POV-Ray : Newsgroups : povray.binaries.images : Into the Wild Server Time
24 Jun 2026 12:03:31 EDT (-0400)
  Into the Wild (Message 21 to 26 of 26)
Subject: Re: Into the Wild
Date: 15 Aug 2020 07:02:27
Message: <5f37c0c3@news.povray.org>
On 8/15/20 5:42 AM, William F Pokorny wrote:
> On 8/15/20 3:27 AM, Thomas de Groot wrote:
> I'm not a big radiosity user, but I'll play a little with the flags
> while my coffee brews and post if I figure more out.
OK. I found to create/save radiosity results I had to use "+rfRad.sav
+rfo". To use the samples I had to use "+rfRad.sav +rfi".
Further, as shown in the top row of the attached image the "+rfRad.sav
+rfo" result on the left is not identical to the "+rfRad.sav +rfi"
results in the middle. Any two +rfo, +rfi renders are identical.
The perhaps helpful news, when comparing a complete "+rfRad.sav +rfi"
render on the left bottom to one which had be stopped and continued
every two render block rows in the bottom middle, the results are
closer. The issue is still there, but the effect is not as pronounced.
This is with your radiosity block - always sample is off. It looks as if
even loading radiosity samples some radiosity calculation / smaller
number of rays are shot. Didn't explore whether there was some way to
better suppress some/all of these and so get a closer match on continuation.
If you're using radiosity and think you might stop and start your
render, using save radiosity samples is for that render is better, but
not a complete fix/workaround.
Bill P.
Download 'continueradsavbetter.jpg' (389 KB)
Preview of image 'continueradsavbetter.jpg'
Date: 16 Aug 2020 03:10:29
Message: <5f38dbe5$1@news.povray.org>
Op 15/08/2020 om 13:02 schreef William F Pokorny:
Ah! So it is the .sav extension that is mandatory. I used .inc but that
did not work apparently. The wiki is silent about this and I think it
should be mentioned there and wherever the .sav is needed. The use of
+rfo and +rf1 in this context also needs some more explanation.
OK. Having done a bit of experimentation of my own now, I see that using
"+rfRad.sav +rfo" for the first run, and then "+rfRad.sav +rfo +rfi" for
all continuations, results in a - visually - seamless render (see
attachment where I continued several times randomly). VERY good indeed!
Thanks Bill, for this insight.
> continuation.
Indeed, but as I said above, visually, the render /looks/ faultless and
this is a workable solution.
Thanks again indeed for your help, Bill. I am glad we brought this
little bug to light.
Download 'continueissue_grey_3.jpg' (55 KB)
Preview of image 'continueissue_grey_3.jpg'
Subject: Re: Into the Wild - the Final
Date: 2 Sep 2020 02:31:04
Message: <5f4f3c28@news.povray.org>
And so we reach the final scene.
The two isosurfaces (see p.t.scene-files) are superposed.
Download 'into the wild_final2.png' (887 KB)
Preview of image 'into the wild_final2.png'
Date: 2 Sep 2020 05:24:13
Message: <5f4f64bd$1@news.povray.org>
Thomas de Groot wrote on 02/09/2020 08:31:
Really a great image!
  Paolo
Date: 2 Sep 2020 14:10:00
Message: <web.5f4fdfb7b26879b9d98418910@news.povray.org>
That looks really good. I certainly like the 'fuzzy vegetation' effect; well
done! And thanks for posting the code.
Date: 3 Sep 2020 02:30:26
Message: <5f508d82$1@news.povray.org>
Op 02/09/2020 om 20:08 schreef Kenneth:
Thanks indeed, Paolo and Kenneth.
The fuzzy vegetation code was a chance hit :-) and it is as fast (or as
slow) to render as the rocky part. Overall, while I like isosurfaces to
build landscapes, I am reluctant to use them because of their slow
render speed, although I do not complain for this particular one. But if
you want to complete the landscapes with vegetation, dwellings, roads
and such, the testing time becomes prohibitive indeed.
