POV-Ray : Newsgroups : povray.binaries.images : The Chess Game Server Time
20 Mar 2026 14:20:38 EDT (-0400)
  The Chess Game (Message 1 to 10 of 10)
Subject: The Chess Game
Date: 6 Nov 2005 16:05:01
Message: <web.436e6f81b4164a0e3a8242480@news.povray.org>
More HDRI fun...!
Download 'the-chess-game-hdri-1b.jpg' (148 KB)
Preview of image 'the-chess-game-hdri-1b.jpg'
Subject: Re: The Chess Game
Date: 6 Nov 2005 16:09:01
Message: <436e70ed$1@news.povray.org>
Ooo... classy.
Date: 6 Nov 2005 20:15:15
Message: <436eaaa3@news.povray.org>
nice! how did you manage to get the pentagram-shaped bokeh on the
defocus?  (i.e. the apeture shape?)
(been out of the loop a little, but last time i used some dof, the bokeh
came out perfectly square-shaped)
benp
the_ajj wrote:
> More HDRI fun...!
Date: 7 Nov 2005 09:35:01
Message: <web.436f65b79969c1aca43155f60@news.povray.org>
> benp
> the_ajj wrote:
> > More HDRI fun...!
Nice of you to notice!  The dof and bokeh effects were done as a bit of
post-processing in photoshop using dofpro
(http://www.richardrosenman.com/index.htm) - it gives much nicer results
than the blur_samples function in povray.  I used the megapov post
processing function to produce a depth map and then used this in the
plugin.  The details are on my web site:
http://www.squaretomato.co.uk/povray/index.php?thegame
Date: 8 Nov 2005 00:48:26
Message: <43703c2a@news.povray.org>
excellent!
so, did you render an 8bit image out of povray?
Ideally you'd render a float precision image so you can get all the
out-of-focus hilight shapes just as bright as the in-focus hilights.
benp
>>benp
>>the_ajj wrote:
>>>More HDRI fun...!
Date: 8 Nov 2005 07:40:00
Message: <web.43709c0e9969c1aca43155f60@news.povray.org>
> excellent!
> benp
Sorry - I have no idea what you are talking about - sounds good though.  How
would I go about doing that?  I could then re-render and see the
difference.
Adrian
Date: 8 Nov 2005 17:04:53
Message: <43712105$1@news.povray.org>
The jaggies on the checkers kill it as far as realism go. Maybe a marble
checker board would make this less visible, or higher AA settings. The rest
is so real though. good work!
Date: 11 Nov 2005 08:40:00
Message: <web.43749e519969c1aca43155f60@news.povray.org>
Thanks.  I think it may be a problem with the image as a JPEG rather than a
bitmap.  I'll check when i get home!
Date: 11 Nov 2005 16:05:02
Message: <web.437507479969c1acc3ec2d060@news.povray.org>
Nope - not a problem with the jpeg - bugger.  I've tried a few render tests
with higher aa - changed the sampling method to 2 etc but I can't get rid
of the buggers...oh well !  Any ideas welcome!
Date: 11 Nov 2005 17:28:32
Message: <op.sz3kp1tdcs6ysw@frogeater.bredbandsbolaget.se>
> tests
It is probably the HDRI that is causing the jaggies. The white squares are
just too bright.
To get rid of the jaggies, you can render at a higher resolution and then
downsample the image.
FE
