POV-Ray : Newsgroups : povray.binaries.images : TBTFH 2018 status Server Time
24 Jun 2026 22:21:13 EDT (-0400)
  TBTFH 2018 status (Message 21 to 25 of 25)
Subject: Re: TBTFH 2018 status
Date: 9 Sep 2018 12:55:01
Message: <web.5b954f4fabd6e8dbb0d4fc1e0@news.povray.org>
hi,
> Am 08.09.2018 um 13:45 schrieb jr:
> > now I would like to find out how to increase the translucence of the rhomboids.
> Are you aiming for semi-transparency or diffuse translucency?
translucent I guess.  I replaced (in BGimeno's code) the rgb colour returned
from  the CW_angle macro with a rgbt (with fixed .45 transmit, see image) but
that results in increased transparency.  the effect I'd like to achieve is more
like very, very thin mother-of-pearl.
regards, jr.
Download 'snip.png' (349 KB)
Preview of image 'snip.png'
Date: 9 Sep 2018 13:00:01
Message: <web.5b955088abd6e8dbb0d4fc1e0@news.povray.org>
hi,
> > regards, jr.
> Look in the last line of the CW_angle macro, I deactivated the values
> ​​of transparency and filters to avoid warning messages.
> The code is a little clumsy and needs many fixes to avoid duplicate code here
> and there. Patience.
thanks.  I put a '#debug concat' inside the macro and found that both filter +
transmit stayed at 0.0 throughout.  that led me to use a (fixed) transmit value
as part of a 'rgbt' colour.  see reply to clipka for image.
> BGimeno
> Pd. Don't call them rhomboids, they are squares subjected to great tension. Very
> sensitive polygons.
:-)  "square" too is full of connotations, how about "retro oblong"?  ;-)
regards, jr.
Date: 9 Sep 2018 13:08:41
Message: <5b955399$1@news.povray.org>
Am 09.09.2018 um 18:50 schrieb jr:
> hi,
Then - presuming your torus thingumajig is using non-solid geometry -
you want backside diffuse illumination, and maybe one or two more levels
of radiosity recursion.
To enable backside diffuse illumination, use the two-parameter version
of `diffuse`:
    finish { diffuse FRONT,BACK }
where FRONT is how much light is reflected to the illuminated side, and
BACK is how much light is transmittend to the other side. The sum should
be smaller than than 1.0 for realistic materials.
Date: 10 Sep 2018 19:25:16
Message: <5b96fd5c@news.povray.org>
>> hi,
> of `diffuse`:
For mother-of-pearl, you also need a fair amount of iridescence. Maybe
something in the 0.4 .. 0.6 range.
Date: 11 Sep 2018 04:50:01
Message: <web.5b9780acabd6e8dbb0d4fc1e0@news.povray.org>
hi,
> > ... like very, very thin mother-of-pearl.
"my" torus.  lol.  I would not be able to create anything like it -- if my life
depended on it.
> of `diffuse`:
only had one quick try so far (got a bit paranoid last night when the CPU temp
thanks.  I'll add this "into the mix" next run.
regards, jr.
