POV-Ray : Newsgroups : povray.binaries.images : 2,296 grains Server Time
18 Mar 2026 15:52:17 EDT (-0400)
  2,296 grains (Message 21 to 30 of 30)
Subject: Re: 2,296 grains
Date: 7 Apr 2011 19:51:09
Message: <4d9e4ded@news.povray.org>
On 4/4/2011 1:57 PM, Trevor G Quayle wrote:
> One interesting tidbit I had found about the Voronoi digrams when I had looked
> at them a few years ago, is that they can be defined by projecting each point
> vertically to a hyperboloid and defining a plane tangent to the hyperboloid at
> this point.  The voronoi diagram of a set consists of the intersections of these
> planes.
I've read about using /parabolas/ (Fortune's algo) for the creation
Voronoi cells, but am at a total loss about how to go about it. Your
description seems clearer than Wikipedia's and Wolfram's. (did you  mean
parabolas, not hyperboloids?)
There's also the problem of using binary search trees. I haven't even
tried to develop one yet, but like quad/octrees, their creation appears
to be a very difficult undertaking. Maybe it's my frame of reference
(POV) that is giving me trouble, or my total lack of formal math
training. One of these days I'm going to need to have an understanding
of such structures (if I ever expect to finish a video game :D).
Sam
Date: 7 Apr 2011 19:57:38
Message: <4d9e4f72$1@news.povray.org>
On 4/5/2011 1:14 PM, Stephen wrote:
> On 05/04/2011 9:11 PM, Christian Froeschlin wrote:
>> It wasn't a criticism, I was just frustrated that even
>> your test objects look better than what I get if I try
>> to render a stone ;)
> LOL I know what you mean. ;-)
You guys need to be less self-critical! (a critical statement if I ever
heard one ;) )
You've got to understand that 90% of my consciousness is taken up with
computer graphics-related ideas... It's makes it very difficult to live
like a normal person. My mind is uncontrollably expanding in all
directions, so I've got to direct into good paths. POV-Ray helps me to
do that :)
Sam
Date: 7 Apr 2011 20:00:56
Message: <4d9e5038$1@news.povray.org>
On 4/7/2011 4:57 PM, stbenge wrote:
> "It's makes"
^See what I mean? :(
Date: 7 Apr 2011 20:50:01
Message: <web.4d9e5b776e76f0aab05ef170@news.povray.org>
> > planes.
> Sam
Sorry, perhaps it was paraboloid, it's been a while and I didn't look it up
first...
Odd , I can't find anything that relates the relationship so simply anymore at
present.  As you said, all the descriptions seem very complex to parse and
figure out the exact meaning.
The way I had understood it simply is to project the x-z plane point vertically
(y axis) onto the paraboloid and make a plane tangent to the paraboloid at that
point.  The voronoi digram for a given set of points will be represented by the
intersections of all the planes for that set.  I actually had set up some simple
mathematics to calculate this and display as a graph in excel at the time and it
seemed to work.
An interseting approach in POV would be to construct it directly in POV.  You
could take an array of each point and calculate the tangent plane for each
point, then create it as a plane object.  Give each plane a slightly different
colour value then do a simple intersection operation and view using orthographic
camera.  Using direct RGB values, you could theoretically create one for up to
16,777,216 (256^3) points (could probably do higher with HDR file type).  Of
course this would be only valid for a 2D set, and I'm not sure how render time
would be...  Perhaps it's time to test this out.
-tgq
Date: 7 Apr 2011 21:18:29
Message: <4d9e6265@news.povray.org>
>>> planes.
>> Sam
> first...
Yeah. Authors of such articles seem to only touch upon construction
methods... What is the parabola exactly? A dense point curve or a pure
function?
> seemed to work.
Wow, Excel uses Visual Basic, right? How did you view it? I always
thought Excel's VB support was crudimentary, at best.
Dude, if you can do /that/, then you've made a full-POV-SDL
implementation of Voronoi cell computation. It may not be the fastest
way to go about it, but it's a step in the right direction.
I hope that one day POV-Ray will have some native method for computing a
point set's nearest neighbors. Some fast core routine where the original
authors gladly let their code fall under the new license. POV's use as a
scientific visualization tool would surely increase...
~Sam
Date: 7 Apr 2011 21:45:00
Message: <web.4d9e67ec6e76f0aab05ef170@news.povray.org>
> > first...
> function?
Pure function: f(y)= x^2 + z^2
> > seemed to work.
No, I did it the difficult way: direct calculation of intersectiong lines then
intersecting points, then used the general x-y graphing to display it.  A lot of
maths, that's why I only did it for a few points (3 or 4 I think it was)
It is only for a 2D array...  The easiest way would be to get an image based on
it, from there it would be trying to convert that directly to a function or some
way to evaluate directly.
-tgq
Date: 8 Apr 2011 04:18:38
Message: <4d9ec4de@news.povray.org>
the troll king said. :-)
doubts, it is a tool for improvement.
(My tuppence worth)
> heard one ;) )
LOL
Time, is a thing that improves graphisc.
> do that :)
Personally, I find that PovRay helps to keep my mind flexible.
Regards
Date: 8 Apr 2011 10:00:01
Message: <web.4d9f13bf6e76f0aa81c811d20@news.povray.org>
> > > first...
> > function?
> > > seemed to work.
> -tgq
Very simple demonstration of this concept.
-tgq
//START
  orthographic
  location <0, 3.5, 0>
  look_at <0, 0, 0>
  right x*1.2
  up y*1.2
#declare C=0.001;//Flattens out paraboloid for viewing
#declare NumP=16;
#declare RS=seed(1);
#declare PT=array[NumP];
#for (i,0,NumP-1)//Pick random points <0,0,0>-<1,0,1>
  #declare PT[i]=<rand(RS),0,rand(RS)>;
union{
  #for (i,0,NumP-1)
    #declare xx=PT[i].x;
    #declare zz=PT[i].z;
    #declare V3=<-2*xx*C,1,-2*zz*C>*(pow(xx,2)+pow(zz,2))*C; //Paraboloid
surface normal at projected point
    plane{V3,0 //plane oriented to normal
      pigment{rgb i/NumP} //color by index
      finish{ambient 0 emission 1 diffuse 0}
      translate <xx,(xx*xx+zz*zz)*C,zz> //  translate to projected point on
paraboloid
    cylinder{0,y*(xx*xx+zz*zz)*C*1.1,0.01 //draw point
      pigment{rgb <1,0,0>}
      translate <xx,0,zz>
  translate <-0.5,0,-0.5>
//END
Download 'voron.png' (17 KB)
Preview of image 'voron.png'
Date: 9 Apr 2011 18:52:41
Message: <4da0e339$1@news.povray.org>
Very interesting. I wonder how difficult it would be to make a list of
every point's nearest neighbors...
Date: 9 Apr 2011 20:10:03
Message: <web.4da0f5066e76f0aab05ef170@news.povray.org>
I don't know.
One thing that is certain is that for the object created, every cell will have a
unique normal that can be traced and they will be ordered in the sense that
adjacent cells will have the nearest normals.
-tgq
