POV-Ray : Newsgroups : povray.binaries.images : Glass for v3.8 finish features Server Time
14 Dec 2025 16:53:31 EST (-0500)
  Glass for v3.8 finish features (Message 1 to 10 of 14)
Subject: Glass for v3.8 finish features
Date: 8 Aug 2022 08:49:24
Message: <62f10654@news.povray.org>
I was happy to read the instructions for a version 3.8 glass material,
provided by Alain Martel
https://news.povray.org/povray.general/thread/%3Cweb.62e942de1adc8eb48a3c0aee5cc1b6e%40news.povray.org%3E/
and wanted to try them out myself. This is the result. The different
variations include air bubbles and the albedo keyword in the cylinder, a
scattering media inside the ovus, and appropriate fade_color and
fade_distance for the different objects. The background is a hdr map,
and a single additional point light are completing the setup.
A big thanks to Alain! This is an excellent starting ground for quality
glass material indeed.
Download 'glass_test_02.png' (534 KB)
Preview of image 'glass_test_02.png'
Subject: Re: Glass for v3.8 finish features
Date: 8 Aug 2022 14:06:05
Message: <62f1508d$1@news.povray.org>
Am 08.08.2022 um 14:49 schrieb Thomas de Groot:
Very nice, indeed. Seems I should take a look into the general
discussion occasionally. IMO there is a small drawback. The "caustics"
at the table did not correspond to the light sources within the HDRI
image. But I'm nitpicking ...
Best regards,
Michael
Date: 9 Aug 2022 05:45:00
Message: <web.62f22b7be64472316086ed06830a892@news.povray.org>
> Thomas
Was it slow to render ? There seems to be no anti aliasing.
Date: 9 Aug 2022 08:43:16
Message: <62f25664$1@news.povray.org>
Op 9-8-2022 om 11:40 schreef Mr:
I used +a0.3 +am2 +bm2 +bs8  maybe not the best aa setting but I was
playing ;-)
I think total render time was about 2 hours or a bit more.
Date: 9 Aug 2022 08:53:02
Message: <62f258ae$1@news.povray.org>
Op 8-8-2022 om 20:06 schreef MichaelJF:
You are right as I added an additional light source and the hdri light
sources have been overflooded. I needed it mainly as a backdrop to the
scene.
initially, I wanted to concentrate on the hdr light sources though...
Date: 9 Aug 2022 10:50:09
Message: <62f27421$1@news.povray.org>
Op 9-8-2022 om 14:53 schreef Thomas de Groot:
...and when I do, no photons are generated!
I use
   photons {
     refraction on
     reflection on
for the sphere with the hdr map, identical to the code for the light
source. Decreasing spacing down to a ridiculously small value doesn't
change anything. I must be missing something here...
Date: 9 Aug 2022 11:16:11
Message: <62f27a3b$1@news.povray.org>
> I use
>    photons {
>      refraction on
>      reflection on
I'm perhaps not following, but...
Taking your hdr sphere to be an actual hollow sphere, you are making it
a photon target for any photon light sources by adding the photon block
above. In other words - as far as I know - there is no way to shoot
photons from other than a traditional light sources.
Aside: I've never tried to shoot photons from a light source inside a
hollow object at the inside surface of that object. I'm not sure it
would work given the how the radial 'shooting pattern' is aimed at
target objects. Perhaps this the reason why you get no photons? Hmm,
maybe a spot light would work... Too long since I've played with photons.
Bill P.
Date: 9 Aug 2022 11:20:00
Message: <web.62f27ad2e64472364326bc25cc1b6e@news.povray.org>
> Thomas
This is why I love working with POV and this community.  There's always someone
who has thought about the same problems and is willing to share their experience
(and code!)
-- Chris R.
Date: 9 Aug 2022 13:09:22
Message: <62f294c2$1@news.povray.org>
Am 09.08.2022 um 17:16 schrieb William F Pokorny:
>> I use
>>    photons {
>>      refraction on
>>      reflection on
> Bill P.
Unfortunatelly, Bill seems to be right. I tried a bit, but it seems to
be impossible to persuade a HDRI light to cast photons, so we need POV
4.0 ;)
Best regards,
Michael
Date: 10 Aug 2022 02:04:55
Message: <62f34a87$1@news.povray.org>
Op 09/08/2022 om 19:09 schreef MichaelJF:
>>> I use
>>>    photons {
>>>      refraction on
>>>      reflection on
>> it a photon target for any photon light sources by adding the photon
>> block above. In other words - as far as I know - there is no way to
>> shoot photons from other than a traditional light sources.
>> Bill P.
> 4.0 ;)
That was also the conclusion I reached.
POV 4.0, where are you? :-)
