I worked out a way to build a dome of lights from an image. Truespace has a
feature like this. This allows the finish properties to react with the
colors of the image better. I used a very low quality radiosity setting.
Render times are around 20min on a amd 64 3200 with 1gig, windows32 and
megapov. Megapov is only needed for the hdr image. Any image could be used.
I wanted to make it a macro but ran into a snag with the file spec keyword.
If any one has an idea for that let me know.
//Light Dome---------
#declare SP = 0.0175;//sample spacing
#declare HEMI = 0.5;//percent of hemisphere from the top down
#declare MULT = 0.24;//Light multiplier
#declare THRES = 0.45;//image intensity threshold
#declare SSAMP = 30;//Subsamples for spacing average
#declare RAD = 60;//radius of light dome
#declare AREA = yes;//use area lights or not
#declare AS = 5;//size of area light
#declare PIMAGE = function {pigment{image_map {hdr "Timage.hdr"}}}//grab
#declare X = HEMI;
#while(X < 1)
#declare Y = 0;
#while(Y < 1)
#local S = seed(10);
#local CNT = 0;
#local COL = PIMAGE(X,Y,0);
#while (CNT < SSAMP)
#local COL = (COL + PIMAGE(X+(rand(S)*SP),Y+(rand(S)*SP),0))/2;
#local CNT = CNT + 1;
#if(COL.gray > THRES)
light_source{x*RAD
color (COL*MULT)
looks_like{sphere{x*RAD,1 pigment{color COL}}}
#if(AREA) area_light <AS, 0, 0> <0, 0, AS> 2, 2 adaptive 3
jitter circular orient #end
fade_distance 1
fade_power 1
rotate z*(X*180-90)
rotate y*(Y*360)
translate y*1
#declare Y = Y + SP;
#declare X = X + SP;
Download 'building1.jpg' (34 KB)
Preview of image 'building1.jpg'
> image
> #declare X = HEMI;
> #while(X < 1)
> #declare Y = 0;
> #while(Y < 1)
> #local CNT = 0;
> #end
> light_source{x*RAD
> color (COL*MULT)
> fade_distance 1
> fade_power 1
> rotate z*(X*180-90)
> rotate y*(Y*360)
> translate y*1
> #end
> #end
> #end
Download 'building2.jpg' (33 KB)
Preview of image 'building2.jpg'
Download 'building3.jpg' (17 KB)
Preview of image 'building3.jpg'
Download 'building4.jpg' (45 KB)
Preview of image 'building4.jpg'
m1j nous apporta ses lumieres en ce 2005-12-03 00:05:
Just a little detail about adaptive area_ligh.
adaptive 0 try to use at least a 2*2 aray, adaptive 1 try to start with an 3*3 aray,
adaptive 2 try
to start at 5*5, adaptive 3 at 9*9... (2^<adaptive value>+1)
In your case, adaptive 3 with a 2*2 aray is completely useless, as it want to start
with 9*9 but
have only a 2*2 aray to work with. So it only use the 2*2 it have, and you never get
any speed
improvement.
Change is inevitable, except from vending machines.
I changed and fixed a few things!
#declare SP = 0.005;//sample spacing
#declare ANGLE = 210;
#declare MULT = 0.003;//Light multiplier
#declare THRES = 0.50;//image intensity threshold
#declare RAD = 100;//radius of light dome
#declare AREA = no;//use area lights or not
#declare LV = no; //lights are visible
#declare X = 0;
#while(X < 1)
#declare Y = HEMI;
#while(Y < 1)
#local CNT = 0;
#local COL = (COL + PIMAGE(X+(rand(S)*SP),Y+(rand(S)*(SP)),0))/2;
light_source{x*RAD color (COL*MULT)
#if(LV) looks_like{sphere{x*RAD,2 pigment{color COL}}} #end
#if(AREA) area_light <AS, 0, 0> <0, 0, AS> 3, 3 adaptive 1
rotate z*(Y*180-90)
rotate y*((1-X)*360+ANGLE)
translate y*0.1
#declare Y = Y + SP*2;
The image is the results of the changes compared to the last.
Download 'building4.jpg' (36 KB)
An updated image with blurred reflection and photons.
Download 'building5.jpg' (37 KB)
Preview of image 'building5.jpg'
