POV-Ray : Newsgroups : povray.binaries.images : dandelion Server Time
15 Mar 2026 01:49:46 EDT (-0400)
  dandelion (Message 31 to 40 of 40)
Subject: Re: dandelion
Date: 19 Oct 2014 02:50:01
Message: <web.54435ec029a2be8f7a3e03fe0@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote:
> "LanuHum" <Lan### [at] yandexru> wrote:
> > Particle systems (Hair) for a dandelion :)
> Looks pretty good, maybe the hairs are a bit too straight but this probably
> wouldn't show up other than at high res/close up.
It is possible to adjust a bend, but for this purpose it is necessary to use
sphere_sweep that much more will increase time of a render
> Are you going to put the whole thing together and texture it, would be
> interesting to see the comparison. I expect yours will be much better for memory
> consumption.
> Sean
I haven't enough time to create a full scene.
Perhaps, I will make it later.
Download 'dandelion_sphere_sweep.jpg' (301 KB)
Preview of image 'dandelion_sphere_sweep.jpg'
Date: 20 Oct 2014 03:43:50
Message: <5444bd36@news.povray.org>
s.day wrote on 15/10/2014 22.02:
> and with the correct texture for the stalk..
Incredible!
Paolo
Date: 20 Oct 2014 15:49:30
Message: <5445674a@news.povray.org>
> if purely SDL,
> you were better than several commercial software like e.g. xfrog !
> In case of that, I bend my head for the one and only real Pov prophet, who will
> save us as all...
> Otherwise ... the source - please!
> Norbert
Hi Norbert,
Took me longer than I thought but the source file is now in p.b.sf I
included a HDR probe that I made with megapov as an experiment years
ago, it is not good but I did not want to upload someone else's probe. I
would suggest downloading a decent external probe to try it out.
Also, the dandelion clock only looks bright with radiosity enabled
(makes a big difference).
Sean
Date: 23 Oct 2014 21:15:01
Message: <web.5449a73929a2be8f5e7df57c0@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote:
> On Fri, 17 Oct 2014 08:03:14 +0200, s.day <s.d### [at] uelacuk> wrote:
> For the texture I made a recursive texture macro. Maybe you could adapt
> it
I tried that out after I fixed a few things that kept it from running out of the
box, and this is what I got.  Maybe something got messed up with the copy-paste.
Download 'leaf.png' (45 KB)
Preview of image 'leaf.png'
Date: 24 Oct 2014 03:24:36
Message: <5449feb4$1@news.povray.org>
That is more than I did :-) My image is empty...
Date: 26 Oct 2014 13:54:11
Message: <op.xocmn8zeufxv4h@xena.home>
On Fri, 24 Oct 2014 03:11:21 +0200, Bald Eagle
<cre### [at] netscapenet> wrote:
Here's a scene with a leaf
// Begin code //////////////////////////////////////////////////////////
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
#include "stones.inc"
#include "woods.inc"
#include "shapes.inc"
#include "shapes2.inc"
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
// camera
#declare Camera_0 = camera {/*ultra_wide_angle*/ angle 75      // fron
t
view
                             location  <0.0 , 1.3 ,-3.0>
                             look_at   <0.0 , 1.0 , 0.0>}
#declare Camera_1 = camera {/*ultra_wide_angle*/ angle 90   // diagona
l
view
                             location  <2.0 , 2.5 ,-3.0>
#declare Camera_2 = camera {/*ultra_wide_angle*/ angle 90 // right sid
e
view
                             location  <3.0 , 1.0 , 0.0>
#declare Camera_3 = camera {/*ultra_wide_angle*/ angle 90        // to
p
view
                             location  <0.0 , 3.0 ,-0.001>
camera{Camera_0}
// sun
light_source{<-1500,2500,-2500> color White}
// sky
sky_sphere { pigment { gradient <0,1,0>
                        color_map { [0.00 rgb <1.0,1.0,1.0>]
                                    [0.30 rgb <0.0,0.1,1.0>]
                                    [0.70 rgb <0.0,0.1,1.0>]
                                    [1.00 rgb <1.0,1.0,1.0>]
                        scale 2
                      } // end of pigment
            } //end of skysphere
// fog
// ground
plane{ <0,1,0>, 0
        texture{ pigment{ color rgb <0.825,0.57,0.35>}
                 normal { bumps 0.75 scale 0.025  }
                 finish { phong 0.1 }
               } // end of texture
      } // end of plane
//---------------------------- objects in scene
//object{Leaf()}
#ifndef(Rand)
     #declare Rand=seed(97531);
#declare LeafHalf=
// 3D curved FINITE (no CSG) surface created from a mesh of triangles
bicubic_patch {
   type 0 // patch_type (0..1)
   // 0 = Bezier patch, just store the triangular vertices
   // 1 = Bezier patch, store all plane equations defined by
   //       the triangulation of the patch into sub patches
   //       (faster, uses more memory)
    flatness 0 // flatness value
   //       flatness_value = 0.0 to 1.0, with higher values
   //        giving flatter, less smooth results
   u_steps 4 // # of triangles to subdivide (1-5)
   v_steps 4 // # of triangles to subdivide (1-5)
   <0,0,0>      <0,.266,.054><-.15,.4,.6> (<-.15,.4,.6>+<.506,.3,.508>)/
2
//<.151,.251,.415>
   <.119,.175,0> <.5,.2,.2><.4,.2,.318> <.506,.3,.508>
   <.288,.334,0> <.4,.3,.2><.8,.1,.05>  <.7,0,.067>
   (<.288,.234,0>+<.777,.1-.079,0>)/2
                 <.777,-.079,0><.8,-.167,0>    <.7,-.2,0> // <1,-.5,0>
   scale <.9,1,1.5>
#declare LeafShape=
// rotate a 2-D outline of points around the Y axis to create a 3-D shap
e
// extrude a closed 2-D shape along an axis
prism {
   linear_sweep  // or conic_sweep for tapering to a point
   linear_spline // linear_spline | quadratic_spline | cubic_spline |
bezier_spline
   -1,         // height 1
    1,         // height 2
   44, // number of points
  <0,0>,<.054,0>,
  <.65,.08>,<.6,.1>,
  <.63,.12>,<.6,.14>,<.64,.16>,<.61,.18>,
  <.65,.2>,<.62,.22>,<.66,.24>,<.61,.26>,
  <.65,.28>,<.6,.3>,<.62,.35>,
  <.57,.35>,<.59,.39>,<.55,.39>,
  <.55,.45> ,<.53,.43>,<.52,.52>, <.5,.45>,
  <.48,.51>,<.46,.49>,<.44,.54>,<.43,.51>,
  <.41,.56>,<.39,.54>,<.37,.58>,<.35,.56>,
  <.33,.6>,<.31,.58>,<.28,.63>,<.26,.61>,
  <.22,.65>,<.2,.63>,<.15,.68>,<.14,.65> ,
   <.12,.7>,<.09,.68>,<.06,.72>,<.04,.71> ,<0,.73> ,<0,0>
  rotate y*90
  rotate x*180
  translate <-.11,0,>
  scale<1.01,1,1.3>
pigment {rgbft<1,0,1,.3,.3> }
finish{brilliance 4 specular .3}
#declare Trans1=rand(Rand);
#declare Trans2=rand(Rand);
#macro FracPigm(Recursions,ColA,ColB)
      #local Count=0;
      #while (Count<Recursions)
       wood
       rotate Count*30
       triangle_wave     warp{turbulence <.1+.5*Trans1,0,.1+.5*Trans2>}
       scale .5 // warp{turbulence .5}
       pigment_map{[0 rgbt
((ColA*(Recursions-Count))+(ColB*Count))/Recursions]
                   [.05
       #local Count=Count+1;
      rgbt ColB
      #while (Count>0)
      #local Count=Count-1;
#macro FracBump(Recursions,ColA,ColB)
      #local Count=0;
       //gradient x  rotate y*30
       //gradient x rotate y*15
       wood
       rotate Count*30
       normal_map{[0 wood -(Recursions-Count)*.3]
                   [.2
      quilted .3  rotate <0,45,45> scale <.3,3,1>  warp{turbulence .1}
      #while (Count>0)
#macro FracTex(Recursions,ColA,ColB)
      #local Count=0;
       wood
       rotate Count*30
       texture_map{[0 pigment{ rgbt
((ColA*(Recursions-Count))+(ColB*Count))/Recursions }
                     normal{wood  -(Recursions-Count)*.3 slope_map{[0
<1,0>][1 <0,-1>]}}
                     finish {diffuse .5,0}
                   [.1
      pigment{rgbt ColB }
      normal{quilted .3  rotate <0,45,45> scale <.3,3,1>  warp{turbulenc
e
.1}}
      #if(version>3.6)
         finish {diffuse 1,.01 ambient .6 specular .5 metallic .5}
      #while (Count>0)
//#declare LeafTex1=
#macro LeafTex1()
           object{LeafShape
                                       texture{ pigment{rgbt 1} }
                                       texture{
                                               gradient z  rotate y
                                                texture_map{
                                                        [0 pigment{ colo
ur
rgb <0.4,0.533,0.035>*.2}]
                                                        [.05
FracTex(3,<0.4,0.533,0.035,0>*.2,<0.365,0.533,0.035,.5>*.08)
                                                        //rgb .5
 rotate
<0,30,-60>
 scale
<.6+.1*rand(Rand),.9,.5>*.9
 translate
<.5,-.1,0>
 warp{turbulence
.01+.01*Trans1}
//#declare LeafTex2=
#macro LeafTex2()
           object{LeafShape
                                       texture{
                                               gradient z  rotate y
                                                texture_map{
                                                        [0 pigment{ colo
ur
rgb <0.4,0.533,0.035>*.5}]
                                                        [.05
FracTex(3,<0.4,0.533,0.035,0>*.5,<0.365,0.533,0.035,.1>*.2)
                                                        //rgb .5
rotate
<0,30,-60>
 scale
<.4+.3*rand(Rand),.9,.5>*.9
 translate
<.5,-.1,0>
 warp{turbulence
.01+.01*Trans1}
//#declare Leaf=
#macro Leaf()
         union{object{LeafHalf LeafTex1()}
             object{LeafHalf LeafTex2() scale <1,1,-1>}
             #if (rand(Rand)>.5)
                 scale <1,1,-1>
//object{Leaf()}
object{Leaf() rotate z*-60 rotate y*140 translate y}
// End code
-Nekar Xenos-
Download 'leaftest.png' (341 KB)
Preview of image 'leaftest.png'
Date: 27 Oct 2014 04:43:26
Message: <544e05ae$1@news.povray.org>
Thanks a lot!
I need to delve into this to discover what makes it tick... :-)
Date: 27 Oct 2014 14:01:24
Message: <op.xoehojwkufxv4h@xena.home>
On Mon, 27 Oct 2014 10:43:26 +0200, Thomas de Groot <tho### [at] degrootorg>
wrote:
> Thanks a lot!
> Thomas
It's similar to graph paper with thinner lines for each subdivision,
working only in halves, then skewed and turbulence added.
-Nekar Xenos-
Date: 31 Oct 2014 20:08:40
Message: <54542488$1@news.povray.org>
Thanks, it never ceases to amaze me what can be done with procedural
textures. I will look into this when I have some more time to workout
what you are doing.
Sean
Date: 5 Nov 2014 14:21:59
Message: <op.xou9eushufxv4h@xena.home>
> what you are doing.
> Sean
I recursively shrink and rotate the texture within itself to simulate the
"veins" in the leaf.
-Nekar Xenos-
