POV-Ray : Newsgroups : povray.binaries.images : Indoor Lighting with Radiosity (Bath) Server Time
20 Feb 2025 14:11:00 EST (-0500)
  Indoor Lighting with Radiosity (Bath) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Indoor Lighting with Radiosity (Bath)
Date: 27 Nov 2006 09:20:37
Message: <456af435$1@news.povray.org>
Nice - what did you use for the toilet & taps etc?
Depressingly good modelling and a successful lighting test.
There's still something a little cg about this image though and I'm not
sure if it's the lighting or textures looking a little too "clean" or
just the perfectly straight lines on the tiles that are ever so slightly
aliased. (that said a photo of that much perfect tiling might look cg
anyway :-)
Date: 30 Nov 2006 05:05:00
Message: <web.456eacaa3e8ef57cd8ef73430@news.povray.org>
All objects are made in AutoCAD, imported to the application I use (owner
application which can import AutoCAD models, render in OpenGL and add
lights and radiosity parameters, then export to .pov, .inc)
> anyway :-)
I'm trying to improve my lighting techniques with key/fill lights and/or
radiosity, also trying to learn the correct parameters for materials
(reflection, refraction, etc..).
The only way I get good antialias is rendering a big image (>3000 pix
weight) and after resize. I always use just +a0.1, because other options
like +a0.1 +am2 +r7 +j takes too long to render and no improvement is
obtained.
Thanks for all comments,
JSR.
Date: 30 Nov 2006 07:15:01
Message: <web.456ec9ff3e8ef57cc0bad8570@news.povray.org>
"JSR" <jsr### [at] gmailcom> wrote:
> Hi,
> This is my last render trying to improve indoor lighting and radiosity.
> The main parameters used in this scene are:
>  Resolution: 1800x1200 (resized to 800x533)
>  Antialias: +a0.1
>  Lights: 3 spot_light area_light 5x5, 1 point_light (fill light)
> Radiosity:
>  count 50
>  error_bound 0.5
>  rec.lim. 1
> (I've used low values for radiosity parameters in order
>  to improve the render time)
> Render time: 2h30m
> CPU: 3.4GHz, 1GB RAM
> Comments? :)
> JSR
Hi JSR,
   Wow, I'm commenting on two bathroom images in the same week :-) I think
the modeling is exceptional, and you're doing well. Nice use of the towel
and soap bottle. I'd love to see more of those little touches.
The lighting could use some warming up, in my opinion
(same thing I saw with the other bathroom image). I'd recommend checking
out Jaime Vives Piqueres' excellent, and free LightSys at
http://www.ignorancia.org/en/index.php?page=Lightsys
Speaking of towels, Jaime also has some VERY interesting cloth renders on
his homepage :-)
Rock on,
George
Kick your render speed into high gear with MegaPOV XRS:
http://www.gammaburst.net/xrs
Date: 30 Nov 2006 14:37:32
Message: <456f32fc@news.povray.org>
Hash: SHA1
> obtained.
	And with +a0.1 +am2 +r1 ? This should be faster than just +a0.1
with no quality loss (note that +am2 +r7 may take up to 1849 times
more samples than if you specify neither +am nor +r !! no wonder you
find it slow)
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD8DBQFFbzMdd0kWM4JG3k8RAoI+AJ0aP9mL8z9J1kE3ROAkARZRXc8fsACfZThY
AbNsFTivilfLjauRVDZMngg=
=tnwo
-----END PGP SIGNATURE-----
Date: 30 Nov 2006 21:59:45
Message: <456f9aa1$1@news.povray.org>
JSR nous apporta ses lumieres en ce 30/11/2006 05:04:
> Hi,
>> anyway :-)
> obtained.
> JSR.
+r7? That's 7 level of recursion. Exept in some very special cases, it don't
improve anything. The default recursion level of 3 is usualy suficient. If not
suficient, you can go up to 4, or 5 if you are VERY picky and pacient.
If Barbie is so popular, why do you have to buy her friends?
Date: 1 Dec 2006 09:55:00
Message: <web.457040ad3e8ef57cd8ef73430@news.povray.org>
I think that LightSys (from Jaime Vives Piqueres) is a very good tool, but
at the moment I prefer to use my own light setup in the scenes, in order to
understand the parameters and their behaviour.
The antialias parameter: +a0.1 +am2 +r1 is faster than just +a0.1 and the
result has the same quality, thanks guys!
I've discovered the importance of good textures for walls and floor instead
of just simple tiles. The image attached is an example.
JSR
Download 'bath2.jpg' (103 KB)
Preview of image 'bath2.jpg'
Date: 1 Dec 2006 10:55:01
Message: <web.4570502f3e8ef57cc0bad8570@news.povray.org>
> Hi,
> JSR
Wow! What a massive improvement in visual impact! (Thomas De Groot: mind if
I borrow your expression? ;-)) I can understand wanting to learn on your
own and not just wanting to plug someone elses system in all the time.
Speaking of that, I think Jaime has a good grasp of textures (which you're
obviously learning fast). His room and cloth renders might help you.
Render on,
George
MegaPOV XRS: Renders faster than light.
Date: 1 Dec 2006 11:55:01
Message: <web.45705d6f3e8ef57cd8ef73430@news.povray.org>
I have a question about MegaPov XRS: When I use 2 or more CPU to render a
scene, How is the work divided? The image is divided in 'n' sections
(n=number of CPU) or
all CPU work to the same pixel?
I ask this because I've tried to render a scene (using MegaPOV without XRS)
in 2 sections and after that I merge the 2 sections in photoshop and the
light in the first section is different from the light intensity in the
second section.
This only happens when I use radiosity.
JSR
Download 'radiosity.jpg' (49 KB)
Preview of image 'radiosity.jpg'
Date: 1 Dec 2006 12:45:01
Message: <web.457069ed3e8ef57cc0bad8570@news.povray.org>
> Hi,
> second section.
> JSR
Hi JSR, great observation! The bottom line is that Jaime Vives Piqures found
a way to (for most practical purposes) eliminate the appearance of those
"tiling artifacts". The threads below should be of interest to you. Let me
know if you need any help.
http://news.povray.org/povray.unofficial.patches/thread/%3Cweb.4503150abd91df05c0bad8570%40news.povray.org%3E/?mtop=7
Jaime's test images:
http://news.povray.org/povray.binaries.images/thread/%3C44f8ae1e%40news.povray.org%3E/?ttop=235114&toff=100
Rock on,
George
Date: 21 Dec 2006 07:25:00
Message: <web.458a7c233e8ef57cc0bad8570@news.povray.org>
> > Hi,
> > second section.
> > JSR
Hi Joel, I'm sorry I forgot to answer your first question. Yes, MegaPOV XRS
splits the scene into n sections ("tiles") and each CPU renders one tile.
How are you doing with MegaPOV XRS?
George
