POV-Ray : Newsgroups : povray.binaries.images : luminance output Server Time
18 Feb 2025 17:50:26 EST (-0500)
  luminance output (Message 1 to 10 of 23)
Subject: luminance output
Date: 16 Apr 2014 02:55:02
Message: <web.534e2857251103cb6a92a3a00@news.povray.org>
Hello,everyone.I am a student.I am doing my graduation project recently.It is
simulating radiance with ray-tracing.I have done a test with pov.But I am
confronting a error with my result.Could anyboby help me check out my issue.Beg
a hot.I am a student.I am confronting the pressure of graduation.I feel so
worry.I have uploaded the whole process of my test,beg a hot help me!
"pov-xyz"is the location of each sphere.
"pov-ref"is the reflectivity of each sphere.
"pov.exr"is the output image by pov.
I have converted "pov.exr" to "pov.tiff".
"result"is my analyse.My issue was wrote in it.
Expecting somebody help me.Great gratitudes!
Download 'pov-730nm.zip' (1632 KB)
Subject: Re: luminance output
Date: 16 Apr 2014 03:45:18
Message: <534e350e@news.povray.org>
Using a specular highlight on tiny spheres is going to give very
unpredictable results, the output pixel value will highly depend on
exactly where the ray hits the sphere compared to the highlight
position. I zoomed in on your scene and rendered it, see attached, I
also changed the background colour to red to highlight the spheres
better. Do you see the problem?
I would use boxes rather than spheres and use diffuse rather than
specular reflection:
  pigment{color rgb 1}
  finish {
   ambient 0
   diffuse ref
That should give much more uniform results and not depend on where each
ray hits the shapes. I don't know if that will solve your problem or not.
Download 'pov.png' (4 KB)
Preview of image 'pov.png'
Date: 16 Apr 2014 03:58:57
Message: <534e3841$1@news.povray.org>
Oops forgot the 1st attachment.
Download 'pov_red_background.png' (9 KB)
Preview of image 'pov_red_background.png'
Date: 16 Apr 2014 12:15:01
Message: <web.534eac5dc34aaa776a92a3a00@news.povray.org>
>   finish {
>    ambient 0
>    diffuse ref
I have modified the statements and done a test with your advice.I find the
result changed,but not what I wanted.Besides,I only have 40000 points ,if I used
box as my model, which needs two points to describle,but my input scene is as
"pov.tif".One point stands for one object,corresponding,with a reflectity.If I
used box,may need two point to descible a object,I doublt the scene is not my
wanted.
Download 'pov.tif.dat' (487 KB)
Date: 16 Apr 2014 19:59:52
Message: <534f1978@news.povray.org>
>>    finish {
>>     ambient 0
>>     diffuse ref
> wanted.
You can use boxes instead of spheres without doubling the size of your
file. Curently, you use this code to place your spheres:
sphere {
  <x1-center_x,y1-center_y,z1-center_z>,1.55
  finish { ambient 0
           emission 0
           specular ref
To use box, just use this code:
box{-1.55, 1.55 // reduce slightly is you want to keep some gap.
// The following line is the key...
	translate <x1-center_x,y1-center_y,z1-center_z>
  finish { ambient 0
           emission 0
           specular ref
This will give you boxes with a width identical to the diameter of your
spheres.
Even beter, make an union containing all your objects:
union{
#fopen   Input_geom_file geom_file_name read
#fopen   Input_spec_file spec_file_name read
#while(defined(Input_geom_file))
     #read(Input_geom_file, X1, Y1, Z1)
     #read(Input_spec_file, Ref)
	translate <X1-Center_X,Y1-Center_Y,Z1-Center_Z>
        }// Remove the texture from the objects
// and apply it to all objects at once
  finish { ambient 0
           emission 0
           specular Ref
}// End of the union
As the variable "n" is never used, I removed it.
Finaly, a general recomendation: In all of your user defined variable,
use at least ONE upper case letter. This ensure that you don't have any
conflict with predefined variables and primitive. It also make it clear
that those are YOUR variables. It can realy help when debugging your code.
Date: 16 Apr 2014 22:25:00
Message: <web.534f3b05c34aaa776a92a3a00@news.povray.org>
> >>    finish {
> >>     ambient 0
> >>     diffuse ref
> > wanted.
> sphere {
>   finish { ambient 0
>            emission 0
>            specular ref
>   finish { ambient 0
>            emission 0
>            specular ref
> spheres.
> union{
> #end
>   finish { ambient 0
>            emission 0
>            specular Ref
> Alain
I have changed with your advice,and have a test.but the image is black.Nothing
in my scene.
Date: 16 Apr 2014 22:35:01
Message: <web.534f3d7dc34aaa776a92a3a00@news.povray.org>
> >>    finish {
> >>     ambient 0
> >>     diffuse ref
> > wanted.
> sphere {
>   finish { ambient 0
>            emission 0
>            specular ref
>   finish { ambient 0
>            emission 0
>            specular ref
> spheres.
> union{
> #end
>   finish { ambient 0
>            emission 0
>            specular Ref
> Alain
I have 40000 points.It stands for 40000 surfaces.Corresponding,there is 40000
reflecities.Irradiance(w/m^2) is my real solar engry.I expect the result is
radiance(w/m^2*str)or luminance(cd/m^2),but I donot know what it is?And how can
I get my desired?
Date: 16 Apr 2014 22:55:01
Message: <web.534f41adc34aaa776a92a3a00@news.povray.org>
issue.Beg
> > >>    finish {
> > >>     ambient 0
> > >>     diffuse ref
> > > wanted.
> > sphere {
> >   finish { ambient 0
> >            emission 0
> >            specular ref
> >   finish { ambient 0
> >            emission 0
> >            specular ref
> > spheres.
> > union{
> > #end
> >   finish { ambient 0
> >            emission 0
> >            specular Ref
> > Alain
I have done a try with your advice,but the image is black.
 I get my desired?
Date: 17 Apr 2014 03:08:52
Message: <534f7e04$1@news.povray.org>
> in my scene.
It's always helpful to post the bit of code you changed, otherwise
nobody has any idea why your image is black, it could many different
reasons.
This works for me, I also added the rotate command as it seems your
points are not aligned with the axes:
box
          -1.55,1.55
         rotate y*-30
          finish {
            ambient 0
            diffuse ref
May I ask where you got the "reflection" numbers from in your
pov-ref.txt file? If I knew where those numbers came from it might help
trying to figure out what you want to achieve.
Date: 17 Apr 2014 05:20:01
Message: <web.534f9c31c34aaa776a92a3a00@news.povray.org>
> >>    finish {
> >>     ambient 0
> >>     diffuse ref
> > wanted.
> sphere {
>   finish { ambient 0
>            emission 0
>            specular ref
>   finish { ambient 0
>            emission 0
>            specular ref
> spheres.
> union{
> #end
>   finish { ambient 0
>            emission 0
>            specular Ref
> Alain
Hello,I want to ask a question:
"try
  Imf::RgbaChannels channels;
  if (options.grayscale)
   if (use_alpha)
    channels = WRITE_YA; // only write luminance & alpha
   else
    channels = WRITE_Y; // only write luminance
  else
   if (use_alpha)
    channels = WRITE_RGBA; // write RGB & alpha
   else
    channels = WRITE_RGB; // write RGB"
this is a part of resource code in openexr.cpp,I want to write luminance
only,how can I set some parameters in pov?
