POV-Ray : Newsgroups : povray.binaries.images : Rendering issues Server Time
15 Nov 2024 18:21:18 EST (-0500)
  Rendering issues (Message 1 to 10 of 14)
Subject: Rendering issues
Date: 12 Jan 2008 16:00:01
Message: <web.478929dc8a37fce37bcf5ca50@news.povray.org>
I'm trying to make a room with stucco by subtracting out isosurfaces. As you can
see in this test render, in the room where the camera is located the stucco
renderes as it should. However, the arrows pointing toward the archway show an
area that is subtracted out but is rendering in all black. Anyone encounter
this before with a solution?
Download 'error.jpg' (20 KB)
Preview of image 'error.jpg'
Subject: Re: Rendering issues
Date: 12 Jan 2008 18:07:13
Message: <47894821$1@news.povray.org>
I'm sure you have your reasons for making an entire house from
isosurfaces! I'd like to see how this turns out :)
Could you show us your code, so we can pin down the cause of the black
areas? The solution could be a simple thing, such as raising the
max_gradient.
Sam
Date: 12 Jan 2008 18:30:00
Message: <web.47894c446c6c555f7bcf5ca50@news.povray.org>
Here's the relevant code with comments. It's basically a box differenced with
other objects and isosurfaces.
  light_source{
    <0,1,0>
    White
    location <0,1.75,0>
    look_at  <0,1.75,10>
    rotate y*-12
    translate <1.75,0,-3>
    right <450/300,0,0>
#declare fn_Pigm=function {
    agate
    color_map {
      [0 color rgb 0]
      [1 color rgb 1]
  difference{
    box{<-200,-1,-100>, <200,200,7.5>}  //the main room
    // the +z room with window
    union{
      box{<-2.5,-.001,2>, <2.5,10,6>}
      difference{ //makes the hole for the door on the +z side of the room
        #declare R=5;
        #declare H=3;
        cylinder{<0,0,5.9>, <0,0,10>, R}
        box{<-100, -100, -100>, <-1.25,100, 100>}
        box{<1.25, -100, -100>, <100,100, 100>}
        box{<-100,-100,-100>, <100, 5-H,100>}
        translate y*-R
        translate y*H
    //the camera room
    box{<-2.5,-.001,-9>, <5,6.0001,1.5>} // room with camera
    difference{//makes archway to connect camera room with +z room
      cylinder{<0,0,.9>, <0,0,2.1>, 2.5 translate y*1.25}
      box{<-100, -100, -100>, <100,-.0001,100>}
    isosurface{//makes the camera room have stucco
      function{(y*y+x*x-2.5*2.5)-fn_Pigm(x*2, y*2, z*2).gray*0.1}
      accuracy 0.0001
      max_gradient 9
      contained_by {box {<-10,-10,.9> <10,10,2.5>}}
      translate <0,1.25,0>
      pigment{White}
      function{max((y*y-(3*3)),(x*x-(3.75*3.75)),(z*z-(5.25*5.25)))-fn_Pigm(x*2,
y*2, z*2).gray*0.1}
      accuracy 0.0001
      max_gradient 20
      contained_by {box {-20 20}}
      pigment{White}
      translate <3.75-2.5,3.05,-(5.25-1.5)>
    //the -x room
    box{<-2.49999,-.001,-9>, <2.49999,6.0001,1.5> translate x*(-5.5)}
    difference{//make the archway connecting the camera room to the -x room
      cylinder{<-5,0,0>, <-2.4,0,0>, 2.5 translate <0,1.25,-1>}
    pigment{White}
Date: 12 Jan 2008 22:30:00
Message: <web.4789856e6c6c555f369a31370@news.povray.org>
I can't help but ask why, why not simply normals?  it's not even a close up...
there's enough issues with coincident surfaces in plain CSG, put isosurfaces to
the mix and you're asking for trouble...
Date: 13 Jan 2008 00:55:00
Message: <web.4789a6b16c6c555f7bcf5ca50@news.povray.org>
I was intending to use isosurfaces because they should blend in better,
especially under the arch. With normals (procedural or bump_maps) there's still
a sharp demarcation between the wall and the arch.
Date: 13 Jan 2008 02:20:11
Message: <4789bbab@news.povray.org>
apply the textures after the transformations.
Date: 13 Jan 2008 02:42:04
Message: <4789c0cc@news.povray.org>
jhu napsal(a):
once I had this problem with coincident surfaces. But I can't see any in
your code.
Date: 13 Jan 2008 03:06:56
Message: <4789c6a0@news.povray.org>
> you can
> stucco
> show an
> encounter
Sometimes isosurfaces do that when they are used in
differences. Fortunately you can just put the differences
into the formulas for the isosurfaces...
global_settings {
   assumed_gamma 1
background{White}
light_source {
   <0,1,0>, color <1,0.9,0.7>
   fade_distance 2
   fade_power 2
light_source {
   <0,2.5,10>, White*0.1
   shadowless
   location <0,1.75,0>
   right <450/300,0,0>
   look_at  <0,1.75,10>
   rotate y*-12
    agate
    color_map {
      [0 color rgb 0]
      [1 color rgb 1]
#declare useIso = true;
union {
   // floor
   box { <-200,-100,-100>, <200,0,7.5>
         pigment {Brown}
         finish {
            specular 0.8
            roughness 0.05
            reflection 0.1
   // ceiling
   box { <-200,10,-100>, <200,200,7.5>
   // near wall with arch
#if (useIso)
   isosurface {
      function { max( (abs(z)-0.25),
                      -min( max( (abs(x)-2.5),
                                 (abs(y+2.5)-2.5)),
                            (sqrt(pow(x,2) + pow(y,2)) - 2.5)
                 +fn_Pigm(x*2, y*2, z*2).gray*0.01 // texture
      accuracy 0.001
      max_gradient 1.43
      contained_by {box {<-20,-10,-2>,<20,10,2>} }
      translate <0,1.25,1.75>
#else
   difference {
      box { <-200,-10,1.5>,<200,10,2>}
      cylinder{<0,1.25,0.9>, <0,1.25,2.1>, 2.5}
      box {<-2.5,-10,0.9>,<2.5,1.25,2.1>}
   // left wall with arch
#if (useIso)
   isosurface {
      function { max( (abs(x)-0.25),
                      -min( max( (abs(z)-2.5),
                                 (abs(y+2.5)-2.5)
                            (sqrt(pow(z,2)+pow(y,2))-2.5)
      accuracy 0.001
      max_gradient 1.43
      contained_by {box {<-1,-10,-20>,<1,10,7.5>} }
      translate <-2.75,1.25,-1>
#else
   difference {
      box { <-2.5,-10,-200>,<-3,10,7.5>}
   // right wall
#if (useIso)
   isosurface {
      function { (abs(x)-0.25)
      accuracy 0.001
      max_gradient 1.43
      contained_by {box {<-1,-10,2>,<1,10,7.5>} }
      translate <2.75,0,0>
#else
   box { <2.5,-10,2>,<3,10,7.5>
   //far wall with door
#if (useIso)
   isosurface {
      function { max(
                    (abs(z)-0.5),
                    -max(
                        (sqrt(pow(x,2) + pow(y+2,2)) - 5),
                        (abs(x)-1.25)
      accuracy 0.001
      max_gradient 1.43
      contained_by {box {<-20,-10,-1>,<20,10,1>} }
      translate <0,0,7>
#else
   difference {
      box { <-200,-10,6>,<200,10,7.5>}
      //door
      difference {
         box {<-1.25,-200,5.9>,<1.25,5,10>}
         cylinder {<0,-2,5.9>, <0,-2,10>, 5 inverse}
      pigment {White}
      finish {
         specular 0.4
         roughness 0.05
Download 'iso_room.jpg' (39 KB)
Preview of image 'iso_room.jpg'
Date: 13 Jan 2008 03:08:31
Message: <4789c6ff@news.povray.org>
jhu napsal(a):
>   light_source{
>     <0,1,0>
>     White
>   camera {
>     location <0,1.75,0>
>     look_at  <0,1.75,10>
>     rotate y*-12
>     right <450/300,0,0>
>   pigment {
>     agate
>     color_map {
>       [0 color rgb 0]
>       [1 color rgb 1]
>   difference{
>     union{
>         #declare R=5;
>         #declare H=3;
>         translate y*-R
>         translate y*H
>     //the camera room
>       accuracy 0.0001
>       max_gradient 9
>       pigment{White}
> y*2, z*2).gray*0.1}
>       accuracy 0.0001
>       max_gradient 20
>       pigment{White}
>     //the -x room
>     pigment{White}
Hello again,
when I removed the stuccos the problem disappeared.
Date: 13 Jan 2008 11:00:00
Message: <web.478a35636c6c555f7bcf5ca50@news.povray.org>
Wow! Thanks for the help and tips. That's some serious isosurface-kung-fu there.
"Tim Attwood" <tim### [at] comcastnet> wrote:
