POV-Ray : Newsgroups : povray.binaries.images : problems with radiosity Server Time
15 Nov 2024 20:20:12 EST (-0500)
  problems with radiosity (Message 1 to 10 of 12)
Subject: problems with radiosity
Date: 14 Sep 2005 12:25:00
Message: <web.43284debc23a6d973333a0@news.povray.org>
I am trying to apply radiocity to my scene. Final image looks fine except
for some strange horizontal lines here and there.
I tried to adjust different parameters, almost without any result. It seems
that the only parameter which affects the appearence of these lines is
"error_bound". When it is below 2.0, the lines start to enumerate. Close to
0.01 they become so numerous that they form ugly patches. Above 2.0 there
is practically no difference.
What is wrong? Could someone please help?
Download 'rad.jpg' (26 KB)
Preview of image 'rad.jpg'
Subject: Re: problems with radiosity
Date: 14 Sep 2005 13:05:37
Message: <43285861$1@news.povray.org>
What does the rest of your radiosity block look like? Or could you post
the scene source?
I understand if you don't want to, but it might give some of us an
opportunity to play with the scene a bit to figure it out.
~Mike
Things! Billions of them!
Date: 14 Sep 2005 13:45:00
Message: <web.43286094d8989f9673333a0@news.povray.org>
> the scene source?
Radiosity block looks like this:
        radiosity {
                pretrace_start 0.08
                pretrace_end 0.01
                error_bound 3
                gray_threshold 0.5
                always_sample off
                count 50
                nearest_count 8
                recursion_limit 3
Tim Nikias (I also posted this message in "newusers") suggested to play with
"nearset_count" and "count". My "nearest_count" is as big as he suggested.
Right now I am rendering with "count 300", but lines still remain, maybe a
little better. I will try 500 at night.
It is absolutely not a problem to post a source. But this is a kitchen with
all the furniture, etc. Original size is 27 MB... Archive size is around
1MB... It is not possible to post it here.
Date: 14 Sep 2005 13:50:00
Message: <web.432861f2d8989f96959cc06b0@news.povray.org>
"avplat" <nomail@nomail> wrote:
> Hi,
It seems (to me) that the lines are being caused by your light sources.
try area lights to smooth the lines.
Wagner
Date: 14 Sep 2005 14:24:46
Message: <43286aee$1@news.povray.org>
avplat wrote:
>>the scene source?
>         radiosity {
>                 pretrace_start 0.08
>                 pretrace_end 0.01
>                 error_bound 3
>                 gray_threshold 0.5
>                 always_sample off
>                 count 50
>                 nearest_count 8
>                 recursion_limit 3
Bump up nearest_count and count. (Tim was certainly right), also turn
always_sample back on.
There *could* be a problem with coincident surfaces (I have seen very
strange lighting artifacts with them)
~Mike
Date: 14 Sep 2005 16:00:00
Message: <web.43287ff9d8989f9673333a0@news.povray.org>
I tried with count 500. There are 3 lines remaining. I will try higher
parameter values, and will also try with different light types.
What do you mean?
What makes me wonder is that the lines are strictly horizontal related to
the *image*. They does not seem to relate to anything in the scene...
Btw, can it be antialiasing-related problem? I am using depth 3 with default
threshold (0.3).
Andrey
Date: 14 Sep 2005 18:10:13
Message: <43289fc5$1@news.povray.org>
avplat wrote:
> Hi,
Hi there,
it may be strange but i had the same problem of brighter horizantal
lines and blocks also several times. But in my case it was not due to
radiosity but due to the choosen antialiasing parameters (as well on
win32 as on linux). Especialy when using method 1. Switching to method 2
normaly solved the problem in my cases.
(xcuse for my poor english)
dave
Date: 14 Sep 2005 18:20:23
Message: <4328a227@news.povray.org>
... and while we are talking about it,
could somebody explain me the fact that in some cases choosing
antialiasing method 1 in conjunction with low threshold limmits (<0.1)
casually produce banding (bright lines and blocks) in the rendered picture?
dave.
Date: 15 Sep 2005 15:00:01
Message: <web.4329c379d8989f9673333a0@news.povray.org>
After looking at numerous pre-rendered and rendered images again and again I
came to the conclusion, that these lines were not calculation errors of
some kind. Thus the problem could not be solved by adjusting radiosity
parameters.
This meant that Wagner perhaps was right. I started removing pieces of
furniture one by one - and inevitably found the one responsible for the
problem. It was a curved piece of glass - a part of the hood (not visible
at the image I presented). I am using Blender as a modelling tool, so I can
only use meshes, not the nice predifined POV-Ray objects. Chosen distance
between vertices was insufficient - which resulted in the surface being
slightly discontinuous. Rays of light went through this glass and formed
"bar code" pattern on the wall. Antialiasing further spoiled the picture by
removing most of these lines and leaving only some of them, making it
impossible to understand where they are coming from.
The problem was solved by increasing vertex count of the glass object and
its smoothing.
Thanks everybody for your advice.
Date: 15 Sep 2005 15:15:01
Message: <web.4329c813d8989f9673333a0@news.povray.org>
M-m-m, sorry, just noticed. I changed my pseudonym to real name, thus
"avplat" = "Andrey Platonov". :o)
Andrey
