POV-Ray : Newsgroups : povray.binaries.images : How to concatenate an identifier? Server Time
12 Aug 2025 16:41:16 EDT (-0400)
  How to concatenate an identifier? (Message 1 to 10 of 12)
Subject: How to concatenate an identifier?
Date: 20 Sep 2020 11:32:32
Message: <5f677610$1@news.povray.org>
Hi(gh)!
In my POVEarth main script, I have to compose the name of the terrain
slice mesh2 (for example, n41e043) to be tested against a trace vector
from the integer part of the geographic camera position. I know that
this is not possible by default, but I remember having used a special
include file years ago which facilitates concatenating identifiers.
Unfortunately, I don't remember the name of this include file...
See you in Khyberspace!
Yadgar
Subject: Re: How to concatenate an identifier?
Date: 20 Sep 2020 12:55:01
Message: <web.5f67889dc09da16c4d00143e0@news.povray.org>
hi,
do you mean the 'Parse_String()' macro in 'strings.inc'?
regards, jr.
Message: <web.5f6788e3c09da16c60e0cc3d0@news.povray.org>
Try macro Parse_String() in strings.inc.
Date: 20 Sep 2020 14:05:01
Message: <web.5f6798f7c09da16c60e0cc3d0@news.povray.org>
JINX!
Date: 20 Sep 2020 14:35:01
Message: <web.5f67a05dc09da16c4d00143e0@news.povray.org>
hi,
> JINX!
YIKES!  ;-)
regards, jr.
Date: 27 Sep 2020 17:40:05
Message: <web.5f71058cc09da16cd98418910@news.povray.org>
This Parse_String(...) macro is new to me, so I played around with it, to see
what it could do. It's quite powerful, and opens up a lot of possibilities.
Btw, I like to take small chunks of code (like macros) out of include files and
put them directly into my scenes; this saves a *little* bit of parsing time--
and I can easily refer to them.
Some simple examples of the macro's use. (You can run all of these as a scene,
to see the results on-screen and in the messages pane):
#version 3.8; // or whatever
// the macro
#macro Parse_String(String)
    #fopen FOut "parse_string.tmp" write // or "MY_FILE.inc" for example
    #write(FOut,String)
    #fclose FOut
    #include "parse_string.tmp" // ditto
// some initial values to work with
#declare S = seed(37);
#declare T = 6 + sqrt(4) + rand(S);
#declare MY_TEXT = concat("Hello"," ", "world!","  ",str(T,0,5)) // ANY kind of
// string
// a text object
text{
ttf "timrom.ttf" // or   internal 1
Parse_String("MY_TEXT"),.2,0 // needs the double quotes here, because the
// macro's written file doesn't create those
translate <-4,0,15>
texture{pigment{rgb 1}finish {ambient 1 emission 0 diffuse 0}}
// Using the macro to CREATE a #declare statement. The macro (invisibly)
// inserts the statement  #declare ZZ = 4;  into the
// scene here-- not as a 'string', but as an actual command with a
// usable 'R-value'
#declare P = "#declare XX = 4;"
Parse_String(P) // using the macro
#declare TEST_1 = XX + 6; // The result is  10  as expected
// to test this final value
#debug concat("\n","TEST_1 = ",str(TEST_1,1,3),"\n")
// and similarly... writing TWO #declare statements on separate lines...
#declare P = concat("#declare XX = 4;","\n","#declare YY = 20;")
Parse_String(P)
#declare TEST_2 = XX + YY; // the result is   24  as expected
#debug concat("\n","TEST_2 = ",str(TEST_2,1,5),"\n")
Date: 27 Sep 2020 18:55:01
Message: <web.5f7117cac09da16c1f9dae300@news.povray.org>
So, due to my addi...  affliction, I actually had a dream about this macro -
using it to describe an identifier as well as output its value.
As in #debug concat ("U", " = ", str (U, 0, 0), "\n")
It would be handy to have a simple macro that you could just pass  _ U _ to, but
U the text character and U the scalar value are separate and distinct.
So my short dream was about implementing Parse_String to create such a macro...
I think I ran out of dried frog pills.....
Date: 28 Sep 2020 06:20:00
Message: <web.5f71b88dc09da16c4d00143e0@news.povray.org>
hi,
> > This Parse_String(...) ...= ", str (U, 0, 0), "\n")
not quite what you thought of, the "wrong way round"?  :-)
Script started on Mon 28 Sep 2020 11:05:25 BST
jr@goose:4:tmp$ c### [at] bepov
#version 3.8;
global_settings {assumed_gamma 1}
#include "strings.inc"
#macro Abc(s_)
  #debug concat(s_, " = ", str(Parse_String(s_),0,2), "\n")
#declare name_ = "U";
Parse_String(concat("#declare ", name_, " = 123.45;"));
Abc(name_)
jr@goose:5:tmp$ povparse be.pov
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.9945627.unofficial
==== [Parsing...] ==========================================================
U = 123.45
File 'be.pov' line 8: Parse Warning: No objects in scene.
==== [Rendering...] ========================================================
regards, jr.
Date: 28 Sep 2020 08:38:22
Message: <5f71d93e$1@news.povray.org>
> #macro Abc(s_)
> #end
> Abc(name_)
Expect most know, but on seeing this thread I added the follow comments
to povr's string.inc file:
// Parse a string you create (i.e., = concat(...)) - while parsing.
// Use carefully. This macro a hack using a file which can collide
// by name across invocations of povray or during multiple
// simultaneous povray commands. Further, in opening and closing a
// file it is also inefficient if done many times. Often it's
// better to use the same "include defined strings for parsing"
// idea by writing many 'to be parsed strings' to a file and then
// include that single file by a name which you know and control.
     #write(FOut,String)
     #fclose FOut
Bill P.
Date: 28 Sep 2020 09:30:09
Message: <web.5f71e4efc09da16c4d00143e0@news.povray.org>
hi,
wondering whether the recommendation should not follow Kenneth's preference (ie
cut/paste macro in to scene) since it is "self-modifying" code.  also thinking,
wrt file name collision(s), perhaps a new version 2 of the macro could (should?)
be added to the POV-Ray/povr distributions, putting the user "in charge".  eg:
#macro Parse_String_2(Fname, String)
  #fopen FP Fname write
  #write(FP, String)
  #fclose FP
  #include Fname
regards, jr.
