Le_Forgeron <jgr### [at] free fr> wrote:
> > I too wanted that my exporter was useful to someone such to what I write it,
> > but, it appeared, it is necessary for nobody.
Sorry!
> Do you have a modeler for rbezier ?
> Or a killing-picture with them ? (like in "killing-application" of the
> Internet bubble)
You - master in C++
> > Then, I won't ask you about opencl. :)
> What's the relation ?
Povray loses on speed, exactly, because of a stubborn position........
The big problem to redistribute calculations on the videocard?
"Nekar Xenos" <nek### [at] gmail com> wrote:
> If I understand correctly this could have helped me when I made my bass
> for cutting the c-holes from the sound-box.
> -Nekar Xenos-
Your guitar - small that I can make.
Simply, I can't brag: God doesn't resolve!
My task - to help all!
Download 'egg.png' (113 KB)
Preview of image 'egg.png'
Download 'pfcg.jpg' (17 KB)
Preview of image 'pfcg.jpg'
> On Fri, 25 Apr 2014 20:07:55 +0200, LanuHum <Lan### [at] yandex ru> wrote:
>> Me all interests about Povray
>> http://atrey.karlin.mff.cuni.cz/~0rfelyus/
>> RBezier
>> This patch is the last in my series of patches for POV-Ray. It extends
>> POV-Ray
>> by ray tracing of trimmed rational Bezier surface patches using Bezier
>> clipping
>> (as described by Nishita, Sederberg and Kakimoto).
>> ftp://atrey.karlin.mff.cuni.cz/pub/local/0rfelyus/povray-3.02/examples/trims-b.png
>> I didn't find in Povray-3.7 opportunity to create bezier patch
>> Good idea for creation of leaves
An electric bass guitar with a violin/celo body? That's new...
>>> RBezier
ds
>>> POV-Ray
er
>>> clipping
es/trims-b.png
ss
My design electro-acoustic bass based on a contra-bass.
I hand-coded the sound-box as a bezier patch. I CSG'd the C-holes out of
the soundbox but I couldn't add depth because I couldn't csg the sides o
f
the C-holes. I was thinking maybe this patch would make it possible.
-Nekar Xenos-
> of the C-holes. I was thinking maybe this patch would make it possible.
Could you not subtract the a scaled down version to create the resonance
chamber?
I am assuming that the thickness of the upper and lower surfaces need
not be detailed modelled to get a realistic sound body.
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
This email is free from viruses and malware because avast! Antivirus protection is
active.
http://www.avast.com
> chamber?
It just ends up looking like a shadow. I need to do the walls/edges of the
c-holes and they need to match.
-Nekar Xenos-
>> resonance chamber?
> the c-holes and they need to match.
Right now, the C-holes look like they are painted on...
How about replacing the patch with an hight_field?
Do a render of only the front face using an orthographic camera and a
black to white gradient. Use +fng16 on the command line when using
version 3.7.
Add some slight bluring to get some beveling/rounding. May be done using
some focal blur or by post processing.
Use water_level to remove the outside part.
As it may be to thick around the openings, you can now use a difference
around the C-holes to get just the correct thickness.
For the back face, you can still use the bezier patch, or you can use
another hight_field made without the openings.
> >>> RBezier
> ds
> >>> POV-Ray
> er
> >>> clipping
> es/trims-b.png
> ss
> f
> -Nekar Xenos-
What about putting a thin box inside the soundbox behind where the C-holes are
then simply cutting a hole in this box as well?
Seab
