POV-Ray : Newsgroups : povray.binaries.images : A method creat uniform thick shell Server Time
19 Mar 2026 18:34:16 EDT (-0400)
  A method creat uniform thick shell (Message 21 to 30 of 45)
Subject: Re: A method creat uniform thick shell
Date: 23 Jul 2018 08:00:01
Message: <web.5b55c221dce0719ae897ce530@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> >> Never mind. I figured it out.
> >> Mike
> > Is it ok?
> Yes, it works well!
> The routine would be very helpful in this object collection:
http://lib.povray.org/searchcollection/index2.php?objectName=ShapeGrid&version=1.11&contributorTag=SharkD
> Would it be okay if I added it there? The license for the collection is
> CC-LGPL.
> Thanks!
> Mike
I saw your links and not very understand what is that object function. Can you
describe?
Date: 23 Jul 2018 19:16:42
Message: <5b5661da$1@news.povray.org>
> describe?
Normally, a person might create internal lines of latitude and longitude
on a sphere by drawing one outer shape and then simply scaling it
smaller as you go deeper inside the sphere. The macros I linked to
ensure that the *lines* are always the same thickness, throughout the
entire object.
An offset surface such as what is generated by your macro is ideal for
this purpose, when it's not possible to use regular CSG objects to
accomplish the same. (Isosurfaces are kind of slow.)
Mike
Date: 24 Jul 2018 08:25:00
Message: <web.5b571a06dce0719ae897ce530@news.povray.org>
> > describe?
> entire object.
> Mike
Well, I permit you to release it on CC-LGPL. But my macro is still far from what
you want I think
Date: 24 Jul 2018 08:40:00
Message: <web.5b571d64dce0719ae897ce530@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> I have written a macro which uses above technique to make an isosurface thin
> shell. I post it below. But I found that it is only for a small thickness or it
> don't have a constant thickness result. Furthermore, for many functions its
> result is not expect.
> So, don't take too much expect with it.
> //-------------------macro-----------------------------
> #macro Shape_ThinShellOf3DFunction(input_function, _min_extent, _max_extent,
> _thickness, _max_gradient)
> #local CSG_OVERLAP=0.001;
> #local h=0.00001;
> #local normalized_function =
> function(var1,var2,var3)
> input_function(var1,var2,var3)
> /sqrt(
> pow((input_function(var1+h,var2,var3)-input_function(var1,var2,var3))/h,2)
> +pow((input_function(var1,var2+h,var3)-input_function(var1,var2,var3))/h,2)
> +pow((input_function(var1,var2,var3+h)-input_function(var1,var2,var3))/h,2)
> difference{
> isosurface{
> function{normalized_function(x,y,z)-_thickness/2}
> max_gradient _max_gradient
> contained_by{box{_min_extent,_max_extent}}
> all_intersections
> isosurface{
> function{normalized_function(x,y,z)+_thickness/2}
contained_by{box{_min_extent-<CSG_OVERLAP,CSG_OVERLAP,CSG_OVERLAP>,_max_extent+<CSG_OVERLAP,CSG_OVERLAP,CSG_OVERLAP>}
> all_intersections
> #end
> //---------------------Here is a good look example------
> #declare f_noise3d = function { internal(76) }
> #declare f_test=
> function(x,y,z){
> x*x+y*y+z*z-1- 0.5*f_noise3d(x/0.3,y/0.3,z/0.3)
> difference{
> Shape_ThinShellOf3DFunction(f_test, <-1.3,-1.3,0>, <1.3,1.3,1.3>, 0.04, 10)
> box{<-1.5,-1.5,-0.1>,<1.5,0,1.5>}
> texture{
>     pigment{rgb<1,1,1>}
>     finish{
>         ambient 0.1
>         diffuse 0.6
Use the macro. and input function below
#declare f_parabola=function(x,y,a){
y-a*x*x
#declare f_curve = function(x,y) {
pow(f_parabola(x,y,1), 2) + 0.2*y*y - 0.02
#declare f_circle = function(x,y) {
x*x + y*y - 0.5*0.5
#declare h = 0.5;
#declare f_test=
function(x,y,z){
(z/h)*f_curve(x,y) + (1-z/h)*f_circle(x,y) - 0.2*f_noise3d(x/0.2,y/0.2,z/0.2)
object{
Shape_ThinShellOf3DFunction(f_test, <-1.4,-1.3,0>, <1.4,1.4,0.5>, 0.024, 10)
texture{
    pigment{rgbt<0.014,0.011,0.007, 0.9>}
    finish{
        ambient 0.0
        diffuse 1.0
        reflection {0.01, 0.89 fresnel}conserve_energy
interior{
    ior 1.46
    fade_colour rgb<0.6, 0.4, 0.3>
    fade_distance 2.6
    fade_power 1001
no_radiosity
Download 'scene glass.png' (104 KB)
Preview of image 'scene glass.png'
Date: 25 Jul 2018 02:54:25
Message: <5b581ea1$1@news.povray.org>
And wrote on 24/07/2018 14:36:
Nice effect.
Now, I'm curious to see the jar filled of water.
Paolo
Date: 25 Jul 2018 05:30:01
Message: <web.5b584307dce0719a5341e80e0@news.povray.org>
> Nice effect.
> Paolo
The rendering is very slow. I 'd rather sculpt one using mesh than using this
method.
Date: 25 Jul 2018 07:02:23
Message: <5b5858bf$1@news.povray.org>
I like it very much. As always, I shall note down the macro for future
reference/use.
Date: 25 Jul 2018 08:20:00
Message: <web.5b586a43dce0719a5341e80e0@news.povray.org>
> reference/use.
> Thomas
Oh, it's nice
Date: 28 Jul 2018 09:48:22
Message: <5b5c7426$1@news.povray.org>
I am trying to do the same, but am having trouble toning down the
reflections. I can barely see through the glass, and the finish is
reflecting too much and too brightly.
Mike
Download 'offset_surface_save_01.png' (229 KB) Download 'utf-8' (4 KB)
Preview of image 'offset_surface_save_01.png'
Date: 28 Jul 2018 09:53:08
Message: <5b5c7544@news.povray.org>
> Mike
just a guess .. diffuse and / or reflection too high
