POV-Ray : Newsgroups : povray.binaries.images : Black and blue Server Time
21 Dec 2025 08:10:40 EST (-0500)
  Black and blue (Message 1 to 7 of 7)
Subject: Black and blue
Date: 1 Mar 2015 03:26:43
Message: <op.xus8epv4ufxv4h@xena.home>
Here I have both the black and blue and the WHite and gold simply by
changing the sky colour
It\s all in the radiosity and exposure
// begin code ---
#version 3.7;
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#default{ finish{ ambient 0 diffuse 1 }}
#include "shapes.inc"
#include "textures.inc"
global_settings{
   ambient_light 1
   radiosity {
          // pretrace_start 1
          // pretrace_end 1
           error_bound 0.6
           count 1000
          // brightness 1
          // gray_threshold 0
          // media on
          // normal on
           recursion_limit 2
  }// end global_settings
camera{ location  <0, 14, -20>
         right   x*image_width/image_height
         rotate 12*y
         look_at   <-1.25,2.8,0>
         angle 33
//sky_sphere{ pigment { color rgb 1} } // Blue/Black
sky_sphere{ pigment { color rgb <1,1,.3>*20} } // gold/white
// fog
// ground
plane{ <0,1,0>, 0
       pigment{ // solid pattern for use in texture/pigment/normal(/density)
// cube checker pattern, alternates color1 and color2
   checker
     color rgb <1, 1, .1>,
     color rgb .5
     scale 5
      } // end of plane
//box{-50,50 hollow pigment{colour rgb <1,1,0>}finish{diffuse 1}}
union {
#for (Cnt,1,3)
   difference {
      box {<-1,-1,-1>,<1,1,1> }
      sphere {0,1.40 inverse /* texture{ pigment{ color rgb<1,1,1>*0.5}}*/
      sphere {0,1.25}
      texture{ pigment{ color rgb ((Cnt/2)=(int(Cnt/2)))*<.1,.1,.7>+.03}//
blue / black
               finish{ phong 1 diffuse 1-Cnt/10 reflection{
0,.1*((Cnt/2)!=(int(Cnt/2)))} }
      translate<0,0,0>
      scale 1+Cnt*0.65
      translate <0,1+Cnt*0.30,0>
      rotate Cnt*<0,-22,0>
scale <1,1,1>
translate<0,1,0>
// End code ---
-Nekar Xenos-
Download '!blueblack.png' (57 KB) Download 'blueblack.png' (64 KB)
Preview of image '!blueblack.png'
Preview of image 'blueblack.png'
Subject: Re: Black and blue
Date: 1 Mar 2015 13:04:27
Message: <54f354ab$1@news.povray.org>
Am 01.03.2015 um 09:26 schrieb Nekar Xenos:
Not the same effect as with the dress though. You just hit the dynamic
range limit of the file format; that's not the case with the dress.
Date: 1 Mar 2015 21:13:33
Message: <54f3c74d@news.povray.org>
OK, Christoph, challenge accepted.  In the right-side render, the dress
is within the dynamic range, except for some of the brighter-lit blue
areas.  The rest of the scene is washed out, as it was in the original
photograph.
The left side uses an rgb 1 light source, appropriately adjusted for
inverse square fading.  The right side uses hsv <40, 0.8, 9>, also
1/sq-adjusted.  Ambient values were auto-calculated by my private render
rig (as were the light source values and camera position), although for
an experiment like this, you'd probably want to stick with radiosity.
(The scene turns off ambient when it uses radiosity, even if you're
still using POV-Ray 3.6.2.)
To keep it realistic, the scene uses assumed_gamma 1.  An even more
realistic scene would use spectral rendering, but with this working POC,
that seems like overkill.
_____________________________________________________________
#version 3.5;
#ifndef (Rad) #declare Rad = on; #end
global_settings
{ assumed_gamma 1
   #if (Rad)
     radiosity
     { count 100
       error_bound 0.5
       pretrace_end 0.01
       pretrace_start 0.08
       recursion_limit 2
camera
{ location <0, 1, -5.6713>
   look_at <0, 1, 0>
   right 0.6667 * x
   up y
   angle 16.0585
#if (frame_number = 2)
   light_source
   { <-3.3125, 7.6250, -5.7374>,
     rgb <36409, 26700, 7282>
     fade_power 2 fade_distance 0.10417
     spotlight point_at <0, 1, 0> radius 45 falloff 90
   #default
   { finish
     { diffuse 0.6
       ambient rgb (Rad? 0: <1.6278, 1.1937, 0.3256>)
#else
   light_source
     rgb <4045.5, 4045.5, 4045.5>
   #default
   { finish
     { diffuse 0.6
       ambient rgb (Rad? 0: 0.18087)
box
{ -1, 1 scale <7, 9, 7> hollow
   pigment { rgb 1 }
plane
{ y, 0
   pigment { checker rgb 0.5 rgb 1 }
sor
{ 8, <0.60, -0.50>, <0.37, 0.00>, <0.26, 0.60>, <0.31, 1.10>,
   <0.23, 1.40>, <0.30, 1.85>, <0.15, 2.00>, <0.00, 2.01>
   sturm
   pigment
   { gradient y color_map
     { [0.5 rgb <0.07, 0.09, 0.8>]
       [0.5 rgb 0.04]
     scale 0.25
Download 'dresses.jpg' (41 KB)
Preview of image 'dresses.jpg'
Date: 1 Mar 2015 21:17:01
Message: <54f3c81d@news.povray.org>
On 03/01/2015 10:13 PM, Cousin Ricky wrote:
> #version 3.5;
> [snip]
Render with: +KFF2 +W320 +H480
Date: 2 Mar 2015 02:42:19
Message: <54f4145b$1@news.povray.org>
>> #version 3.5;
Are you using Moray?
Regards
Date: 2 Mar 2015 09:55:50
Message: <54f479f6$1@news.povray.org>
>>> #version 3.5;
No, I'm just failing to assume that everyone has upgraded since 2004.
It doesn't need any features beyond 3.5, so I went with that.
Date: 2 Mar 2015 10:32:50
Message: <54f482a2$1@news.povray.org>
>>>> #version 3.5;
Fair enough. Just a thought. :-)
I am a fairy and my name is Nuff.
Fairy Nuff.
