POV-Ray : Newsgroups : povray.binaries.images : Apparent circular pattern of scratches Server Time
19 May 2024 10:00:05 EDT (-0400)
  Apparent circular pattern of scratches (Message 11 to 17 of 17)
Subject: Re: Apparent circular pattern of scratches
Date: 26 Jan 2019 09:40:01
Message: <5c4c7141$1@news.povray.org>
Am 26.01.2019 um 09:56 schrieb Thomas de Groot:
> Proof of concept using different finishes for surface and scratches.
> Still in flux...
I think we're getting somewhere.
Date: 26 Jan 2019 13:55:03
Message: <web.5c4cac675e3f44509c5d6c810@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> Hello,
> here is my attempt, using a layered texture and an imagefile for the scratches
> (similar to what Thomas posted here -
http://news.povray.org/povray.advanced-users/message/%3C5c4970bb%40news.povray.org%3E/#%3C5c4970bb%40news.povray.org%
3E
> material {
>         texture {
>                 pigment {color srgb <0.9284,0.9016,0.8678>}
>   normal {
>                         average
>                         normal_map {
>                                 [1      bump_map {png "scratches"}
>                                         bump_size -1
>                                         bump_size -1
>                                         rotate x*90
>                                         bump_size -1
>                                         rotate z*90
>                         accuracy 0.003
>                 finish {
>                         ambient 0
>                         diffuse 0.1
>                         specular 1
>                         roughness 0.0003
>                  phong 0.5
>                         phong_size 10
>                         brilliance 3
>                         reflection {0.6, 1 fresnel on metallic}
>                         conserve_energy
>         texture {
>   pigment {color srgbf <0.96,0.965,0.975,0.99/0.8>*0.8}
>   finish {
>           ambient 0
>           diffuse 0.05
>           reflection {0, 1 fresnel on}
>           conserve_energy
>           specular albedo 0.5
>                         roughness 0.001
>                         brilliance 7
>         interior {ior 3.64}
>         scale 1
>  Reorient_Trans (z, 1)
> Norbert
I like that, fine scratches or scuffed. Great how it follows the curvatures and
reflected light.
Any criticism I can think of would be that some lines appear to radiate outward
from the lit areas, showing up as bright as the other, non-radial lines. Which
is what was mentioned before about the original idea, so I wonder how that
directional condition could be achieved? Seems like a polarization effect needed
to do that anyhow.
Date: 26 Jan 2019 15:05:01
Message: <web.5c4cbc425e3f4450765e06870@news.povray.org>
> > Hello,
> > Norbert
Holy crap.  :O
> reflected light.
I think that's an important part of the effect - the halo of concentric
scratches.
> to do that anyhow.
Yeah - I'm also still very curious as to what gives rise to that selective
effect IRL.  I'd be tempted to predict that only a series of oriented lines
would reflect strongly - not a circular pattern.  I mean, it's not like
completely random scratches adopt a circular pattern - so it must necessarily be
a purely optical effect.
Date: 27 Jan 2019 02:37:49
Message: <5c4d5fcd$1@news.povray.org>
On 26-1-2019 14:10, ingo wrote:
>> Still in flux...
> The scratches are based on the random sticks? If so, try uses extremely
> stretched boxes as sticks to get a sharper 'impression'.
No, on a bump_map. Not a very subtle one I must say but sufficient for
the purpose.
> Maybe use a gradient 'depth map' texture on the sticks, the scratichg edge
> rgb 1 and going to rgb 0 to the other edges. Vary the rgb 1 on the sharp
> edge for depth variation.
That is a good alternative for making scratch maps, apart from simply
downloading them from the web :-)
> Render it with orthocam and a light at the camera location.
> ingo
Date: 27 Jan 2019 02:52:48
Message: <5c4d6350@news.povray.org>
>>> Hello,
>>> Norbert
> Holy crap.  :O
I agree. The important thing is to use a bump_map of some quality.
>> reflected light.
> scratches.
See image attached. Playing with different bump_maps and strength of the
bump_size.
>> to do that anyhow.
Maybe, that comes from the fact that the scratches are not very linear,
more "curvy" as it were. I noticed that also with different bump_maps.
The more linear the scratches are, the more the effect is visible.
It /is/ an optical effect of course, based imho on the strength of
incident light reflecting from the scratch surfaces. The closer the
incident light angle is to 90 degrees with regard to (part of) the
scratch surface, the stronger the scratch reflects. Inversely, the
scratch will hardly or not light up when the incident light angle is
very low. The cumulation of strongly reflecting scratches will dominate
the view in the end, giving rise to the optical illusion.
Download 'circular scratches_test.png' (427 KB)
Preview of image 'circular scratches_test.png'
Date: 27 Jan 2019 07:15:01
Message: <web.5c4d9ffb5e3f44501fbfafc10@news.povray.org>
I found a povray file to get the bump_map. Perhaps somebody knows the origin. My
only contribution is an aoi texture as default.
/* scratches2 */
// +fn16 Output_File_Name=d:\images\ +w4096 +h4096
#version 3.7;
global_settings {
        #declare a_g = 2.2;
        assumed_gamma a_g
        max_trace_level 16
        noise_generator 3
        orthographic
        location -5*z
        look_at 0
        right 40*x
        up 40*y
/*#default {
                        bozo
                        scale 0.2
                        color_map {
                                [0      rgb 0.5]
                                [1      rgb 1]
                finish {ambient 1}
#default {
                        aoi
                        color_map {
                                [0      srgb 1]
                                [0.5    srgb 0]
                                [1      srgb 1]
                finish {ambient 1}
#include "transforms.inc"
#declare I = seed (1);
#declare ang = 0;
#while (ang < 360)
        #declare num = 20+20*rand (I);
        #declare i = 0;
        #while (i < num)
                #declare px = no;
                #declare nx = no;
                #declare r = 0.01+0.035*rand (I);
                #declare s = 2+10*rand (I);
                #declare _x = -20+40*rand (I);
                #declare _y = -20+40*rand (I);
                sphere {
                        0, 1
                        scale <r,0.5,r>
                        scale <1,s,1>
                        rotate ang*z
                        translate <_x,_y,0>
                #if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z
translate _x*x}).x > 40 | vtransform (-0.5*y, transform {scale <1,s,1> rotate
ang*z translate _x*x}).x > 40)
                        #declare px = yes;
                        sphere {
                                0, 1
                                scale <r,0.5,r>
                                scale <1,s,1>
                                rotate ang*z
                                translate <_x-40,_y,0>
                #else
ang*z translate _x*x}).x < 40 | vtransform (-0.5*y, transform {scale <1,s,1>
rotate ang*z translate _x*x}).x < 40)
                                #declare nx = yes;
                                sphere {
                                        0, 1
                                        scale <r,0.5,r>
                                        scale <1,s,1>
                                        rotate ang*z
                                        translate <_x+40,_y,0>
translate _y*y}).y > 40 | vtransform (-0.5*y, transform {scale <1,s,1> rotate
ang*z translate _y*y}).y > 40)
                        sphere {
                                0, 1
                                scale <r,0.5,r>
                                scale <1,s,1>
                                rotate ang*z
                                translate <_x,_y-40,0>
                        #if (px)
                                sphere {
                                        0, 1
                                        scale <r,0.5,r>
                                        scale <1,s,1>
                                        rotate ang*z
                                        translate <_x-40,_y-40,0>
                        #else
                                #if (nx)
                                        sphere {
                                                0, 1
                                                scale <r,0.5,r>
                                                scale <1,s,1>
                                                rotate ang*z
                                                translate <_x+40,_y-40,0>
                #else
ang*z translate _y*y}).y < 40 | vtransform (-0.5*y, transform {scale <1,s,1>
rotate ang*z translate _y*y}).y < 40)
                                sphere {
                                        0, 1
                                        scale <r,0.5,r>
                                        scale <1,s,1>
                                        rotate ang*z
                                        translate <_x,_y+40,0>
                                #if (px)
                                        sphere {
                                                0, 1
                                                scale <r,0.5,r>
                                                scale <1,s,1>
                                                rotate ang*z
                                                translate <_x-40,_y+40,0>
                                #else
                                        #if (nx)
                                                sphere {
                                                        0, 1
                                                        scale <r,0.5,r>
                                                        scale <1,s,1>
                                                        rotate ang*z
                                                        translate
<_x+40,_y+40,0>
                #declare i = i+1;
        #declare ang = ang+20;
Norbert
Date: 28 Jan 2019 02:36:04
Message: <5c4eb0e4$1@news.povray.org>
Ah! Thank you indeed. For a moment I thought it could be Steve Paget as
I have a bump_map with that name from him, but that is a very different
image, not related. The question remains unanswered for now.
