Just playing with blurred reflections from some of the code found online.
Download 'surfacea.jpg' (179 KB)
Preview of image 'surfacea.jpg'
Nice picture, excellent lighting it looks very realistic. I assume blurred
reflections are mega pov only or can they be done with normal POV?
Sean
> Sean
Well the first attempts I did where using povman with a combination of
shaders I wrote and code I found online. This image was done using SDL code
I here in the forums.
#macro BTEX(BlurAmount,BlurSamples,ObjectPigment,ObjectFinish )
average texture_map
{ #declare Ind = 0;
#declare S = seed(0);
#while(Ind < BlurSamples)
[1 // The pigment of the object:
pigment { ObjectPigment }
// The surface finish:
finish { ObjectFinish }
// This is the actual trick:
normal
{ bumps BlurAmount
translate <rand(S),rand(S),rand(S)>*10
scale 1000
#declare Ind = Ind+1;
Credit goes to the very smart person that wrote this code but I can not
remember names very well.
I have not tried the megapov blur yet.
The povman shader gives more control but is slower. With it I was able to
fade the reflection off based on distance from the object. Not sure yet how
to do that with any other version of povray. Will keep playing.
> > Sean
> texture {
> average texture_map
> { #declare Ind = 0;
> normal
> { bumps BlurAmount
> scale 1000
> #end
> #end
http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
Found my reference!
Nice Ground.
Sebastian
I love it ! It's my new wallpaper !
Dark Skull Software
http://www.darkskull.net
A+
> > Sean
> texture {
> average texture_map
> { #declare Ind = 0;
> normal
> { bumps BlurAmount
> scale 1000
> #end
> #end
A very clever macro, I wouldn't have thought of using average for something
like that. Thanks for the povman prompt as well, I hadn't even realised it
existed. Looks very interesting..
Sean
> Dark Skull Software
> A+
Now this is just about the best compliment I could get. Thanks!
Very nice lighting. The floor is great too...
It's really *not* gonna be long before computers running freeware
software can produce images that are almost utterly indestinguishable
from reality. ;-)
Here is an update. I soften the floor by using a 16bit png.
The sphere on the left is the pov sdl average while the right is the shader.
I miss spoke before in that the shader method does not yet control the
trace depth. PovMAN does not have the gather function added.
Download 'surface.jpg' (100 KB)
Preview of image 'surface.jpg'
