POV-Ray : Newsgroups : povray.binaries.images : "Position Finder" results Server Time
29 Jun 2024 05:48:26 EDT (-0400)
  "Position Finder" results (Message 25 to 34 of 34)
Subject: Re: "Position Finder" results
Date: 3 Oct 2018 10:15:00
Message: <web.5bb4ce4e813dde7ac437ac910@news.povray.org>
I think if you look at:
http://www.povray.org/documentation/view/3.7.1/246/
you'll see several things.
1. The +/- 0.5 range for x and y
2. camera angle is determined by changing the length of the direction vector.
3. I think this relates to the error you see, and it's decrease with smaller
camera angles.
Here's my crappy reasoning-by-analogy in the absence of the code in front of me,
and on short notice:
When you swivel a line through pivot point, a small change at the end results in
a large change in the other end when the pivot point is close ( small direction
vector / wide angle)
When you pull the camera way back, you have to make very large changes in the
position to have the same effect - or put the other way - any changes at the
other end are very small (your errors) for the same amount of change.
Think about that in terms of any trace() results and calculations based on those
- they're like angles, and like levers they can magnify (by integers or
fractions) the results.
I don't think you're/we're going to get very far fiddling with code or working
backwards from the existing macro.
Write some code to model a default camera scene, and then play with point
locations and their projection onto the z=1 plane.
Then you can work from there.
What you do (and understand) in a forward, stepwise manner, you can follow
stepwise, backwards to see what calculations you need to to go from screen
coordinates to 3D vector coordinates.
Date: 3 Oct 2018 10:15:01
Message: <web.5bb4ceb3813dde7ac437ac910@news.povray.org>
_See_ what I mean here:
http://news.povray.org/povray.binaries.images/message/%3Cweb.587ce70b1652a4dcc437ac910%40news.povray.org%3E/#%3Cweb.587
Date: 3 Oct 2018 15:10:02
Message: <web.5bb513d4813dde7ac437ac910@news.povray.org>
OK, so here's a rudimentary object position / surface normal finding scene I
wrote from scratch, which shows the back-and-forth conversion of screen position
coordinates and 3D scene object coordinates.
Wrote 2 "shotgun" macros to pepper the target object with trace() calls to see
about the "underside" issue.
Play around with it, let me know questions, comments, improvements as always.
#version version;
#global_settings {assumed_gamma 1.0}
light_source {
 <0.5, 0.5, -1>
 color White
 fade_distance 20
 fade_power 2
#declare Default_location = <0, 0, 0>;  // 2.3.1.1.1 Location and Look_At
#declare Default_direction = <0, 0, 1>;  // 2.3.1.1.4 The Direction Vector
#declare Default_right = <1.33, 0, 0>;  // 2.3.1.1.6 Aspect Ratio
#declare Default_up = <0, 1, 0>;   // 2.3.1.1.6 Aspect Ratio
#declare Default_sky = <0, 1, 0>;   // 2.3.1.1.2 The Sky Vector
// When you specify the angle, POV-Ray adjusts the length of the direction
vector accordingly.
// The formula used is direction_length = 0.5 * right_length / tan(angle / 2)
// where right_length is the length of the right vector.
// You should therefore specify the direction and right vectors before the angle
keyword.
#declare Default_angle = 0;
// direction_length = 0.5 * right_length / tan(angle / 2)
// The look_at modifier should almost always be the last item in the camera
statement.
// If other camera items are placed after the look_at vector then the camera may
not continue to look at the specified point.
#declare Default_look_at = <0, 0, 1>;  // 2.3.1.1.1 Location and Look_At
#declare Aspect = image_width/image_height;
#declare A = <Aspect, 1, 1>;
 location Default_location
 direction Default_direction
 //right Default_right
 up  Default_up
 look_at Default_look_at
#declare TopRight = <0.5, 0.5, 1>;
#declare Far = 12;  // the far plane of a defined view frustum
// The diagonal distance from the Image Plane to a Far view frustum corner is
greater than the straight distance
#declare DiagonalLength = vlength (<(Far/2)*Aspect, (Far/2), Far> - TopRight);
// Frame the canvas
#declare Corner = array [4] {<-0.5, 0.5, 1>, <0.5, 0.5, 1>, <0.5, -0.5, 1>,
<-0.5, -0.5, 1>}
#declare Frustum = union {
#for (N, 0, 3)
 sphere {Corner [N] * A 0.01 pigment {Gray10}}
 sphere {Corner [N] * A * DiagonalLength 0.01 * DiagonalLength * 1.1 pigment
{Green}}
 // Here you can see that I just multply the sphere center's vector by a scalar:
the DiagonalLength
 // To give the rear sphere the same _apparent_ size (MOA), the radius is
multiplied by the distance
 // (Twice as far away needs to be twice as big to appear the same size)
 // Since you wouldn't be able to see one sphere behind the other, the radius is
increased by a factor of 1.1
object {Frustum}
#macro Get3DPosition (Xpos, Ypos, Target, Mark)
 #declare Xpos = (Xpos - 0.5) * Aspect;
 #declare Ypos = -1*(Ypos - 0.5);
 #declare NormalVector = <0, 0, 0>;
 #declare From = <0, 0, 0>;
 #declare TraceThrough = <Xpos, Ypos, 1> - From;
 #declare PositionIn3D = trace (Target, From, TraceThrough, NormalVector);
 #if (vlength (NormalVector) != 0)
  cylinder {PositionIn3D, PositionIn3D+NormalVector, 0.01 pigment {Green}}
 // Indicate trace point
 #if (Mark)
  sphere {<Xpos, Ypos, 1> 0.005 pigment {Green}}
 #end // end if Mark
#end // end macro
#macro Convert2ScreenPos (Pos3D)
 #declare ScreenPosX = (Pos3D.x / Pos3D.z)/Aspect+0.5;
 #declare ScreenPosY = -1*((Pos3D.y / Pos3D.z)-0.5);
 #declare ScreenPos = <ScreenPosX, ScreenPosY>;
 ScreenPos
// define an object
#declare Radius = 0.25;
#declare Object = sphere {<3, 5, 12> Radius pigment {Red}}
object {Object}
Get3DPosition (0.696, 0.094, Object, yes)
// Find the center of the object
#declare Min = min_extent (Object);
#declare Max = max_extent (Object);
#declare Center = Min + (Max-Min)/2;
#macro CircularShotgun (Target)
 #for (Angle, 0, 2*pi, 2*pi/12)
  #for (Rad, 0.9, 0.1, -0.1)
   #declare Offset = Angle + (2*pi/12 * Rad);
   #declare SP = Convert2ScreenPos (Center+<Rad*Radius*cos(Offset),
Rad*Radius*sin(Offset), 0>);
   #declare SPX = SP.x;
   #declare SPY = SP.y;
   Get3DPosition (SPX, SPY, Target, yes)
#end // end macro CircularShotgun
#macro BBShotgun (Target)
 #declare MinT = min_extent (Target);
 #declare MaxT = max_extent (Target);
 #declare Xrange = (MaxT.x - MinT.x);
 #declare Yrange = (MaxT.y - MinT.y);
 #debug concat(str (MinT.x, 0, 5), "\n")
 #debug concat(str (MaxT.x, 0, 5), "\n")
 #debug concat(str (Xrange, 0, 5), "\n")
 #for (Xvals, MinT.x, MaxT.x, Xrange/10)
  #for (Yvals, MinT.y, MaxT.y, Yrange/10)
   #debug concat(str (Xvals, 0, 5), "\n")
   #declare SP = Convert2ScreenPos (<Xvals, Yvals, Center.z>);
   Get3DPosition (SPX, SPY, Target, no)
#end // end macro BBShotgun
//CircularShotgun (Object)
BBShotgun (Object)
// end file
Date: 3 Oct 2018 15:45:01
Message: <web.5bb51b0a813dde7aa47873e10@news.povray.org>
> you'll see several things...
Oh my GOD, that drawing is all WRONG!! If the 'position' is inside my eyeball,
and my eyeball shoots a ray toward my computer screen, it's at an ANGLE, and
then when the ray enters the screen and goes inside my computer, it's still at
an ANGLE, and, oh my GOD, nothing works right, and, and...
:-P
My feeble attempt at humor for today. "You know you've been raytracing too long
when..."
Funny factoid: As I continue working with the code and making little incremental
advances (while removing bits and pieces that are no longer needed), I see that
I'm already inching closer and closer to re-making the code from scratch. But
currently in a *slow* hit-and-miss fashion  :-/  I shall ponder on your sage
advice and conceptual suggestions ;-)
Another tidbit: Up until now, I've spent the VAST majority of time trying to
work out that stubborn 'normal' business from trace(...)-- but the real point of
the code is finding a POSITION (the returned translation.) The normal-based
rotations are more like pretty window-dressing-- albeit very nice window
dressing. I need to concentrate on the POSITIONING accuracy for awhile.
Date: 4 Oct 2018 03:19:00
Message: <5bb5bee4$1@news.povray.org>
On 3-10-2018 15:17, Kenneth wrote:
>> So, I manage to get the arrow on the rod by tweaking:
>> #local dir_y  = vaxis_rotate (lookat-cam_loc, vcross (cam_d, cam_up),
>> (0.483-screen_y_position*0.01)*cam_ang/image_width*image_height);
>> #local dir_xy = vaxis_rotate (dir_y, cam_up,
>> (0.535-screen_x_position*0.01)*cam_mirror*cam_ang);
>> replacing the 0.5 value by respectively 0.483 in dir_y and 0.535 in dir_xy.
>> Of course, this is entirely by just dumb trial and error, and I highly
>> doubt if it is significant. I wonder now if it holds for other scenes...
>> tests to do...
> Yeah, I've found that tweaking *something* (one of several different things
> actually) can put the arrow where it's supposed to be. But I suspect that your
> values would need to change, when using a different camera angle? My own 'tweak
> tests' have shown that the code as-is has the ideal overall values in its
> arrow-placement equations-- but only at the most extreme telephoto/zoom camera
> angle. As that angle value climbs toward 90 (more and more wide-angle), the
> arrow position just gets progressively worse... and my own value-compensation
> tweaks have to get larger, to correct it. Very frustrating so far.
> BTW, what CamAng did you use for this test? 80?
Yes, 80. You know, I was just beating the bush and whistling a merry
tune, waiting for anything (a miracle?) to happen ;-) Totally crap of
course.
> On a brighter note:
> I've discovered a simple fix for ALL of the traced 'normal' problems that I've
> been dealing with!
> To wit: After spending WAY too much time trying to come up with workarounds, I
> replaced Norbert's
> rotate <rx,0,rz>
> with
> Point_At_Trans(Norm) // a macro
> from "functions.inc"
> That's it!
Indeed. I forgot about that one. See below for further thoughts.
> Well, not quite: Even though the ARROW'S 'normal' orientation now looks great
> all the time, the found rotation (in the #debugged output and on-screen) is no
> longer correct-- because rotate <rx,0,rz> no longer agrees with whatever
> Point_At_Trans is doing behind-the-scenes.
One may wonder what we really need. I personally believe we do not need
the rotation values resulting from the rx and rz calculations at all. We
use this macro (1) primarily to get an accurate 3D position on a given
surface; (2) possibly, we also need an orientation to the surface, thus
we need the normal. With Point_At_Trans(Norm) we can then orient our
object accurately on the surface.
> I haven't yet found a way to get at Point_At_Tran's hidden inner values, to USE
> for the rotation.  Looking at its code (and at the other macros that it requires
> in order to work), there's... a MATRIX.  :-(  I refuse to be beaten, though! Out
> of desperation, I'm now *trying* to work out a way to turn a normal directly
> into a set of rotations-- at least in two axes--that I can use to bypass
> Point_At_Trans AND rotate <rx,0,rz> altogether.
I think: forget about this. No need for this.
Date: 4 Oct 2018 03:34:50
Message: <5bb5c29a$1@news.povray.org>
Yes, of course. I new it was fundamental (but always push at the
fundamentals ;-) ). Had to be reminded.
Indeed. It is the way in which Gilles Tran's visibility test macro is
made operational in a given scene.
> camera angles.
probably yes.
That seems reasonable indeed. I agree.
Date: 4 Oct 2018 03:53:19
Message: <5bb5c6ef$1@news.povray.org>
>>> dir_xy.
>>> tests to do...
>> things
>> that your
>> own 'tweak
>> wide-angle), the
>> value-compensation
> course.
>> On a brighter note:
>> that I've
>> been dealing with!
>> workarounds, I
>> replaced Norbert's
>> rotate <rx,0,rz>
>> with
>> That's it!
After testing, I think you will get more reliable results using
Reorient_Trans(y,Norm) instead. Otherwise the arrow text has a tendency
to rotate around the original y axis.
Btw, not in functions.inc but in transforms.inc ;-)
Date: 4 Oct 2018 11:15:00
Message: <web.5bb62d9e813dde7aa47873e10@news.povray.org>
You're right!
MUCH better. I had never noticed the difference before. (Point_At_Trans had
always been my 'go-to' macro for this kind of thing; I assumed that they both
operated the same way.) Thanks!
OOPS.  Correct again.
Date: 4 Oct 2018 13:05:01
Message: <web.5bb64732813dde7aa47873e10@news.povray.org>
[off-topic]
That little suggestion of yours has actually cleared up a long-standing mystery
for me. Having assumed that Point_At_Trans and Reorient_Trans produced the same
results, I had always used the former, for normals found on the surface of a
sphere (it just seemed easier)-- with the result being that my placed object
there rotated 90-degrees every now and then, relative to the surface's own
normal-- specifically, when the traced point crossed the border of
triangular-shaped 'quadrants' on the sphere surface. (It also occurs on the dips
and undulations of a height_field.)
I thought that this was due to a natural ambiguity of the found normal. But
Reorient_Trans doesn't perform that un-wanted rotation, as I see now. Excellent!
Date: 5 Oct 2018 02:38:24
Message: <5bb706e0$1@news.povray.org>
> [off-topic]
Thanks for this little insight into working processes. From my side, I
have always used Reorient_Trans instead of Point_At_Trans, probably for
the reasons you mention, through the advice of somebody else, like
usually happily happens in these ng's. The descriptions in the docs are
the shortest possible, but it tells nonetheless the difference in
concept from which one can understand the behaviour, with a bit of luck.
Maybe this is a little bit clearer:
http://www.f-lohmueller.de/pov_tut/trans/trans_470e.htm
