
min_extent(OBJECT_IDENTIFIER), max_extent(OBJECT_IDENTIFIER). The
min_extent and max_extent return the minimum and maximum coordinates of
a #declared object's bounding box (Corner1 and Corner2), in effect
allowing you to find the dimensions and location of the object.
Note: This is not perfect, in some cases (such as CSG intersections and
differences or isosurfaces) the bounding box does not represent the
actual dimensions of the object.
> time of a render.
Me too :)
True ;-)
I do not understand why you show this
Unless it is an example of this:
Regards
Date: 23 Aug 2015 00:39:51
Message: <55d94e97$1@news.povray.org>
Am 23.08.2015 um 06:08 schrieb Stephen:
>>> Regards
>>>       Stephen
>> No!
>> Thanks!
Unfortunately that won't help with this issue, as min_extent and
max_extent give you the extent of the object's bounding box (rather than
the object itself), which in case of parametrics is in turn simply based
on the contained_by object.
One possible solution would be to evaluate some sample points from the
function set (possibly using an adaptive algorithm), and create the
contained_by box based on the range of the results (with some additional
margin).
Date: 23 Aug 2015 00:53:39
Message: <op.x3s07m0xufxv4h@xena>
I'm not sure if Pov-Ray converts a Parametric to a mesh for rendering. If
it does, then maybe it would be faster if you use the Blender mesh rather
than the Pov-Ray paramtric.
Another reason for the slow speed might be that the camera is placed in a
position that results in too many computations - it almost looks like the
camera is inside the shell or intersecting with the edge of the shell.
-Nekar Xenos-
Date: 23 Aug 2015 01:50:00
Message: <web.55d95efbf3deb2877a3e03fe0@news.povray.org>
> >> Regards
> >>       Stephen
> > No!
> > Thanks!
> > time of a render.
> Me too :)
> True ;-)
> Regards
>      Stephen
Thanks! Yes, you correct understand :)
> >>> Regards
> >>>       Stephen
> >> No!
> >> Thanks!
> margin).
Thanks!
> -Nekar Xenos-
I test all objects at one position of the camera. If the sphere is rendered
quickly, I can't tell that it is rendered slowly.
But, my opinion is only my opinion. Let users decide that such quickly and that
such slowly. I can't use a renderer of Cycles, because very slowly. Others use
and rejoice, are happy.
Also, I give transformations to a renderer not to spend time for writing of the
file.
But, if to convert all objects in mesh, to the Blender it will be heavy
Date: 23 Aug 2015 02:50:02
Message: <web.55d96c08f3deb2877a3e03fe0@news.povray.org>
> -Nekar Xenos-
Certainly, the mesh is rendered very quickly.
On formulas the Blender creates mesh 1 second.
+ click on modifiers button, select modifier and press smooth button.
That with these formulas does Povray taking away more than an hour I don't even
assume. :)
Download 'parametric_to_mesh.jpg' (278 KB)
Preview of image 'parametric_to_mesh.jpg'
Date: 23 Aug 2015 06:29:52
Message: <55d9a0a0@news.povray.org>
Interesting
> margin).
This makes me think that Nekar's idea of creating a mesh is a starting
point.
If LanuHum could create and export a mesh of the object (declared but
not called). PovRay could evaluate its bounding box and use those values
as the parametrics contained by.
Regards
Date: 23 Aug 2015 09:15:01
Message: <web.55d9c668f3deb2877a3e03fe0@news.povray.org>
> Interesting
> > margin).
> point.
> Regards
>      Stephen
This object was created by the Blender tool. If to use meshmaker, it is
necessary to specify the amount of bound boxing
Date: 23 Aug 2015 10:00:01
Message: <web.55d9d17df3deb2877a3e03fe0@news.povray.org>
I wrote nonsense. :)
Consider it a joke! :)
Date: 23 Aug 2015 10:37:42
Message: <55d9dab6$1@news.povray.org>
Brother! :)
Done ;)
Regards
