POV-Ray : Newsgroups : povray.binaries.images : polygon to circle loft Server Time
18 Mar 2026 10:44:19 EDT (-0400)
  polygon to circle loft (Message 22 to 31 of 51)
Subject: Re: polygon to circle loft
Date: 11 May 2015 11:40:02
Message: <web.5550cd06908ae421bad22bea0@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> The main thing that up - smooth, and down - flat, or on the contrary
> That the side appeared smoothly from a bottom to top, or on the contrary
Excuse me, I, ... I just can't understand them.
 I guess my English is too bad to realize what these sentences meant...
> In the Blender it will be mesh(fictitious, approximately similar), and will be
> exported to Povray as your object.
> For this purpose there will be special entry fields of necessary data.
So, would you like to write a converter that create such shapes and export to
Pov-ray?
Date: 11 May 2015 12:05:01
Message: <web.5550d253908ae421bad22bea0@news.povray.org>
Paolo Gibellini <p.g### [at] gmailcom> wrote:
> And wrote on 10/05/2015 18.07:
> > Here is a similar shape that blend a circle into two circles.
> There is a lot of potential: this object seems a half body of a cartoon
> character.
> Paolo
Well, here is its bottom.
Download 'loft test2 5 4m20s.png' (189 KB)
Preview of image 'loft test2 5 4m20s.png'
Date: 11 May 2015 12:30:01
Message: <web.5550d7e7908ae421bad22bea0@news.povray.org>
My polygon to circle blending shape has this (not so good?) property:
If you draw a straight line from one corner point of the polygon to the circle,
it will not fit its edge.
Download 'lofting 1 scale.png' (34 KB)
Preview of image 'lofting 1 scale.png'
Date: 11 May 2015 12:35:00
Message: <web.5550d9e0908ae421bad22bea0@news.povray.org>
scaled picture
Download 'lofting 1.png' (50 KB)
Preview of image 'lofting 1.png'
Date: 11 May 2015 12:45:08
Message: <web.5550db8b908ae421bad22bea0@news.povray.org>
But if you connect the circle to the middle point of one segment of the polygon,
you will get a straight line.
Download 'lofting scale2.png' (34 KB)
Preview of image 'lofting scale2.png'
Date: 11 May 2015 12:55:06
Message: <web.5550de9e908ae421bad22bea0@news.povray.org>
Hey, I ever rendered these pictures:
Download 'shapes.png' (146 KB)
Preview of image 'shapes.png'
Date: 11 May 2015 13:35:01
Message: <web.5550e7ca908ae4217a3e03fe0@news.povray.org>
> Pov-ray?
Sorry, I don't speak English. I use an online translator.
Well, I will try to explain on another.
Your first example has 6 edges.
How to write a similar polynom for N edges???
The user shouldn't write a formula. :)
The user needs this:
Download 'polynom.jpg' (16 KB)
Preview of image 'polynom.jpg'
Date: 11 May 2015 13:50:00
Message: <web.5550eb9e908ae4217a3e03fe0@news.povray.org>
I will specify:
Download 'polynom1.jpg' (19 KB)
Preview of image 'polynom1.jpg'
Date: 12 May 2015 02:50:00
Message: <web.5551a203908ae4213f4ed4340@news.povray.org>
If you are asking how to do that(shape) in Pov-ray, I have finished the work.
But there is some other detailed problem ...
Date: 12 May 2015 03:15:13
Message: <web.5551a758908ae4213f4ed4340@news.povray.org>
The file is here:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5551a29627d064353f4ed4340%40news.povray.org%3E/
You can just include it and use the macro:
//------coding here------------
#include "blending_polygon_circle_shape.inc"
object{
Shape_Polygon_To_Circle_Blending(5, x, 0.3, 0.1, 0.8)
pigment{rgb<0.5,0.56,0.5>}
1. The macro create a shape that blend a regular polygon of which center is at
<0,0,0>, to a circle of which center at <0,0, height>.
2. The first parameter is the number of sides of the polygon.
3. The second parameter is a vector.
4. The third parameter is the circumscribed circle radius of the polygon.
5. The fourth parameter is the radius of the circle.
6. The fifth parameter is the height of the shape.
