POV-Ray : Newsgroups : povray.binaries.images : POVEarth: Norway, Svalbard, Moffen Island Server Time
26 May 2026 18:05:13 EDT (-0400)
  POVEarth: Norway, Svalbard, Moffen Island (Message 11 to 19 of 19)
Subject: Re: POVEarth: Norway, Svalbard, Moffen Island
Date: 13 Apr 2020 11:20:46
Message: <5e94834e$1@news.povray.org>
Hi(gh)!
On 13.04.20 11:26, jr wrote:
> just came across your .. brother-in-arms.  ;-)
> <https://www.youtube.com/watch?v=8_bW3ab8YAk>
Yuck! That would be too chunky for me...
See you in Khyberspace!
Yadgar
Date: 13 Apr 2020 11:55:57
Message: <5e948b8d$1@news.povray.org>
Hi(gh)!
On 13.04.20 12:23, jr wrote:
> on the source (zip) files -- you wrote a 3601x3601 tile needs ~1.5G.  that is
> ~115 bytes per pixel; likely, some/much of that information will not be
> required.  suggest recoding those, to a custom file format.
What do you mean with "custom file format"? Anything binary rather than
text?
> on the mesh2 storage -- what if meshes were only created on-the-fly[*], when
> needed for rendering that part of povearth?  sure, performance hits everywhere,
> but within budget.
On the average raytracing geek's machine (if I regard my six-core AMD
with 24 GB of RAM as average) this still would take 2 1/2 hours per
elevation data tile... just downloading, decompressing and readily using
them in a scene file would be faster!
> another "budgeting" option would be to focus on a single continent, initially,
> and only produce those meshes.
Yes, with POVghanistan only (160 tiles, liberally including also parts
of neighbouring countries to have a neat rectangle - and, yes, doing the
Shalimar Gardens at Lahore or the Golden Temple of Amritsar would be
very nice, not to mention countless other examples of Mughal
architecture throughout India and Pakistan), this would fit into my
limited webspace resources...
>  (maybe, when you retire, your pension will allow
> you to buy more cloud-storage.  :-))
But cloud storage would not be publicly accessible, would it?
In fact, I am an early retiree... from a very patchy work life, so my
pension is rather low, I can't help but having to win a lottery jackpot
to be able to do full-fledged POVEarth... and also my other megalomaniac
project, the Organ Palace - a museum showing all electronic organ models
ever manufactured, at least in virtual space (X3D organs playable as VST
instruments via MIDI keyboard(s) or even entire MIDI organ playtables)
if not in the real world, then also containing a music school and
concert venue... but there is no El Gordo in Germany!
Yadgar
Date: 13 Apr 2020 16:20:04
Message: <web.5e94c85c99da5e40fb0b41570@news.povray.org>
> text?
No - I think what you need to do is what every computer graphics and movie set
designer does to get things like this to work - cheat like Hell.
You don't need 40 billion triangles where a few thousand, or a cleverly textured
primitive with normals will suffice.  I completely understand your goal - but at
the present, you will let the idea of the perfect sacrifice the reality of the
good.
If you have a very large tile - but there isn't much of note on it, then why
model every grain of sand?  Select the parts that NEED detail, and designate
those as meshes or some other detailed form.
What can you adequately get away with using heightfields, and planes and bezier
patches?
With bicubic patches - for the cost of only 16 control points you can get
2^u_steps x 2^v_steps triangles....
Fewer data points, less storage, less reading from disk - more interpolation and
procedural generation.
I'm not sure how all of the tiles are arranged on the globe - but I would start
with the framework, and decide how best to tile the surface.  Then when
rendering, the scene file only renders what is in view, and close enough to need
actual modeling.   Something like a view from space wouldn't need 8000 tiles -
you could do it like a soccer ball with 12 pentagons and 20 hexagons - or just
UV-map a sphere {}.  As you move in closer, the camera-globe distance determines
the model type and level of detail (LOD).
Then you can easily have 8000 tiles worth of renderable placeholders with
location markers, text for what you'd like to see there, comments in the code,
etc.  Missing tiles get a checkerboard or something to visually show that it's
missing.
I'd also institute a file naming system for easy version control, so that you
don't have to manually edit the parent pov file or parent inc file when changes
are made, but it's easy to see which one is newest.   "Tile 8000_2020_04_13.inc"
or something like that, and then you can include Tile 8000_*.inc" without
issues.
Date: 14 Apr 2020 03:55:01
Message: <web.5e956b3c99da5e40827e2b3e0@news.povray.org>
hi,
> good.
agree with this.  ~70% of the surface is ocean, so a lo-res representation of
that alone would lead to significant savings.
and the "Level Of Detail" point too is good.  how many people would want to zoom
in closely on deserts, or uninhabited areas in general?
regards, jr.
Date: 14 Apr 2020 05:28:21
Message: <5e958235$1@news.povray.org>
Hi(gh)!
But how to do this - as the reliefs are not "flat", but follow Earth's
curvature?
Yadgar
Date: 14 Apr 2020 06:00:00
Message: <web.5e95891799da5e40827e2b3e0@news.povray.org>
hi,
> curvature?
o you could "mix" tiles.  using the 30m where detail matters, using 90m for
other areas.
o you could pre-process each ocean etc tile, averaging out N neighbouring
pixels.
o you could reduce the #vertices per mesh.  for instance, if the mesh data is
stored in GTS format, there's a tool ('gtstricutter' (have not used it (yet)))
which can remove triangles according to some constraints you supply on the
command-line.
there will any number of other ways too, I guess.
regards, jr.
Date: 14 Apr 2020 06:22:43
Message: <5e958ef3$1@news.povray.org>
Hi(gh)!
> other areas.
> pixels.
> command-line.
Most likely, I will provide the data as heightfields rather than mesh2
objects...
Yadgar
Date: 14 Apr 2020 06:50:01
Message: <web.5e95947899da5e40fb0b41570@news.povray.org>
> Hi(gh)!
> curvature?
> Yadgar
http://www.econym.demon.co.uk/isotut/combine.htm
See:  "Addition and Subtraction"
You have latitude, longitude, and elevation.
Just modulate the elevation (radius)
A common way to approximate spheres is triangle subdivision, bumping the new
central vertex "out" to the radius.
http://news.povray.org/povray.binaries.images/thread/%3C57b60bd1$1@news.povray.org%3E/
So you'd just construct a base with a spherical curve (oblate spheroid geodesic)
and then add the height to the base.   "easy".  ;)
Date: 14 Apr 2020 13:36:14
Message: <5e95f48e$1@news.povray.org>
And, than base can be a simple, boring, old sphere primitive with a
water texture. To get the oblate shape, just use scale<1.003, 1, 1.003>
with the Y axis coincident with the polar axis.
