POV-Ray : Newsgroups : povray.binaries.images : Another ringworld revisitation Server Time
16 Mar 2026 17:18:42 EDT (-0400)
  Another ringworld revisitation (Message 1 to 5 of 5)
Subject: Another ringworld revisitation
Date: 21 Jun 2010 17:10:01
Message: <web.4c1fd41611a7b4754f28787e0@news.povray.org>
Here's an interactive VR of my ringworld, to counterpoint Thomas' recent
efforts. (Not technically a binary post but anyway).
http://www.infradead.org/~wmp/vr_povray/ringworld01.mov
I actually had to cheat with the sun as well as the sky in the end. It appears
I'm still suffering with some precision issues. Although the shadow squares are
fine, apparently something a million units across but 90 million units away from
the camera doesn't show up. Moving it closer does make it show up, so I'm using
a fake sun-and-shadow-squares union, a mere million units away and scaled
proportionally. The shadows are cast by the actual shadow squares, which have
no_image set. The result should be indistinguishable from the real(!) thing.
I need to play with the landscape some more now, brighten the arch, etc, etc...
Bill
Subject: Re: Another ringworld revisitation
Date: 21 Jun 2010 20:20:36
Message: <4c2001d4$1@news.povray.org>
> Bill
Oh, God, please don't make me install Quicktime and all the other Apple
junkware..
http://isometricland.com
Date: 22 Jun 2010 03:55:01
Message: <web.4c206b5651f7de26dd25f0b0@news.povray.org>
> junkware..
I'm pretty sure you only need quicktime. However, if you know another 100% free
way to encode interactive VR I'll be happy to supply alternatives! Is yours
flash? What did you use to create it?
Date: 22 Jun 2010 05:10:29
Message: <4c207e05$1@news.povray.org>
Impressive indeed!
I have a couple of comments though:
I am not too convinced about the view of the sun and shadow squares. The
glare of the sun should overs-shine the squares and make them invisible I
guess during day time. Also I wonder if the ring at zenith would be visible
in that glare.
It now appears as if the sun is much larger than the shadow squares. If this
were so, there would be no nights at all. In reality (?) the squares are the
size of the sun's diameter. However, I assume that it is the glare we are
seeing?
Date: 22 Jun 2010 05:35:01
Message: <web.4c2082ca51f7de26dd25f0b0@news.povray.org>
> Impressive indeed!
Isn't it? I was pleased with this.
> in that glare.
You are right, of course, I was taking severe artistic license in this matter!
Of course the glare would make the shadow squares all but invisible - however,
it is likely that they would be partly visible during twighlight, and probably
very obvious at night, when they also occlude parts of the arch. I think the
nature of their world would be more apparent to the natives than Niven thinks...
> seeing?
Yes, this was an attempt to depict glare. What I really need to do is make the
glare larger, the sun's disc smaller, and use some kind of colour bleeding to
produce a more (photo)realistic effect. I think it is time to investigate Sam's
macros... :)
I have seen variable-exposure hdr panoramas on photography sites - perhaps I
should also investigate this... I expect the tools required are expensive :(
