"LanuHum" <Lan### [at] yandexru> wrote:
> clipka <ano### [at] anonymousorg> wrote:
> > Hmm... maybe an off-by-1 error in the triangle vertex indices generated
> > by the exporter?
> We will wait for Mr.
> I don't see error. :(
Hi, sorry but I fail to see any problem in LanuHum's images or in mine when I
tried rendrering the scene in the official exporter. By just looking at
the pictures, the only problem I saw was ray depth set too low. Do you mean that
there is use of a syntax that is going to be deprecated ? I also checked the
normals of the file, which are fine. I don't have any urge to import the mesh
into PoseRay, though in the long run I can see it could be good to have a better
compatibility with it. But I'm probably missing something?
Subject: Re: WIP: We check the union Blender - Povray
Date: 29 Jun 2015 07:06:56
Message: <559126d0$1@news.povray.org>
The point in question was the mesh2 export result as exemplified by the
attached image of the object as it was shown in Poseray or as rendered
in POV-Ray.
Download 'data_vase_dec.jpg' (25 KB)
Preview of image 'data_vase_dec.jpg'
> > > by the exporter?
Why you didn't show render result???
Thomas, please check this vase in Poser.
This mesh2 was created by the official exporter.
It is important to me to know: there is a error or not?
Download 'povwip27.7z.zip' (895 KB)
>>>> by the exporter?
The file renders and the vase looks fine in PovRay 3.7.
But when loading into PoseRay I get an Access Violation.
Poser will not import PovRay files
Regards
Date: 30 Jun 2015 03:28:39
Message: <55924527@news.povray.org>
Now, this is an interesting conundrum.
The mesh2 geometry obviously seems corrupt when loaded in *Poseray*
(image povwip27.jpg).
However, it seems to render correctly, although extremely slow when
rendered in *UberPOV* (image povwip27_uber.png) ;
and a bit faster in *official POV-Ray* version (image povwip27_37.png).
To speed things a bit up, I switched photons off.
My guess is that the export is not really correct because the vase which
was made from an obj version rendered fast, also with photons. So, the
official exporter needs to be looked into.
Download 'povwip27.jpg' (26 KB)
Download 'povwip27_37.png' (64 KB)
Download 'povwip27_uber.png' (85 KB)
Preview of image 'povwip27.jpg'
Preview of image 'povwip27_37.png'
Preview of image 'povwip27_uber.png'
Am 30.06.2015 um 09:28 schrieb Thomas de Groot:
There's a simple solution to the riddle:
It's a bug (or undocumented limitation) in PoseRay.
The official syntax of the face_indices block is as follows:
face_indices {
number_of_faces,
<index_a, index_b, index_c> [,texture_index [,
texture_index, texture_index]],
<index_d, index_e, index_f> [,texture_index [,
Apparently PoseRay stumbles over the optional texture indices.
> Thomas
Thanks!
I am inclined to consider that the error in the official exporter is.
If in a scene of lathe and mesh2, the created Povray (meshmaker), caustics from
objects have identical intensity and uniformity at spacing 0.01.
But, if mesh2 creates blendpov, caustics from lathe and from mesh2 have
different intensity and dances with a tambourine demand.
On the weekend I will try to take it a error.
If the obj file gives a correct idea, to the obj exporter can give the answer.
obj doesn't take a normal from vertices.
obj calculate normal split.
It is a victory or not?
spacing 0.005
Trace Time: 0 hours 3 minutes 23 seconds (203.487 seconds)
using 4 thread(s) with 797.850 CPU-seconds total
POV-Ray finished
'***POVRAY FINISHED***
Download 'update_export_mesh.jpg' (74 KB)
Preview of image 'update_export_mesh.jpg'
Date: 1 Jul 2015 03:01:29
Message: <55939049@news.povray.org>
It certainly is! Well done!
> Thomas
Thanks for the report then. This looks like it would be a most profitable fix.
But I hope it is not intrinsically related to the face indices features used for
exporting multiple materials, because this was the only way to keep the Blender
centric approach of the exporter (preserving the material assigned locally to
different parts of a mesh).
