POV-Ray : Newsgroups : povray.binaries.images : Le Forgeron: experiments Server Time
17 Feb 2026 07:32:27 EST (-0500)
  Le Forgeron: experiments (Message 42 to 51 of 71)
Subject: Re: Le Forgeron: experiments
Date: 3 Apr 2016 16:41:17
Message: <57017fed@news.povray.org>
Le 03/04/2016 21:40, LanuHum a écrit :
> "LanuHum" <Lan### [at] yandexru> wrote:
>> The hgpovray connection with the Blender continues.
> Le Forgeron example:
> camera
> { stereo distance (26)
> parallaxe atan2(13,300)
> location -300*z
> right image_width/image_height*x
> direction z
> up y
> angle 15
> My exporter:
> camera {
>     stereo distance (???) //It is calculated the exporter or is declared by the
> user?
It's the distance between the eyes.
It's about 13 cm usually, for adult human at least.
I do not know if you have a scale setting for your scene. (something like: 1 pov unit
= x.xxx meter )
>     parallaxe atan2(???,???) //It is calculated the exporter or is declared by
> the user?
If you have a "focus" point, it might help.
Focus point is on the line from 'location', along 'direction'.
Here attached is an illustration of distance and parallaxe.
Value of parallaxe is in radian.
It's the angle away from the direction vector for each pseudo-center for the image of
each eye.
Download 'stereo.png' (59 KB)
Preview of image 'stereo.png'
Date: 4 Apr 2016 06:30:34
Message: <5702424a$1@news.povray.org>
Am 03.04.2016 um 22:41 schrieb Le_Forgeron:
>> user?
@LanuHum: Don't listen to him -- the French are known to be freaks.
Normal people have about half that inter-pupillary distance ;)
Date: 4 Apr 2016 07:41:05
Message: <570252d1$1@news.povray.org>
>>> user?
You are probably correct... I do not know where I picked that 13 cm.
Date: 4 Apr 2016 07:56:29
Message: <5702566d$1@news.povray.org>
>>>> user?
It is the metric system. It can be confusing. ;-)
Regards
Date: 4 Apr 2016 08:05:35
Message: <5702588f$1@news.povray.org>
>>>>> declared by the
>>>>> user?
[making a facepalm]
Yes, especially when you know that that distance is exactly 1 palm. :-)
Date: 4 Apr 2016 08:26:55
Message: <57025d8f$1@news.povray.org>
> [making a facepalm]
It may seem counter-intuitive but because the imperial system is not
regular. More thought was needed and results were passed through a
mental double check. Today youngsters can't count.
Regards
Date: 4 Apr 2016 12:55:01
Message: <web.57029b4e1d798e7f7a3e03fe0@news.povray.org>
unit = x.xxx meter )
> > the user?
of each eye.
I understood that manual input is necessary.
omni_directional_stereo and fisheye_stereographic these parameters require???
Thanks.
Message: <web.57029b871d798e7f7a3e03fe0@news.povray.org>
Thank you!
Date: 4 Apr 2016 13:43:10
Message: <5702a7ae$1@news.povray.org>
>>> the user?
of each eye.
> Thanks.
omni_directional_stereo needs only "distance" (same meaning as for "camera stereo").
fisheye_stereographic is single point of view (blame the historical naming): no stereo
vision there.
(and no "distance" and no "parallaxe"). It's a fisheye, with a specific curve for
mapping.
Date: 4 Apr 2016 15:20:01
Message: <web.5702bd781d798e7f7a3e03fe0@news.povray.org>
In Blender the camera has only the focal length parameter.
Not up, not right, not look_at
Transformations of the camera are defined by object.matrix_world.
Transformations of the all scene objects are defined by object.matrix_world.
Povray camera angle should be calculated on a formula.
There are additional parameters: to see from distance and to distance.
Therefore, the camera of the Blender can look through a wall.
But, for Povray it isn't applicable.
