POV-Ray : Newsgroups : povray.binaries.images : uv_mapping for cylinder, disc, cone & lemon Server Time
28 May 2024 23:21:32 EDT (-0400)
  uv_mapping for cylinder, disc, cone & lemon (Message 1 to 10 of 16)
Subject: uv_mapping for cylinder, disc, cone & lemon
Date: 3 Sep 2018 15:12:27
Message: <5b8d879b@news.povray.org>
user control is achieved by adding "uv_mapping direction" in cylinder,
disc, cone and lemon
code available at
https://github.com/LeForgeron/povray/commit/83a269c227ab08e6e426670f30ed18a524360b17
first point of cone is always uv(0,0), even if the internal code later
performs an inversion.
Disc center or inner circle is v(0), outside is v(1)
cone { -y * 0.5, 0.5, 0.5 * y, 0.25  uv_mapping x texture { Verso }
transform{ Trans }  translate VS* y + 6 * x }
cylinder { -y * 0.5, 0.5 * y, 0.5 uv_mapping x  texture { Verso }
transform { Trans } translate 6 * x }
lemon
  -0.5 * y, .5, 0.5 * y, .25, 1.5 uv_mapping x texture
    Verso
  } transform { Trans } translate - VS* y + 6 * x
ovus { 0.5, 0.25 distance 1 radius 2.5 texture { Verso }
transform { Trans } translate - VS * y}
disc { 0, -y, 1, 0.125 uv_mapping x texture { Verso } transform { Trans
} translate +VS*y }
sphere { 0, 0.5 texture { Verso }  transform { Trans}  translate - VS* y
- 6 * x}
torus { 0.65, 0.25 texture { Verso }  transform { Trans } translate - 6 * x}
box{ -0.5, 0.5  texture { Verso } transform { Trans }  translate VS* y -
6 * x }
box { 0, <1, 1, 0> texture { Flat }  scale 3 translate - 3/2 * x - y }
Download 'refimguvmapping.png' (347 KB)
Preview of image 'refimguvmapping.png'
Subject: Re: uv_mapping for cylinder, disc, cone & lemon
Date: 3 Sep 2018 19:21:06
Message: <5b8dc1e2$1@news.povray.org>
Am 03.09.2018 um 21:12 schrieb Le_Forgeron:
> code available at
I haven't taken a closer look at it yet, but I presume the UV mapping is
oriented such that the seam lies in the half-plane defined by the axis
of rotation and the vector specified after `uv_mapping`?
That's the parameterization I would have suggested, too.
However, I'm not happy with the syntax, as `uv_mapping` without any
parameter is already a valid general object modifier, which allows to
turn on UV mapping in the object rather than in the texture.
That modifier could be hacked to allow for an optional vector parameter
when the object is a cylinder, cone or lemon, but that would indeed be
rather... hackish.
Date: 4 Sep 2018 07:28:20
Message: <5b8e6c54$1@news.povray.org>
>> code available at
Exactly !
> rather... hackish.
Oh, I didn't notice uv_mapping was an object modifier, and not a pattern
(texture/pigment/... ) only.
Might have to introduce a new keyword then, for that purpose.
My current problem is adding such rotation of uv in sphere_sweep: it is
far simpler for sphere_sweep to get a float between 0 and 1 for that
purpose... unless I drop the current computation of the first mapping
which use the plane of the first two non-colinear segment for setting
the current origin.
So, one or two keywords to find, meaningful... and short, but not ambiguous.
Date: 4 Sep 2018 13:16:15
Message: <5b8ebddf$1@news.povray.org>
> ambiguous.
And the tie is now between:
* **direction**, as used in camera and rainbow
* **orientation**, as used in warp (cylindrical, spherical, toroidal)
Any preferences ?
Date: 4 Sep 2018 16:45:01
Message: <web.5b8eee896842dff8c437ac910@news.povray.org>
> > ambiguous.
> Any preferences ?
Do you want to [re]use other keywords?
What about axis, or alignment, or maybe as clipka said - half_plane ?
Date: 5 Sep 2018 00:23:56
Message: <5b8f5a5c$1@news.povray.org>
Am 04.09.2018 um 19:16 schrieb Le_Forgeron:
>> ambiguous.
I'm looking at the warps' "orientation" parameter right now, and it
gives me headaches. What is it even? A vector in pigment space to pick a
different slice of the pigment? A vector in shape space to orient the
torus/sphere/cylinder?
> Any preferences ?
If "orientation" in warps does exactly(!) the same, that would be the
parameter name to use.
Otherwise, there are probably better names to pick. "uv_orientation", maybe?
Date: 5 Sep 2018 00:24:53
Message: <5b8f5a95$1@news.povray.org>
Am 05.09.2018 um 06:23 schrieb clipka:
... or "uv_seam_direction"?
Date: 5 Sep 2018 01:27:53
Message: <5b8f6959@news.povray.org>
You're the one who's supposed to know!
:D
Date: 5 Sep 2018 02:22:37
Message: <5b8f762d$1@news.povray.org>
>>> ambiguous.
>> Any preferences ?
If it can match an existing keyword and its concept, it make:
1. less concept to explain
2. less work to code
3. less keyword to remember
4. less confusion in the end
The hell would be a SDL with every subpart having its own private set of
keywords, because "it was not exactly the same concept, nor the same
thing, so it has to be a dedicated keyword."
Imagine cylinder and sphere declaration using keywords:
cylinder{ disc_center_base_position <v>, disc_center_apex_position <w>,
radius_of_cylinder r }
sphere { center_sphere_position <v>, radius_of_sphere r }
That's not user-friendly.
TBH, I did not even remembered that there was a rainbow in Pov-Ray.
Date: 5 Sep 2018 03:03:50
Message: <5b8f7fd6$1@news.povray.org>
>>> ambiguous.
For me it's the dist_exp which is more obscure: it's explained for 0,
but what are other value ? (btw, a "box" (2D) <0,0> to <1,1> extended to
infinity along orientation... isn't that a square and a normal to
select... what ? On second reading, the box is infinite along
orientation and a square in perpendicular directions.
And what is that "distance" in the text ?
Yet another case of: better open the source to understand.
At least, I understand "planar", but there is no picture for it !
And "cubic", nice cubic !
>> Any preferences ?
it would rather be u_orientation, or u_something, as v is already set by
the shape and its symetry. u_zero ?
"second_base_vector_of_half_plane_with_symetry_axis_where_u_is_zero" is
far too long.
I would like to avoid more than one "_" if possible (so u_zero_direction
is one word too long). Two words is nice (look_at, point_at), but three
or more words become painful (yet, I added rational_bezier_patch
elsewhere, so it's not so wrong, just if it could be avoided).
Oh, and for sphere_sweep, it would be the direction of u=0 for v=0, yet
later along the sweep it would turn for continuity.
Native speakers, you're welcome !
