Am 10/28/2020 um 12:05 schrieb Bald Eagle:
> The intense friction between the theoreticians and empirical experimentalists
> and engineers is likely to be eternal ;)
Having been on both sides during my career did work quite well for me ;)
> When everything is expressed in pigment {rgb <r, g, b,>} at assumed_gammma 1.0,
> everything seems pretty straightforward.
Sure.
> But let's say someone borrows a nice texture that has srgb keywords sprinkled
> throughout its declaration. The color that pigment color values that get
> "exposed" to the other elements in the scene are still just - rgb, correct?
Absolutely. The srgb keyword just tells POV-Ray to consider this color
as beeing encoded with the sRGB gamma transfer function and converts it
immediately to its linear equivalent.
As long one is aware that rgb has to be followed by an linear color
expression everything is fine while on the other hand an expression like
rgb <220, 32, 80>/255 together with assumed_gammma 1.0 cries out to
produce an unwanted result.
In the times before 3.7 it was very hard to work with any kind of image
map with assumed_gammma 1.0 but Christoph did a really great job in
fixing all these issues - and IMHO quite underrate as this was an
endeavor of epic proportions.
> Two things which seem pretty unclear are the effect of assumed_gamma srgb,
> and/or a light source defined as srgb. I can conceive the light source as just
> being the rgb end result of the srgb conversion formula, like the texture
> example, but just checking.
> But assumed gamma must affect the whole scene - presumably by doing all of the
> color calculations in "srgb color space". Which with my present understanding,
> and peeks into the source code, lead me to speculate that multiplying a pigment
> color by a light source color gets a whole lot more complicated.
assumed_gamma srgb is close to assumed_gamma 2.2 with all its well known
drawbacks: POV-Ray will work internally not in a linear color space
resulting in hue-shifts all over the place.
assumed_gamma srgb is useful when using POV-Ray only as a
"painting-tool" for drawing graphs or the like...
> Does one use srgb for all colors in assumed_gamma srgb scenes or rgb?
This doesn't matter as rgb just takes the value as is and srgb converts
into the target space which means in this case no conversion at all
resulting in the same thing.
> What's the proper way to instantiate image_maps that may be encoded by libraries
> with in-built gamma handling precorrections?
While I have no idea what exactly you do mean by this let me tell you
this: as long those libraries follow the appropriate image file format
specifications POV-Ray shouldn't have any problems and otherwise these
libraries are crap anyway.
> I guess the concern here with many of my examples / implied questions is the
> user trying to do something with srgb, and the software then doing a second
> conversion - or the user NOT doing a conversion where needed and winding up not
> using the color values needed for consistency with the rest of the scene, or
> something getting corrected by the software in the opposite direction because a
> user wasn't aware of a required precorrection.
My point of view here is quite simple: If you aim at any degree for
realism in your renders you'll have to use assumed_gamma 1.0 and make
sure that everything that follows the expression rgb is encoded with a
linear gamma.
This is not my personal opinion, this isn't even an opinion this is a fact.
On the other hand you may not aim for any photo-realism at all then
POV-Ray allows you to do whatever fits your needs.
This great range of freedom also allows you to mess up things in any
wanted or unwanted way - this is the price you have to pay for your freedom.
-Ive
Ive <ive### [at] lilysoftorg> wrote:
> Well, now I have read through the whole thread. What a mess. There are
> so many false statements, combined with completely correct statements
> and - as usually - the worst ones: almost true statements.
> And then are the things that are simply not relevant anymore (like the
> whole discussion with Warp - Clipka expanded the color_map syntax so
> that none of the complains is still valid).
"Science advances by taking two steps forward and one step back."
Or here, maybe it was 1 step forward and two steps back :-P
I sometimes think of the newsgroups as a kind of 'community sketch pad, where
someone starts out by drawing a few basic shapes or blobs (the "idea"), then
others start adding their own doodles, then erasures, then recapitulations of
the 'history of art', then more doodles... until, hopefully at the end, there is
a 'nice final picture' of the original idea. But sometimes its a real mess
getting there, I agree. (And I'm certainly to blame, here.) But the final result
can be... awesome! Too bad that we can't clean up the mess, by deleting all the
extraneous stuff and dead ends. ;-) Ah, but that's the interesting (and messy)
history of how we got to the end result... to be kept in the archives for all
time, ha. :-O
> linear gamma.
I'm genuinely curious about image_map use in that context, and how it is handled
by POV-ray internally. You mentioned, I think, that the *linear* contents of the
image's colors/brightness are used for internal computations(?), regardless of
what we 'see' in the render. If I'm correct about that, do you know if radiosity
from an image_map uses the *linear* values to 'shed its light' into the scene?
In other words, are the radiosity patches' 'colors' based on the linear-color
values of the image? Or does radiosity 'radiate' the 2.2-gamma colors, the image
colors that we 'see' in the render? It would seem that there would be a wide
color difference between the two schemes... with perhaps different visual
results than we might imagine or expect, depending on the scheme used. (A rough
analogy would be, using rgb colors vs. srgb colors for an object's pigment.)
Subject: Re: Stock colors and assumed_gamma 1 in POV-Ray 3.6
Date: 29 Oct 2020 03:27:19
Message: <5f9a6ed7$1@news.povray.org>
Op 28/10/2020 om 10:33 schreef Ive:
> Am 10/28/2020 um 8:54 schrieb Thomas de Groot:
>> Maybe you remember the Bald Eagle / Clipka discussion in
http://news.povray.org/povray.advanced-users/thread/%3C57894ece%241%40news.povray.org%3E/
> I admire your memory. Especially not just remembering it - but also
> *where*.
> But no I don't think I did read this thread, otherwise I would have been
> tempted to remark that my silly demo scene "cyndi cubes" demonstrates
> the usage of the macros from my file CIE_tools (both part of the
> Lightsys package) and these would be much more powerful (e.g. would also
> be able to compensate for whitepoint errors) than Clipka's suggestions.
> Which reminds me, these files were written back in 2003, long before
> Christoph even joint the POV-Ray community and meanwhile he already left
> - people come and go and doesn't time fly by?
My memory was from something Christoph said and which I noted down as
the words of the oracle. So I just had to look for the oracle and there
it was, with reference et al. ;-)
This whole rgb/srgb business has been a difficult one for me and I just
try to follow the advices of my learned friends. Breaking the rules more
often than not I am afraid.
I am sad about all those people who have left and who had something
tangible to contribute, if only for their amazing scenes. But that is
life I guess...
Date: 29 Oct 2020 05:20:15
Message: <5f9a894f@news.povray.org>
Am 10/29/2020 um 0:40 schrieb Kenneth:
Well, even in science - at some point - findings turn into knowledge and
facts. No astronomer or cosmologist has any doubt about Newtons laws of
gravity and no - general relativity didn't proof them wrong, it still
includes Newtons laws. By accepting them and using them we are even able
to send probes to the border of the solar system by accelerating them
with sling-shots around Jupiter.
> time, ha. :-O
Sure. But then someone (was it you? If so, I'm sorry I do not mean it
personal) turns up with a link to some past discussion that is meanwhile
(since 3.7) completely obsolete and frankly, complaining about a minor
detail that could already be solved within 3.6 (poly_wave as I did
suggest there) appears to me not like an epic battle, more like a boring
minor battle of retreat.
So this NG is like the rest of the net. One has to learn how to assess
and classify the threads written here in the past.
Since 3.7 (and assumed_gamma 1.0 of course):
Every image that is loaded via image_map is internally converted
automagical into a linear representation. POV follows the rules of image
file format specification and does everything right. In case you KNOW
that the image you intent to load is different you can use the gamma
modifier for image maps and tell POV-Ray what it should assume.
Like e.g. image_map {jpeg "my_image" gamma 1.8} for a jpeg file that was
produced 30 years ago on a Mac.
Every image that is loaded via bump_map is assumed to be already a
linear representation of the bumpiness (as it should be) and will
internally be represented as is. In case you KNOW that your map is gamma
encoded (for whatever reason) you should tell POV-Ray like e.g.
bump_map {jpeg "my_bump" gamma 2.2}.
As POV-Ray has no native support for transparency maps, specularity
maps, roughness maps, metallicity maps (all of them are pretty much
standard in professional PBR rendering and as such are always considered
to be in linear color space as a de facto standard) but can use them
with the help of the pigment_pattern statement one should always add
gamma 1.0 to the image_map expression when the image is *NOT* meant to
be an "image" but a map of some kind.
And radiosity? There is a reason that file file formats like OpenEXR and
Radiance HDR are already per definition encoded in linear color space.
So, to answer your question, of course uses the radiosity calculation
linear values.
A final remark: not using assumed_gamma 1.0 causes hue-shifts that
become more dramatic the more complex the lighting situation is AND it
violates the very basic low of energy conservation. There is no brick
wall that reflects more light than shines on it.
If one has no problem with this two issues I'm absolutely fine with this
but please do not complain about unexpected results.
And if somebody uses assumed_gamma 2.2 and produces a brilliant image
I'm glad for him but this proofs nothing and is no reason to start this
discussion again.
-Ive
Date: 29 Oct 2020 11:42:07
Message: <5f9ae2cf$1@news.povray.org>
On 10/29/20 5:20 AM, Ive wrote:
<snip>
> discussion again.
lol...thud (thanks btw)
> linear values.
Thanks; that was one of the 'missing links' in my conception of radiosity use.
Yes, that is how I now understand any *non*-assumed_gamma 1.0 to operate. (And
of course, visual results bear it out.)
> ... And if somebody uses assumed_gamma 2.2 and produces a brilliant image
> discussion again.
Well, in an ideal world, with everyone having perfect recall of all of the
arcane details that make up POV-ray, I would agree. But the trouble with the
newsgroups (and even the highly-detailed reference wiki) is that the true
'nuggets of wisdom' are spread out and not easily referenced. (That's probably
the case with any large collection of facts.) In the newsgroups here, the truly
useful nuggets are contained *somewhere* in x-number of years of posts, and it
sometimes takes real detective work to find them.
I bow down to anyone who can keep *all* of that stuff in memory, for instant
recall!
Thomas here, and Bald Eagle as well AFAIK, have apparently taken the time to
create a compendium of pertinent links to old posts, that they can refer to. I
used to do the same-- until my old Win XP computer failed...and I had stupidly
neglected to back up my years of 'net links. (I've learned my lesson, the hard
way.) For me, it's almost like starting again from ground-zero.
The point is, it's not easy (at least for me) to remember all the do's and
don'ts of POV-ray operation, and especially the 'why'.
One of Clipka's many strengths was that he had infinite patience in answering
the 'same ol' questions' over and over again. Aside from his knowledge and his
willingless to share it, that was the one quality that stood out.
Date: 30 Oct 2020 03:28:18
Message: <5f9bc092@news.povray.org>
Op 29/10/2020 om 17:22 schreef Kenneth:
My compendium of pertinent links is small as I did really start that
quite recently after I lost so much time in tracing back relevant info
(and/or history) I needed for particular projects. The net (and hence
POV-Ray) is great for re-inventing the wheel at regular times :-) No
criticism involved here; it is the nature of the net that stimulates
this I am afraid, and its volatile way of "remembering" and "forgetting"
things. The same goes for all those people who were present during those
early days of POV-Ray and have vanished now, sometimes suddenly,
sometimes gradually, but knowledge has gone with them, if that knowledge
had not been secured one way or another.
I suppose prehistoric man experienced the same phenomenon: one tribe
discovered a novel way of knapping silex tools. They boasted about it in
the neighbourhood but were wiped out by their version of covid-19 before
the knowledge was spread. It certainly is true of his spread from
Africa: it happened several times but only few expansion waves were
successful.
[and now I shut up]
Date: 30 Oct 2020 04:15:36
Message: <5f9bcba8$1@news.povray.org>
Let me stick out my neck once again. ;-)
Back in 2014, and following some discussion it appears, I composed this
test scene, without really understanding the matter. What is wrong?
Download 'utf-8' (6 KB)
Am 10/30/2020 um 9:15 schrieb Thomas de Groot:
I didn't run it as I do not have Ricky's include file anyway but from
looking at it there is nothing wrong
The first box under "Ive's macros" should be brighter and less saturated
and the second one should be the same as your 1st reference color.
If this is not what you expect you might want to check your expectations
But in case you want *my* boxes to look the same as *your* reference
boxes you should obviously also use "MyColor" for the first box and
sRGB_to_scRGB(MyColor) for the second one as this does exactly the same
as the POV-Ray keyword srgb.
-Ive
https://news.povray.org/%3C5513104c%241%40news.povray.org%3E
