POV-Ray : Newsgroups : povray.binaries.images : mesh2 generator: strange error! Server Time
29 Apr 2024 18:40:04 EDT (-0400)
  mesh2 generator: strange error! (Message 11 to 16 of 16)
Subject: Re: mesh2 generator: strange error!
Date: 14 Jul 2020 19:45:28
Message: <5f0e4398$1@news.povray.org>
On 15.07.20 01:36, Bald Eagle wrote:
> #declare Obj = union {
> // Everything
>   #local Min = min_extent (Obj);
>   #local Max = max_extent (Obj);
>   #local Center = (Min+Max)/2;
Do these two functions return float or vector values?
Date: 14 Jul 2020 20:00:01
Message: <web.5f0e468d2c156900fb0b41570@news.povray.org>
> > // Everything
They're <x, y, z> coordinates.
http://wiki.povray.org/content/Reference:Vector_Expressions#Functions
Date: 14 Jul 2020 22:11:46
Message: <5f0e65e2@news.povray.org>
Hi(gh)!
>>> // Everything
Meanwhile, I found out the reason for the weird position of the terrain
slice: when adding a flattening factor to the calculation of the
vertices, I accidentally deleted the cosine statement for the x
coordinate! I replaced it, and now the terrain is in the correct place -
but I wonder that the texture_list has no effect on its coloring, the
entire relief is black!
I still have a full-resolution (i.e. 3601 by 3601) mesh2 of the Kabul
area rendering correctly, but looking up 3.5 GB of text for the
implementation of the texture is next to impossible...
So here once more the "small" (still some 15,000 lines of code!) mesh2
script generated by my mesh2writer.pov...
See you in Khyberspace!
Yadgar
Download 'utf-8' (295 KB)
Date: 15 Jul 2020 02:29:22
Message: <5f0ea242@news.povray.org>
> I really have no clue how to do this - and I can't look it up, as is
> seems not to be included in the POV-Ray 3.7 doc!
As for the docs, the best you can do is use this:
http://wiki.povray.org/content/Reference:Keywords
the wiki docs are the most up to date. Looking up the Keywords is
fastest. I use this almost on a daily basis.
Date: 15 Jul 2020 06:25:00
Message: <web.5f0ed8b02c156900fb0b41570@news.povray.org>
A mesh of one or two triangles can be placed in exactly the same places as one
of 3601 x 3601 triangles.
Put very simple, fast objects in place when testing.
Get it work and work well (change up some of the numbers to verify your
hard-coded assumptions) and then save a copy of the working code somewhere.
If the texture definition is gigantic, trim it down to a simplistic
representation and see what the pattern modifiers are doing.
Do that, and I'll bet you'll find the problem in no time.
Date: 15 Jul 2020 07:25:01
Message: <web.5f0ee6652c156900fb0b41570@news.povray.org>
#declare F_Earthslice = finish {ambient 0.05 diffuse 1 brilliance 0.25 }
ambient 0.05 seems incredibly low, but diffuse 1 ought to be fine.
This leads me to question: Where is your light source and at what angle does it
impinge upon the surface?
Render a shadowless cylinder from your light source location to the
ApproxLook = <-3347983.0848,4226003.8087,3406932.3387>;
vector to see for sure.
Right now you're flying blind and feeling around in the dark.
