![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 20/05/2014 07:19, s.day a écrit :
> "Eriban" <pov### [at] spamgourmet com> wrote:
>> Hi,
>> It's been a while since I had some time and inspiration to create something in
>> POV-Ray, but I had a bit of both recently. Here's the result, which I hope you
>> like.
>> Cheers,
>> Erwin
> Very good, I understand how someone can draw something like this but to model it
> in POV... I have no idea how that could be done.
> Sean
Make it a T-shirt... or a corporate logo !
Actually, wonderful on a black T-shirt, need a white background for
printed logo, but not sure it remains as lovely.
It remind me of Escher, but of different kind.
http://www.4-construction.com/fr/magazine/images/formes-geometriques-dans-les-peintures-de-mc-escher_7539/12345/
The gear could be the next General Motors' or any steel/mechanic-related
company.
Or even a TV channel.
Just because nobody complains does not mean all parachutes are perfect.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 19-5-2014 21:26, Eriban wrote:
> Hi,
> like.
You truly are a 3D Escherian. Very well done indeed. And beautiful too.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for all your comments. Please find my replies below.
Stephen <mca### [at] aol com> wrote:
> That is nice. I've not seen that one before.
> :-D
It's indeed far less common than the impossible triangle for example. However,
this illusion is not the first of its kind. See for example
http://im-possible.info/english/art/computer/ausbourne.html or
http://impossible-world.blogspot.nl/2014/03/impossible-cog-wheels.html. The
drawings on the latter page actually inspired this one.
Jim Henderson <nos### [at] nospam com> wrote:
> Very nice, and a wonderful variation of the triangle (wasn't that Escher?) image.
Thanks. Escher indeed created drawings based on the impossible triangle,
> Now I want to know how it was done. ;)
The basic part of this illusion is quite straightforward to achieve. Two halfs
of the gear, oriented at right angles and placed such that they appear to line
up.
The devil is in the detail though. Given that the surface is reflective (and
also has a subtle normal) a few more tricks are needed to avoid discontinuities.
It's rendered in one go though, and did not require any post-processing.
"jhu" <nomail@nomail> wrote:
> That's unpossible!
Well, apparently not. Ray-tracers don't lie... ;-)
Thanks. My above reply to Jim gives some insight on how to start. One of the
advantages of ray-tracing is that you have quite powerful tools at your
disposal: perfectly accurate object placement, perfect mirrors, perfect copies
of objects, programmatic textures, etc. Those all really help when rendering
impossible objects.
Might make a nice t-shirt indeed. The black background really helps to make the
object stand out, so best to leave that unchanged.
Yes, it's quite similar to the ribbons in Escher's "Cube with magic ribbons"
drawing. That one, however, is more advanced with bumps slowly morphing into
dents. Maybe I should give that a go as well sometime.
> company.
It's a question though whether it then represents excellence, or shoddy
craftsmenship ;-)
Thanks. This is indeed becoming my ray-tracing specialty. The only thing I can
do reasonably well. Ah well, better that than doing many things poorly I
guess...
Cheers,
Erwin
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> (and also has a subtle normal) a few more tricks are needed to avoid
> discontinuities.
Indeed, I could see that this would make things really challenging. You
did a /fantastic/ job with lining things up and avoiding reflections that
give it away. :)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Eriban wrote:
> Hi,
> something in POV-Ray, but I had a bit of both recently. Here's the result,
> which I hope you like.
> Cheers,
> Erwin
I don't like it, I love it. It puts the impossible cube I did a while ago way to
shame.
Ger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>Eriban on date 19/05/2014 21.26 wrote:
> Hi,
> like.
> Cheers,
> Erwin
For impossible engines...
A fantastic shot!
Paolo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 20.05.2014 22:36, schrieb Eriban:
>> :-D
I think your version tops it though.
>> company.
> craftsmenship ;-)
Flexibility. It obviously represents the amalgamation of excellence and
flexibility.
> guess...
"reasonably well"? You must be an Englishman, as that's typical English
understatement.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
shame.
Thanks. Well, an impossible cube is a good start. Hopefully this will inspire
you to try some more impossible scenes. They are fun! :-)
> A fantastic shot!
Thanks!
Thanks.
> >> company.
> > craftsmenship ;-)
> flexibility.
Ah yes, that sounds better. So maybe it's a suitable logo for an Agile Hardware
company.
> understatement.
Well, I am not English but did live there for a few years, so I might have
picked it up there.
Cheers,
Erwin
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hi,
> like.
> Cheers,
> Erwin
You inspired me to try my hand at animating some of those. The html makes it all
tile.
Thanks,
Jeff
Download 'geartile.zip' (181 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> tile.
Hi Jeff,
I really like this. I am surprised by how well it actually works, given the
awkward shape of the gears. Occasionally the gear teeth don't seem to fully
interlock, but there's some redundancy in your set-up, so it all keeps turning
nicely. At least, I have been watching it for a fair while now, and didn't see
any hiccups ;-)
Cheers,
Erwin
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
