![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The source code for one of the images below contains a light
source (and renders in less than a second), while the source
code for the other image does not have a light source (and
renders in about 3 seconds).
Both images were rendered in one single pass with the official
POV-Ray v3.5. No other tools or resources was used, (except for
jpeg-compression.)
So here is a little quiz: Can anyone guess how this was done ?
And which of the images has source code with light_source ?
Tor Olav
Download 'A12.jpg' (13 KB)
Download 'A91.jpg' (13 KB)
Preview of image 'A12.jpg'
![A12.jpg](/povray.binaries.images/attachment/%3CXns93A4378303A9Ftorolavkhotmailcom%40204.213.191.226%3E/A12.jpg?ttop=413793&toff=6650&preview=1)
Preview of image 'A91.jpg'
![A91.jpg](/povray.binaries.images/attachment/%3CXns93A4378303A9Ftorolavkhotmailcom%40204.213.191.226%3E/A91.jpg?ttop=413793&toff=6650&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: With and without a light_source - 2 attachments
Date: 24 Jun 2003 00:55:49
Message: <3ef7d9d5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Once you've got the first image, just reuse it as image_map (in a box?) )
with ambient 1
I can't see any difference between them
Regards
Bruno Gimeno
eelr
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There is a tiny difference, You can see it in attached file :oP
Chaps
"B. Gimeno" <nos### [at] jazzfree com> wrote in message
news:3ef7d9d5@news.povray.org...
> with ambient 1
> Regards
> Bruno Gimeno
> eelr
Download 'A12minusA91.jpg' (3 KB)
Preview of image 'A12minusA91.jpg'
![A12minusA91.jpg](/povray.binaries.images/attachment/%3C3ef840d3%241%40news.povray.org%3E/A12minusA91.jpg?ttop=413793&toff=6650&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"B. Gimeno" <nos### [at] jazzfree com> wrote in news:3ef7d9d5@news.povray.org:
> with ambient 1
Nope, that's not the way I did it. No image maps were used.
As Chaps said; There is a tiny difference.
(It is easier to see it if you invert Chaps' difference image.)
Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Jun 2003 11:27:35
Message: <3ef86de7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Slope maps?
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Jun 2003 12:23:03
Message: <3ef87ae7@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Tor Olav Kristensen <tor_olav_kCURLYAhotmail.com> wrote in message
no idea really. it migh tbe interesting, but if it takes longer without a
light source and the images are *almost* identical, what's the point? unless
the non light_source image produces nice shadows, which isn't evident here.
my guess is A12.jpg. it looked like the bright area on the inside was
tighter. but now looking again, they look too close.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Ross Litscher" <lit### [at] osu edu> wrote in
news:3ef87ae7@news.povray.org:
> without a light source and the images are *almost* identical, what's
> the point? unless the non light_source image produces nice shadows,
Actually, this "method" does not produce shadows at all.
(It therefore provides a way to use a shadowless light source
to make phong highlights for isosurfaces.)
The highlights in the texture are controlled by a function.
(I.e.: The highlights are kind of "built into" the texture.)
I made a macro that builds functions that can be used to
control texture maps, pigment maps, color maps etc. for
isosurface shapes.
One just have to tell the macro about the camera position,
the position of the "virtual" light source and the amount
of ambient, diffuse and specular (phong) reflection for the
surface. One can also tell the macro about how the light
is attenuated as it "moves" away from the light source.
(Of coarse, the macro also needs to know the function for
the isosurface shape itself.)
You can find attached 2 more images that were made with
this macro. The "virtual" light source has the same
position in space as in the other images. But the textures
in the texture_map are different.
I'm not sure yet if all this is useable for more than
generating special effects.
A12.jpg is made with a "virtual" light source.
Tor Olav
Download 'A14.jpg' (31 KB)
Download 'A15.jpg' (29 KB)
Preview of image 'A14.jpg'
![A14.jpg](/povray.binaries.images/attachment/%3CXns93A4DFE02E17torolavkhotmailcom%40204.213.191.226%3E/A14.jpg?ttop=413793&toff=6650&preview=1)
Preview of image 'A15.jpg'
![A15.jpg](/povray.binaries.images/attachment/%3CXns93A4DFE02E17torolavkhotmailcom%40204.213.191.226%3E/A15.jpg?ttop=413793&toff=6650&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Hugo Asm" <hua### [at] post3 tele dk> wrote in news:3ef86de7$1@news.povray.org:
> Slope maps?
It all started with my experiments with slope maps for isosurfaces.
But: No it is not made with slope maps.
I used a function controlled texutre map to make the shading and
the phong highlights.
The function calculates (numerically) the slope of isosurfaces and
uses information about the directions to the camera and the light
source to calulate a value that I use to control the brightness of
the texture at each point on the isosurface.
Also see my answer to Ross Litscher some minutes ago in this thread.
Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: With and without a light_source - 2 attachments - 2 attachments
Date: 24 Jun 2003 18:16:46
Message: <3ef8cdce@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:Xns### [at] 204 213 191 226...
> isosurface shapes.
well that all is interesting. So are these pictures. what you do continues
to amaze me, i completely love all your isosurface posts. now that i kind of
understand what you are doing here, these picture are really cool.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3ef8cdce@news.povray.org:
> continues to amaze me, i completely love all your isosurface posts.
> now that i kind of understand what you are doing here, these picture
> are really cool.
Thank you Ross for these encouraging words !
Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
