POV-Ray : Newsgroups : povray.binaries.images : Rounded Prisms Server Time
10 Apr 2026 09:06:20 EDT (-0400)
  Rounded Prisms (Message 1 to 10 of 26)
Subject: Rounded Prisms
Date: 23 Nov 2005 09:45:01
Message: <web.43847f2f53a825ce74786be00@news.povray.org>
I've recently been playing around with my rounded prisms macros. As well as
regular polygon rounded prisms, I can now also do irregular polygons and
polyominoes. Here are a few examples. I'll post some SDL when it's fit for
human consumption. :)
The polyomino tesselations were found by a C program I wrote years ago on
the Amiga. I can post it (source & Linux binary) as well, if anyone wants
it.
Download 'rpcblock0s.jpg' (169 KB)
Preview of image 'rpcblock0s.jpg'
Subject: Re: Rounded Prisms
Date: 23 Nov 2005 10:15:01
Message: <web.438487427ed7ae6c74786be00@news.povray.org>
Here are some more:
Download 'rpdblock0s.jpg' (220 KB)
Preview of image 'rpdblock0s.jpg'
Date: 23 Nov 2005 11:10:01
Message: <web.438493687ed7ae6ca43155f60@news.povray.org>
> Here are some more:
Look fantastic - could make some great abstract images using these!! Be
great to post the source.  Great work!  Adrian
Date: 23 Nov 2005 17:15:00
Message: <web.4384e8e87ed7ae6cdc45bc820@news.povray.org>
yes, please post the source - I am looking for some nice tesselations /
Penrose tilings for a garden pavement.
Joanne
Date: 23 Nov 2005 21:50:00
Message: <web.438525007ed7ae6cdd5514710@news.povray.org>
> Joanne
Ok, this one can do regular & irregular polygons and polyominoes, but in a
few days I'll post one that does a better job with polyominoes (after I've
cleaned it up a bit more). The scene file below can do polyo's but they're
not suitable for tiling, since the rounding is added to the outside of the
shape. That's ok for regular polygons, since we can just use scaling to
make them fit together, but for polyominoes the rounding really needs to be
done within the borders of the squares.
// Persistence of Vision Ray Tracer Scene Description File
// File: IsoTest
// Vers: 3.5
// Desc: Sandy ground & other IsoSurfaces
// Date: 11 Apr 2004
// Auth: PM 2Ring
// -d +A0.2 +AM2 +R4
// -F -A0.4 +AM2 +R1
// +A0.1 +AM2 +R3
#version 3.6;
global_settings {
  assumed_gamma 1
  max_trace_level 7
#declare SkyBlue = rgb<.035, .27, .67>*.6;              //For water & sky
#declare SkyRad = 1E3;
  location <0, 8, -12.0> * 1.35
 // location <0, 5, -12.0> * 3 *1.3
  //location <0, 97, -5>
  direction 2*z
  angle 30
  look_at  -2*y
#declare LightLoc = <1, 4, -3> * 105;
light_source {
  LightLoc rgb 1.2
  //parallel point_at 0
  //looks_like{sphere{LightLoc, 3E2 pigment{rgb<1,1,.8>}finish{ambient 1.5
diffuse 0}}}
//---Textures--------------------------------------------------------------
#declare CM_Clouds =
color_map {
    [0.0   rgb 1]
    [0.05  rgb 0.85]
    [0.20  rgb 0.75]
    [0.45 SkyBlue]
#declare T_Clouds =
texture{
    bozo
    color_map {CM_Clouds}
    warp{
      //turbulence 0.75
      turbulence 0.175
      octaves 7
      omega 0.7
      lambda 2.25
  finish{ambient 0.9 diffuse 0.2}
#declare FThing =
finish{
  ambient 0.05 diffuse .85
  specular .75 roughness 1e-4
  reflection .25 diffuse .7
#declare TGround =
texture{
  pigment{
    //crackle
    //cells
    wrinkles
    color_map{[0 rgb 1][0.025 rgb .25][0.1 rgb .75][0.15 rgb <.85 .75
....65>][1 rgb 1]}
    scale 1.5 / 10
  finish{
    ambient .05 diffuse .675
    //specular .5 roughness 1e-6
    specular .25 roughness 1e-3
    //reflection .15
//---Objects-------------------------------------------
#declare Ground =
cylinder{
  -y, 0, SkyRad/20
  texture{TGround}
//Convert 2D to 3D
#macro V3D(A, H)<A.u,H,A.v>#end
//Generalized Rounded Prism
#macro RPrism(Vtx, Sides, SH, SR)
  //merge{
  union{
  #if(1)
    prism{
      linear_spline 0, SH, Sides+1,
      #local I=0;
      #while(I<=Sides)
        Vtx[I]
        #local I=I+1;
    #local SH = SH - SR;
    #local I=0;
    #while(I<Sides)
      #local II = mod(I+1,Sides);
      #local A0 = V3D(Vtx[I],0);
      #local A1 = V3D(Vtx[I],SH);
      #local DV = Vtx[II]-Vtx[I];
      sphere{A1, SR}
      cylinder{0, SH*y, SR translate A0}
      cylinder{A1, V3D(Vtx[II],SH), SR }
      #local Panel = box{z*1e-3, <vlength(DV), SH, SR>}   //Side panel
      object{Panel rotate y*atan2(-DV.y,DV.x)*180/pi translate A0}
      #local I=I+1;
#macro NPrism(Rad, Sides, SH, SR)
  #local Vtx = array[Sides+1];    //To store polygon vertices
  #local Ang = -2*pi/Sides;
  #local Rad = Rad - SR;
  #local I=0;
  #while(I<=Sides)
    #local Vtx[I] = <cos(Ang*I), sin(Ang*I)>*Rad;
    #local I=I+1;
  #local Vtx[Sides/2] = Vtx[Sides/2] * -.5;          //perturb 1 vertex to
test rounding
#macro PolyPrism(SH, SR)
  #local Sides = 8;
    <-3,2>, <3,2>, <3,0>,
    <1,0>, <1,-2>, <-1,-2>,<-1,0>,
    <-3,0>,<-3,2>
#declare Thing =
object{
  //PolyPrism(.75, .15)
  NPrism(3, 6, 1, .15)
  pigment{rgb 1}
  //pigment{rgb <0 .15 .75>}
  finish{FThing}
  translate y*1e-4
//--------------------------The actual scene-------------------
#declare Sky =
sphere{-y*SkyRad*.9, SkyRad
  inverse
  no_shadow
  texture{
    T_Clouds
    scale <1 .85 1> *  SkyRad/10 rotate 25*y
#if(1)
  object{Sky}
#else
  background{SkyBlue}
  //background{rgb 1}
object{Ground}
object{Thing rotate -35*y translate -3*z}
//-------------------------End of file-------------------------
Here's another sneak preview of tiled polyominoes:
Download 'rprismdf4s.jpg' (101 KB)
Preview of image 'rprismdf4s.jpg'
Date: 24 Nov 2005 12:05:02
Message: <web.4385f22a7ed7ae6cd5d3b08c0@news.povray.org>
In a word, STUNNING!  Just what I am looking for - ancient Persian tilework
on the way!
Date: 24 Nov 2005 12:13:15
Message: <mo8h53-sl3.ln1@badulaque.unex.es>
Among other things, PM 2Ring saw fit to write:
Would it be possible to have rounded inner corners as well?
I mean, where the polygon is concave, you see a "seam" in the rounded edge,
I guess you need a torus here.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 24 Nov 2005 13:29:17
Message: <4386067d@news.povray.org>
I wrote a macro for this once, with variable radii for each vertex. Never
quite finished it.
Attached is a demo render, no HDRI, radiosity or checkered floor though, I
apologize.
Download 'test_var_rnd_lin_prism.png' (490 KB)
Preview of image 'test_var_rnd_lin_prism.png'
Date: 24 Nov 2005 20:35:00
Message: <web.43866a167ed7ae6cad93754b0@news.povray.org>
Yes, a partial torus would do the job. And the algorithm that finds the
polyomino corners can tell the difference between inner & outer corners.
I've been thinking of adding rounded inner corners, but I'm trying to avoid
using differences & intersections, for efficiency reasons.
Date: 24 Nov 2005 20:40:00
Message: <web.43866ad27ed7ae6cad93754b0@news.povray.org>
Thanks!
> on the way!
I'm looking forward to it. I'll try to post the polyomino version tonight
and the polyomino puzzle solver, too.
