POV-Ray : Newsgroups : povray.binaries.images : Using media to approximate MegaPov Glows, take 2 Server Time
20 Apr 2026 17:34:02 EDT (-0400)
  Using media to approximate MegaPov Glows, take 2 (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Using media to approximate MegaPov Glows, take 2
Date: 21 Feb 2014 20:34:13
Message: <5307fe95$1@news.povray.org>
>> While I am waiting for the latest iteration of the renders for the
>> macros I am
>> refurbishing now, I decided to dust off an old experiment I did from
>> 2011, that
>> being using media to emulate the Glows in MegaPov.
>> The different methods aren't perfect yet, but they aren't too horrible
>> either.
>> I am making Glow types which are intended to not only emulate, but
>> expand on the
>> initial offerings of MegaPov.
>> I will upload the responsible macros when I polish up the attenuation
>> a bit.
>> Ian
> Why do not use a little trick, put your scene in a big hollow sphere.
> This is the method use for the image which here is the link
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.51cea112203a6891916440570%40news.povray.org%3E/camera1a1.jpg?ttop=391615&toff=150
> Lionel.
  I mean a sphere like this:
	sphere {
		0, 5000
		hollow
		texture {SpherePigment}
		interior {ior Sphere_Ior}
The interior is very important to obtain the glow effect.
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 21 Feb 2014 23:00:00
Message: <web.53081fc6a70b5e4fddb0c31e0@news.povray.org>
> Nice one. Glow was a nice feature. This one could be combined with
> Clipka's Cutoff Distance for Fading Lights which he presented here, a
> couple of weeks ago.
> Thomas
Thanks. :)
Yeah, I loved Glow. The codebase between MP1.2.1 and OEM3.7 was too different,
and I too unfamiliar with either, for re-patching it to be a viable option for
me. I think the falloff model clipka uses is nice and on the money too, and I'll
need to check his code out. He always makes cool stuff. :)
I used the model [much hacked] from the following location for 1/3rd of the test
image shown on the far right of my upload:
http://imdoingitwrong.wordpress.com/2011/01/31/light-attenuation/
http://imdoingitwrong.wordpress.com/2011/04/14/spherical-harmonics-wtf/
http://imdoingitwrong.wordpress.com/2011/02/10/improved-light-attenuation/
> This looks really promising Ian; I love the old MegaPOV glows.
Thank you. :)
I am not sure why, but there was just...something special, I guess, about that
feature. It hit me in the same place that separating the branches and looking
into the lit Christmas tree did when I was about four did.
I actually now decorate my trees now by wrapping lights inside of the tree,
spiraling up to the top, then working my way in layers to the outside, in memory
of the visions from that long lost, ephemeral youth.
> Looks pretty similar to the old glow effect. I have to admit, I also liked
> this feature and think it would be a great addition to the standard version of >
POV.
> Sean
This is indeed my goal, and I am getting closer, as you will see from my
followups. :)
There is so much you can do with Glows, everything from fireflies to the insides
of Christmas lights [well, the old non-LED ones from before Obama made
incandescent bulbs illegal, though in truth I don't know if the scope of that
law covers those]. I dont know why, but for some reason the fact that they
render into the scene vs. being a "post-process" effect attracts me even more.
The only software that I know of that ships with Glows beyond MP is DAZ Carrara,
and they nail the feature. Not sure if they are post-process or not. Rhino
Render has a pathetic facsimile as well, which are post-process. Their effect is
bad and they should feel bad. :p
> Beautiful images! I assume that what I'm seeing is the effect of using
> radiosity (and no light sources.)
> I've never used MegaPOV, so I have a question: How does its implementation of
> this effect differ from 'standard' POV-Ray?
The image structure I used came from an old MegaPov sample scene, used in fact
for the benefit of comparing apples to apples for the greater part, with the
only major difference being my Media Glow implementation, so I cannot truly take
credit for the composition. ;)
Actually, I use both radiosity + emitting media and normal light sources here,
but much of the effect you see is the product of a loop applying a function to a
generated color map. I have to keep the instances of light sources and media to
a minimum or I hit an error with FixedSimpleVector overflows, though if I recall
from my delvings it is less of an error and more of a hard coded limit, like
with blob count. Or I am remembering incorrectly. Or both. Heh.
Normal POV-Ray has no glow function, and due to the issues mentioned above with
source code familiarity, I decided to hack it by using radiosity and media.
> Lionel.
Hello again! I just want to thank you for your Metal and Media texture
contributions [see our e-mail from 11/11/13]. I promise you will see them in
action soon, shortly after I am done with improving my blob placement engine
used in my Snow, Moss and Corrosion macros. :)
The way this macro works is by encapsulating the emitting media in a local
sphere with intervals 2 and samples 10, 100, which avoids some of the issues I
have experienced with global atmospheric media, in terms of undesired
interactions and render time. I will inspect the link you sent further, however.
Do you know if the source for that image is available? There is a smoothness in
the media which may solve or augment some issues I am working on at the moment.
Ian
Date: 23 Feb 2014 13:26:59
Message: <530a3d73@news.povray.org>
> Ian
I post the source in p.t.scene.files, you can study, edit, use it as you
like. I hope it will be usefull for you.
Lionel.
Date: 24 Feb 2014 00:57:15
Message: <530adf3b@news.povray.org>
Again me!
Ok, I have clean up the code and here is an example of the fake glow
(sphere encapsuled in another sphere). Source is in p.t.scene-file under
/fake glow/ subject.
Lionel.
Download 'fake_glow.png' (256 KB)
Preview of image 'fake_glow.png'
Date: 25 Feb 2014 20:20:25
Message: <530d4159@news.povray.org>
> Ian
As the default sampling method for media is method 3, using intervals
with a value larger than 1 have very bad effec on the rendering time.
Also, as the documentation state, "Too many intervals can lead to
artifacts, and POV will create more intervals if it needs them."
The default is 1 and should be left at that.
Also, samples 10, 100 is the same as samples 10. ONLY the first value is
used and the second is silently ignored.
Similarly, ratio, been needed to determine the relative weight of the
intervals, no longer have any object and is not used.
The same apply to confidance and variance as they are used to decide if
you need more samples for an interval or not.
The default values are:
method 3
samples 10
intervals 1
variance is NOT used
confidance is NOT used
ratio is NOT used
Date: 26 Feb 2014 00:40:01
Message: <web.530d7d52a70b5e4fc2d977c20@news.povray.org>
> method 3
> samples 10
> intervals 1
> ratio is NOT used
I've been wondering about the usefulness of variance/confidence/ratio for a long
time (re: method 3). I came to the same conclusions, after a lot of testing and
head-scratching. It's nice to see the info clearly stated. :-)
Date: 26 Feb 2014 18:15:01
Message: <web.530e7526a70b5e4fddb0c31e0@news.povray.org>
> method 3
> samples 10
> intervals 1
> ratio is NOT used
> Alain
That is a lot of info that I did not know, there; thank you! :)
I am using method 2 exclusively, but now that I know the second number is
pointless, I'll remove it for cleanliness. I do not use variance, confidence or
ratio either. :)
Ian
Date: 26 Feb 2014 18:20:00
Message: <web.530e7577a70b5e4fddb0c31e0@news.povray.org>
FractRacer <lg.### [at] gmailcom> wrote:
> Again me!
> Lionel.
Thanks! :)
The effects you have there look pretty sweet too. :)
Ian
Date: 28 Feb 2014 19:57:55
Message: <53113093@news.povray.org>
>> method 3
>> samples 10
>> intervals 1
>> ratio is NOT used
>> Alain
> ratio either. :)
> Ian
When using method 2, you NEED to provide intervals, variance, confidance
and ratio, or rely on the default values. Also, you should use samples
min_samples, max_samples.
Date: 1 Mar 2014 02:55:00
Message: <web.531191c0a70b5e4fddb0c31e0@news.povray.org>
That is pretty much what I have going on, save for variance, confidence and
ratio. I do not really know the details of cause and effect well enough to mess
with them, and I am extremely close to my goal of replicating MP Glows [types 1
and 2] now. I have a total of 11 Glow types at this point, and they are all
distinct enough where it isn't easy to confuse them.
One thing I tried was converting the C code from the Glow patch to SDL, as much
as was possible. I spent an hour or so doing that, but it was cumbersome because
it required parameters that I know of no way to access in SDL, such as ray
origin and various extents. I did this back in my first stab a few years ago;
perhaps I'll look at this again with an eye towards simply extracting the
falloff expressions.
One outlier is attached...I have no idea what is up with this odd cube
artifact... It almost looks like bounding boxes, but I wouldn't put money on
that being what it is. I replicated this accident once through overlapping media
containers and looks_like [quickly fixed through consolidation], but such is not
the case in this instance. This is the shabbiest example of what I have
accomplished toward my goal, by the way.
Once I am happy with the 11 types, I will consolidate the SDL to remove
duplicate code across types, remove anything that ends up being too close to
anything else, and to minimize light sources.
The FixedSimpleVector exceptions I was getting are gone now through prior
consolidation efforts, but I have not yet established a comparison of max glows
between MP and the media variant. Obviously the media implementation is slower
to varying degrees according to type.
Thanks for the tips man! :)
Ian
Download 'mediaglow 2014_0_2_.png' (258 KB)
Preview of image 'mediaglow 2014_0_2_.png'
