POV-Ray : Newsgroups : povray.binaries.images : Smoothing bicubic_patchs. A pain. Server Time
20 May 2024 13:16:55 EDT (-0400)
  Smoothing bicubic_patchs. A pain. (Message 31 to 37 of 37)
Subject: Re: Smoothing bicubic_patchs. A pain.
Date: 22 Aug 2018 17:35:01
Message: <web.5b7dd65c9b869b6138c8b7240@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Here's another image where the cubes have been scaled in the U/V-directions by
> the lengths of the vectors used for reorienting them. (These vectors were
> created with the partial derivatives of the bivariate functions for the Bezier
> patch.)
Here's the same image with smaller dimensions.
Tor Olav
http://subcube.com
Download 'scaled_cubes_on_the_surface_of_a_bicubic_bezier_patch.jpg' (165 KB)
Preview of image 'scaled_cubes_on_the_surface_of_a_bicubic_bezier_patch.jpg'
Date: 22 Aug 2018 19:00:01
Message: <web.5b7deabb9b869b61458c7afe0@news.povray.org>
> Yes, that is possible. Just create 3 bivariate functions with the appropriate
> Bernstein polynomials and feed them to the parametric object. But you need
> patience for that...
Pffft.    Then forget it.  None of us Povvers have any patience for that kind of
thing..
We want the instant gratification of hand-coding 1776 lines of SDL that hands us
that first frame of a 3600-frame animation by the very next day!
> > Then, given a point <m, n> (or <u, v>) on the surface, one could place things ON
> > the surface of the patch.
> Yes, this image shows some white spheres and cylinders following a path in the
> UV-space on the surface of a NURBS-patch:
> http://dataduppedings.no/subcube/POV-Ray_Images/NURBS_Grid.jpg
Right - I've admired that one also.
I haven't yet gotten to coding any NURBS objects - but I'm sure it's an
inevitability   ;)
> See also the attached image where the I've put some sphere sweeps on a Bezier
> patch. (Notice that you can read out the radii for the sphere swept curves
> (0.06, 0.46 and 0.48) in the UV-mapped texture.)
Yes - that's a neat trick.  I can already see the 2 rotating sets of rolling
spheres in a bowl-shaped Bezier patch, oscillating in simple harmonic motion.
Very nice images as always - you surely have some great macros worked out in
order to be able to make all these "custom" renders in short order.
Date: 22 Aug 2018 19:05:00
Message: <web.5b7debbd9b869b61458c7afe0@news.povray.org>
> If you calculate the two partial derivatives (d/dU and d/dV) for each of the
> bivariate functions for a Bezier patch you can use these to reorient objects to
> align with the U-, V- and normal directions of the surface.
One more thing to ponder the full import of.
Just keep raising the bar.   :P
> This article contains some useful information about that:
https://www.scratchapixel.com/lessons/advanced-rendering/bezier-curve-rendering-utah-teapot/bezier-patch-normal
I do believe I've seen that one, but haven't had the time to fullly dissect and
digest it.
> The attached image shows cubes that are reoriented to align with the directions
> I mentioned above. It also shows a lot of splines that creates a grid on the
Well, assuming the patch is bounded by a unit sphere, then those are ---
subcubes.
:D
I have a vague notion that some of this might be accomplished via matrix
transforms.   But that's only a tenuous supposition at this point.
Care to make a MEDIA Bezier patch?  :)
Date: 23 Aug 2018 13:15:57
Message: <5b7eebcd$1@news.povray.org>
> inevitability   ;)
If you can find a modeller from which you can export the two
knot-vectors and the grid of of weighted control points, I would be very
interested.
Date: 30 Aug 2020 10:55:00
Message: <web.5f4bbce39b869b611f9dae300@news.povray.org>
> Last night, I dreamed about Klein Bottles. That would be a hellish job
> to model I guess. ;-)
Perhaps, but of course, someone has done it.   :)
http://t-kita.net/gnuplot_povrml/
I remembered this and figured I'd post you a link to the scene code.
http://t-kita.net/gnuplot_povrml/povray-demo/povray-demo3.pov
Date: 31 Aug 2020 02:26:40
Message: <5f4c9820$1@news.povray.org>
Op 30/08/2020 om 16:51 schreef Bald Eagle:
/Of course/ somebody did just that! Very nice; thanks for the links.
Date: 1 Sep 2020 02:35:33
Message: <5f4debb5@news.povray.org>
Op 31/08/2020 om 08:26 schreef Thomas de Groot:
Which got me thinking that, while the modelling of the Klein bottle
might be simple, the orientation of the face normals is not. My best
guess would be to switch those round at the point where the bottle
intersects itself. Modelling software (like Silo) don't like that. :-)
