I usually make several states of my work. This time, I revisited my
entry for the March 2011 Challenge of the TC-RTC:
http://tc-rtc.ideasintoreality.co.uk/imagenewdisplay/stills/index325.html
Some minor changes and additions and a render performed with UberPOV
(stochastic aa) instead of Megapov in the original. All in all, render
time was in excess of 48 hours.
In a few years time I probably shall render the next state. ;-)
Download 'paris la nuit_2018_sig.jpg' (234 KB)
Preview of image 'paris la nuit_2018_sig.jpg'
SCNR
https://imgur.com/oSL6pCA
Regards
I like the change in illumination around Cathy. I am not too sure about
the bloom around the street lamps. The pattern does not reflect the mist
at ground level.Also, I seem to remember that the bloom was centred just
in front of the lamp. It has been a long time since I have been out in a
night like that. :)
Regards
> night like that. :)
The bloom came out a bit stronger than I intended, especially in
relation to the street media. I had noted this for the future state. :-)
Render time is so long that I postpone any new version to 2020 at least...
How many cores does your CPU have, now? Computer GHz have sort of
stagnated, and CPUs with more than 6 cores can cost as much as a typical
PC all by themselves. Also, you may want to wait until mitigations for
Meltdown and Spectre have made it into new CPU architectures.
Mike
Meh. Wait a little while, and you may get it done faster than you think.
http://www.jbis.org.uk/paper.php?p=2006.59.239
The atmosphere is good. Lighting is usually the most difficult to get right,
especially in scenes like this, with not much light.
Well done Thomas, I could learn a thing or two here.
Ton.
>> least...
Intel i7-2600, 64-bit, 3.40 GHz, 4 cores/8 threads (6 used for the render).
LOL Yes indeed! However, the main reason is that I become tired of the
scene and want to lay it on the shelf for a while. I am going to print
this version and hang it on my wall. Time for scrutiny has started now.
> Cheers
> Ton.
Hartelijk dank!
Initially, the most difficult was to backward engineer from the
photograph. Camera position/orientation, lens characteristics, all that
is unknown from the start. Invaluable help came from the use of Tim
Nikias' Glare macros which allow for a background image in the scene.
That way I could reconstruct more easily perspective and size of the
different street and building elements.
Lighting and media were/are the next pain in my right foot big toe. I am
still not done there although I get gradually closer to what I want.
Patience is the keyword.
Tim Nikias' site can be found here: http://www.nolights.de/index.html
However, I cannot find the Glare macros there anymore. Somebody any
idea? Tim?
