POV-Ray : Newsgroups : povray.binaries.images : A Planetary Journey Server Time
19 Nov 2025 07:01:16 EST (-0500)
  A Planetary Journey (Message 1 to 10 of 23)
Subject: A Planetary Journey
Date: 9 Aug 2015 13:10:01
Message: <web.55c7887f1d940348a45e3d720@news.povray.org>
Playing around with media to model a sunrise I came up with the following image
finally.
And yes, there are people trying to walk a rope between hot air balloons. They
rely on their parachutes.
For the balloons I took an IRTC-Entry by Neil Alexander as starting point.
Image_maps of Earth and Mars are from NASA of course.
Enjoy and best regards,
Michael
Download 'planetary journey_20150809_1280.png' (445 KB)
Preview of image 'planetary journey_20150809_1280.png'
Subject: Re: A Planetary Journey
Date: 9 Aug 2015 13:20:01
Message: <web.55c78b5752ac8b067a3e03fe0@news.povray.org>
> finally.
> Michael
Beauty!!! Sun! Very Beauty!!!
Date: 9 Aug 2015 13:26:05
Message: <55c78d2d$1@news.povray.org>
Am 09.08.2015 um 19:06 schrieb MichaelJF:
> finally.
The media, trees and far-off balloons look gorgeous!
I think the tightrope walker is a bit too large; maybe 70% of its size
should be a better fit.
I'm not so happy with the Earth, Mars, red-white striped, and
yellow-orange banded balloons; they look as if they didn't receive any
sunlight, while instead glowing on their surface.
If this is supposed to be glow from the propane burners, it should be
(1) darker, (2) more coloured, and (3) be more intense near the bottom
of each balloon. One way to achieve this might be to place light sources
at the propane burner locations with proper distance-based falloff, and
use arse... um, I mean, backside illumination on the balloon skins
("diffuse X,Y" or, better yet, "diffuse albedo X,Y", where X+Y < 1).
Date: 9 Aug 2015 14:25:00
Message: <web.55c79a9f52ac8b06a45e3d720@news.povray.org>
> > finally.
> > Michael
Many thanks from Germany to Russia!
Best regards,
Michael
Date: 9 Aug 2015 14:35:01
Message: <web.55c79d2252ac8b06a45e3d720@news.povray.org>
> > finally.
Many thanks for your comments.
One has to make compromises in CG. The walker is 2.10 m in height. Huge but not
impossible. The main problem I saw was the rope and the balance pole. They are
/* very */ much thicker as they should be. But invisible otherwise. And still
the anti-aliasing has problems with them. But increasing the the anti-aliasing
recursion depth yielded problems with the general lighting. So I had to meet a
compromise.
For your suggestion of arse illumination I have to study a little bit more. But
not with this image. I like it, and it will be as it is.
Best regards,
Michael
Date: 9 Aug 2015 14:44:22
Message: <55c79f86$1@news.povray.org>
Am 09.08.2015 um 20:34 schrieb MichaelJF:
> compromise.
You might give UberPOV's stochastic anti-aliasing mode a try.
Date: 9 Aug 2015 14:56:04
Message: <55c7a244$1@news.povray.org>
> Michael
That is no bad, Michael
Might go as far as saying it is AWESUM
Regards
Date: 9 Aug 2015 15:05:01
Message: <web.55c7a45052ac8b06a45e3d720@news.povray.org>
> > Michael
> Regards
>      Stephen
Thank you very much, Sir ;-)
Michael
Date: 9 Aug 2015 15:17:42
Message: <55c7a756$1@news.povray.org>
>>> Michael
>> Regards
>>       Stephen
My pleasure. :-)
Regards
Date: 9 Aug 2015 16:25:57
Message: <55c7b755$1@news.povray.org>
On 8/9/2015 6:26 PM, clipka wrote:
> and use arse... um, I mean, backside illumination
I see what you did.
Alternative spelling: erse :-)
Regards
