POV-Ray : Newsgroups : povray.binaries.images : Secret Passage WIP (TINA CHeP) Server Time
13 Mar 2026 07:36:20 EDT (-0400)
  Secret Passage WIP (TINA CHeP) (Message 47 to 56 of 106)
Subject: Re: Secret Passage WIP (TINA CHeP)
Date: 29 Oct 2014 04:31:32
Message: <5450a5e4@news.povray.org>
This is coming on very nicely indeed. Good progress!
I have a couple of (minor) comments.
- Nitpicking. The rod from the farthest ceiling fixture aligns too well
with the frame edge of the portrait over the mantelpiece. This is not
vital but it catches the eyes (mine at least). just shift the camera, or
the frame, or the lamp a little bit, whichever is best.
- The big mirror over the couch seem a bit flat to me.
- the carpet could use a bit of (more) thickness/fluffiness.
- The lighting of the scene. Much better than before but I am not sure
where the light is coming from now. Somewhere in between the two light
fixtures? In the final version I suppose you will light the lamps
themselves?
- The tunnel entrance. Shouldn't there not be some way to show /how/ the
entrance is closed? I suppose there should be some notches along the
edges for the missing boards. Nitpicking: The floor boards being aligned
parallel to the entrance, the closing lid must be especially reinforced
in order to remain rigid when somebody walks over it ;-)
- Detail. Could you give the painting of the lady with the flowers some
painterly aspect? It looks too much like a photograph to me but that
might be the effect of the distance. Impressionism would be the way to
go for the time period and the subject matter.
Date: 29 Oct 2014 08:05:00
Message: <web.5450d7a7cbb3d815192ae5f10@news.povray.org>
> I must admit - the radiosity is a very nice lighting enhancement, and really
> makes the tunnel look much better and gives much better definition to many of
> the objects in the room.
Radiosity is almost always a dramatic improvement.  It gives depth to shadowed
areas.  Ambient occlusion (which falls out of radiosity) is a part of life, and
scenes look flat without it.
> Please chime in with constructive criticism - [snip]
> So, I'm looking to hear about what I can do to really raise the level of quality
> since I think I'm done modeling the bulk of the _things_ and can begin shifting
> more of my focus to the crafting of textures normals and finishes, camera angle,
> lighting, radiosity, HDRI lighting, media, etc.
The mirror on the left is too flush with the wall, and the reflection is too
cloudy (unless you intend it to be a very dingy mirror).
If that's sunlight coming through the door on the right, it needs to be /a lot/
stronger.
With the floor flush with the walls of the passage, how does the lid support
itself?
Date: 29 Oct 2014 11:25:00
Message: <web.545105eecbb3d8155e7df57c0@news.povray.org>
>The rod from the farthest ceiling fixture...
I'll see what I can do about that.
It does, doesn't it.  It actually does have depth, but for some reason this
camera angle makes it look bad.
Yes, I need to do something with that for sure.
> themselves?
Correct.  My "WIP light".  I'm going to take a stab at getting those ceiling
lamps illuminated from within and see what sort of light they throw.
It is a bit mirky as to the mechanism - and there certainly aren't any visual
cues to suggest that where the entrance IS, the carpet USED TO BE.
Here and there I considered doing SOMETHING - I just haven't really latched onto
WHAT.
"Notches" - like tongue-and-groove?
It's about 2 full inches thick, so I figured that maybe there were
through-dowels or threaded rods or something.
There's actually a small ledge of stone on either side of the tunnel that the
sliding floor panel rests on - I suppose I ought to accentuate that, put a rail,
some rollers, a latch - something
Good instinct - I felt it far too "clean" as well - and I like the simu-paint
idea.  I'll have to go back and look over that recent thread.
I hadn't the energy to mess with it prior to rendering it with radiosity since I
had only just emerged from a long and arduous debugging of my
Frame-plus-mirror/picture code.
It still seems a bit lacking and likely needs an overhaul.
Lesson learned: missing or flat-out wrong parentheses and curly braces are
annoying.  MISPLACED curly braces that allow the scene to render but don't give
you what you want can make you question your eyesight and sanity.
Date: 29 Oct 2014 11:30:01
Message: <web.5451072dcbb3d8155e7df57c0@news.povray.org>
I don't know why that is, since it should be exactly the same texture as the
mirror in the back left corner.
From an earlier state:
http://postimg.org/image/omlhifip1/
> stronger.
Yes, lighting is indeed something that's only been done with makeshift
"worklights"  up until now - and so begins a whole new phase of learning and
experimentation.
> itself?
"CG magic."  ;)
(See above - it has an inadequately visible ledge.)
Date: 29 Oct 2014 11:51:03
Message: <54510ce7$1@news.povray.org>
You can do that also in GIMP quite easily.
Yes, that is nasty indeed.
Date: 29 Oct 2014 14:20:00
Message: <web.54512f56cbb3d815192ae5f10@news.povray.org>
Word.
Date: 29 Oct 2014 18:57:16
Message: <545170cc$1@news.povray.org>
On 28/10/2014 15:20, Bald Eagle wrote:
> Current state of the WIP:
Thanks for sharing this WIP. This version is expanding and fulfilling
your initial post. It is a joy to watch.
And I have noticed that people who do what you are doing get better
images in the end.
I disagree with all the comments about the "hidden" passage. I think
that you have got it just right. It is magical, you know. And doesn't
need to be realistic.
But I think the carpet should be scaled a bit wider and the floorboards
changed a bit. They look like laminate. If you look at the floorboards
in Warp's Tips http://warp.povusers.org/povtips/ you will see what I mean.
Anyway, great work so far. :-)
Regards
Date: 29 Oct 2014 23:00:00
Message: <web.5451a97dcbb3d8155e7df57c0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> And I have noticed that people who do what you are doing....
Rough layout and then piecewise elaboration and improvement?
I have sort of wondered exactly how this was supposed to work:
The whole of the centre of the floor had disappeared into the wall opposite to
the fireplace, and the rough steps led down into a kind of passage that ran in
the direction of the unfinished house.  "This is the entrance," said Jennings,
"it works from a concealed button on the wall.  Electricity is used.  You see
why the sides of the floor are left bare; the carpet has quite disappeared.
Trying to translate this gadget from the book into something visual, I recall a
quote from someone working on the movie Jacob's Ladder speaking to the author -
"Just tell me one thing: How may carpenters do I need to build "the void"?
>and the floorboards
I started out by copy-pasting his code - I think perhaps it's the scale of the
texturing, the distance of the camera from the floor, or the smoothness of the
floorboards that may give rise to that effect.  I've got a few things that I'm
modifying in the floor code, so I think that will incrementally improve as I
work through all the facets to weed out all of the glitches and artefacts, and
polish things up.
Thanks very much, Stephen - a lot of the things I've played with in the past
have been a bit simplistic, and I've often looked at the work of the Masters
here and wondered how I would ever do anything like THAT, so it means a lot to
hear that I'm catching on.
So here I am, 1900 lines, a dozen include files, and a WIP directory with over
500 files and >150MB of sample images, etc....   and maybe a little carpal
tunnel inflammation  ;)
Date: 30 Oct 2014 05:12:41
Message: <54520109@news.povray.org>
That too but I really meant exposing your early WIPs to public scrutiny
and criticism.
One advantage, other than the practical help. Is that as we see the
piece develop, we become involved and have a greater appreciation of it.
Which translates into a higher score.
The answer is, if you believe your bible, One and his dad. ;-)
One thing I have noticed is that Povs cameras do not match the "mind's
eye" camera. Sometimes what authors write cannot be realised in reality.
So you can only show what you think works.
> polish things up.
I just mentioned it to add to your list. :-)
You are and at a fast pace too.
The way of the world. :-)
Recently I transferred all of my PovRay and Poser files from an old
machine to a new one. It took all night via WiFi. Now I have to do it
again to a desktop machine.
BTW Did you know that it is possible to type with your elbows?
Another non-standard typing method I have come across is typing with
your thumb and first two or three fingers pressed together for strength.
I noticed this when I worked for a newspaper. The "ex-hot metal"
compositors typed like that.
Regards
Date: 30 Oct 2014 08:15:00
Message: <54522bc4$1@news.povray.org>
> and criticism.
...and not to forget, you get stimulated to pay attention to details
that you may have missed otherwise but which turn out to be quite
essential in the end.
>> with over
>> carpal
Lol! I didn't know that! It reminds me of carillon playing: with fists.
I have a cousin-in-law who is a professional player and he sometimes
uses his elbows too :-) Never tried it myself on a keyboard though ;-)
