POV-Ray : Newsgroups : povray.binaries.images : MATCHMOVING in POV-ray Server Time
6 May 2026 17:40:46 EDT (-0400)
  MATCHMOVING in POV-ray (Message 11 to 20 of 35)
Subject: Re: MATCHMOVING in POV-ray
Date: 14 Feb 2014 13:21:34
Message: <52fe5eae$1@news.povray.org>
On 14/02/2014 6:20 PM, Stephen wrote:
> On 14/02/2014 5:02 PM, Kenneth wrote:
>> I
>> don't*think*  a sky_sphere can be made no_image (?). But I could be
>> wrong about
>> that.
> You could always use a large sphere with a spherical projection and the
> no image flag.
Oh! Very nice work. I forgot to say.
Regards
Date: 14 Feb 2014 13:25:00
Message: <web.52fe5e9cd1c8d4af192ae5f10@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
>  The problem with using a sky_sphere is that my
> police car renders need a transparent background (for compositing later); I
> don't *think* a sky_sphere can be made no_image (?). But I could be wrong about
> that.
No, you are not wrong.  Luckily, POV-Ray has a built-in sphere primitive.  :-)
__________________________________________________
//+ua
#version 3.7;
#include "skies.inc"
sphere
{ 0, 1
 //Substitute your image map
  texture
  { pigment
    { gradient y color_map
      { [0 rgb <0.4, 0.6, 1.0>]
        [1 rgb <0.10, 0.15, 0.30>]
    finish { ambient 0 diffuse 0 emission 1 }
  texture { T_Cloud1 scale 0.1 }
  scale 10000
  hollow
  no_image
light_source
{ <-1, 1, -1> * 5000, rgb <1.4716, 1.0775, 0.6379>
  parallel point_at 0
camera
{ location <0, 0.75, -5>
  look_at <0, 1, 0>
  angle 40
plane { y, 0 pigment { checker rgb 0.05 rgb 1 } }
sphere
{ y, 1
  pigment { rgb <0.61, 0.61, 0.64> }
  finish
  { reflection { 1 metallic }
    ambient 0 diffuse 0
    specular albedo 1 metallic roughness 0.0001
Download 'kenneth-alpha_sky.png' (53 KB)
Preview of image 'kenneth-alpha_sky.png'
Date: 14 Feb 2014 15:15:00
Message: <web.52fe7811d1c8d4afc2d977c20@news.povray.org>
> > no image flag.
Yeah, that's what I'm doing now.
What I *really* need to do-- for this project and others-- is to buy a shiny
sphere, for making a 'light probe' (a non-HDRI version, as my little Canon video
camera doesn't shoot HDRI/'raw' images, unfortunately.) Then I could photograph
the surrounding 'environment' in just a single image (or two? I'm still not sure
of how light probes are made) and map that to the large no_image sphere. In the
past, I've simply stitched lots of 'normal' photos together, to get a
quasi-360-degree image for reflections. What a pain.
Many thanks!
Date: 14 Feb 2014 15:30:00
Message: <web.52fe7bc4d1c8d4afc2d977c20@news.povray.org>
Of course, there's the alternate trick of making, say, five bracketed exposures
of the mirrored sphere with my 'regular' camera, and then combining those in
specialized software to make an HDRI image. But I haven't gotten into the HDRI
world yet, sad to say. "So little time, so MUCH to learn." ;-)
Date: 14 Feb 2014 17:35:01
Message: <web.52fe99e2d1c8d4af91114470@news.povray.org>
This is pretty cool!
I have a 5 inch chrome sphere that I use for that very purpose (plus it looks
cool on my desk when not in use). Mount your camera on a tripod and take a set
of bracketed shots, then rotate the tripod ~90 degrees around the sphere and
take another set of bracketed shots. After you've combined the two bracketed
imagesets into 2 HDRs you can merge these offset images to eliminate the
camera/tripod completely from the final shot. Of course, Ive's IC is very useful
here:
http://www.lilysoft.org/IC/ic_index.htm
www.McGregorFineArt.com
Date: 14 Feb 2014 18:49:23
Message: <52feab83$1@news.povray.org>
I don't think that any camera can take HDR images natively.
For combining the bracketed images, there is hdrshop. A nice little
utility just for that purpose. It can also transform a reflective sphere
probe to a latitude-longitude one that you can then apply to a large
sphere or sky_sphere using the spherical mapping.
Date: 15 Feb 2014 04:50:47
Message: <52ff3877$1@news.povray.org>
On 14/02/2014 8:26 PM, Kenneth wrote:
> "So little time, so MUCH to learn.";-)
Seconded. :-)
Regards
Date: 15 Feb 2014 11:30:37
Message: <52ff962d@news.povray.org>
http://news.povray.org/povray.binaries.images/message/%3Cweb.44468657f8d220636c4803960%40news.povray.org%3E/#%3Cweb.44468657f8d220636c4803960%40news.povray.org%3E
   IIRC, that worked nicely, and additionally you have the fun of doing
it with POV-Ray... :)
Jaime
Date: 15 Feb 2014 19:10:00
Message: <web.530000cdd1c8d4afc2d977c20@news.povray.org>
That is fascinating!!  Thanks for posting the link; I had not seen it before. I
can certainly make use of Trevor's sophisticated code ideas: Awhile ago, I tried
writing some similar (though inferior) code to do this kind of 'HDRI conversion
in POV-Ray', but got rather bland results. I see now what I was doing wrong.
Thanks! (And to Trevor too!)
Date: 15 Feb 2014 19:30:00
Message: <web.53000574d1c8d4afc2d977c20@news.povray.org>
> here:
So the 90-degree image is simply to get a clean area to 'replace' the
camera-plus-photographer in the original straight-on image? That makes perfect
sense. Here's a question, though: Is the *final* light probe ultimately made
from BOTH of those images? (Meaning: Is the 'corrected' straight-on image
somehow combined WITH the (similarly-corrected) 90-degree image to get a light
probe that has MORE environment imagery in it? Or is only the straight-on image
used?)
There's also something *mysterious* about light probes that I still have trouble
grasping: In my research into the subject, several sources stated that the
mirrored ball actually gathers environment imagery from BEHIND itself-- in the
spatial hemisphere out of view of the camera(!)-- implying that the very edges
of the ball pick up the 'hidden' back-side environment. Is that true (or even
possible?)
