POV-Ray : Newsgroups : povray.binaries.images : Paris by night Server Time
11 May 2024 04:58:23 EDT (-0400)
  Paris by night (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Paris by night
Date: 20 Aug 2018 17:33:29
Message: <5b7b33a9$1@news.povray.org>
On 8/20/2018 7:38 AM, Thomas de Groot wrote:
> The bloom came out a bit stronger than I intended, especially in
> relation to the street media. I had noted this for the future state. :-)
> Render time is so long that I postpone any new version to 2020 at least...
How many cores does your CPU have, now? Computer GHz have sort of
stagnated, and CPUs with more than 6 cores can cost as much as a typical
PC all by themselves. Also, you may want to wait until mitigations for
Meltdown and Spectre have made it into new CPU architectures.
Mike
Date: 20 Aug 2018 18:50:01
Message: <web.5b7b45714fa7fe4f458c7afe0@news.povray.org>
Meh.   Wait a little while, and you may get it done faster than you think.
http://www.jbis.org.uk/paper.php?p=2006.59.239
Date: 20 Aug 2018 20:30:00
Message: <web.5b7b5cbf4fa7fe4fc661c7ca0@news.povray.org>
The atmosphere is good. Lighting is usually the most difficult to get right,
especially in scenes like this, with not much light.
Well done Thomas, I could learn a thing or two here.
Ton.
Date: 21 Aug 2018 02:42:03
Message: <5b7bb43b$1@news.povray.org>
>> least...
Intel i7-2600, 64-bit, 3.40 GHz, 4 cores/8 threads (6 used for the render).
Date: 21 Aug 2018 02:49:01
Message: <5b7bb5dd$1@news.povray.org>
LOL Yes indeed! However, the main reason is that I become tired of the
scene and want to lay it on the shelf for a while. I am going to print
this version and hang it on my wall. Time for scrutiny has started now.
Date: 21 Aug 2018 03:06:57
Message: <5b7bba11$1@news.povray.org>
> Cheers
> Ton.
Hartelijk dank!
Initially, the most difficult was to backward engineer from the
photograph. Camera position/orientation, lens characteristics, all that
is unknown from the start. Invaluable help came from the use of Tim
Nikias' Glare macros which allow for a background image in the scene.
That way I could reconstruct more easily perspective and size of the
different street and building elements.
Lighting and media were/are the next pain in my right foot big toe. I am
still not done there although I get gradually closer to what I want.
Patience is the keyword.
Tim Nikias' site can be found here: http://www.nolights.de/index.html
However, I cannot find the Glare macros there anymore. Somebody any
idea? Tim?
Date: 21 Aug 2018 07:28:53
Message: <5b7bf775$1@news.povray.org>
> idea? Tim?
I found the Glare macros on Tim's old site, through the Wayback Machine:
https://web.archive.org/web/20031008070348/http://www.digitaltwilight.de:80/no_lights/download.html#Glare%20Macros
Interestingly, as there was a discussion not long ago here about an even
distribution of points on a sphere, Tim provides a macro to do just
that. Look for ESR, below the Glare macros.
Date: 23 Aug 2018 02:17:34
Message: <5b7e517e@news.povray.org>
On 20/08/2018 12:38, Thomas de Groot wrote:
> On 20-8-2018 12:28, Stephen wrote:
>> On 20/08/2018 08:24, Thomas de Groot wrote:
>>> I usually make several states of my work. This time, I revisited my
>>> entry for the March 2011 Challenge of the TC-RTC:
>>> http://tc-rtc.ideasintoreality.co.uk/imagenewdisplay/stills/index325.html
>>> Some minor changes and additions and a render performed with UberPOV
>>> (stochastic aa) instead of Megapov in the original. All in all,
>>> render time was in excess of 48 hours.
>>> In a few years time I probably shall render the next state. ;-)
>> I like the change in illumination around Cathy. I am not too sure
>> about the bloom around the street lamps. The pattern does not reflect
>> the mist at ground level.Also, I seem to remember that the bloom was
>> centred just in front of the lamp. It has been a long time since I
>> have been out in a night like that. :)
The render time is a passion killer. ;-)
Regards
Date: 16 Sep 2018 11:53:04
Message: <5b9e7c60$1@news.povray.org>
I would scale up the uncalmly sky a bit, maybe somewhere between 1.5 and 2.
The scene looks amazingly good, my congratulations.
I would add a very slight blur to almost the entire scene background,
but really just a very slight blur. Like dust (humidity) in the air
causes a slight blur.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 17 Sep 2018 02:31:54
Message: <5b9f4a5a@news.povray.org>
Possibly. However, I want to keep as close to the original as possible.
Thanks. Took a lot of sweat over the years ;-)
Again, keeping as close to the original as possible. However, I shall
keep this in mind for a hypothetical next version.
