POV-Ray : Newsgroups : povray.binaries.images : Distant Haze - How To? Server Time
23 May 2024 02:25:11 EDT (-0400)
  Distant Haze - How To? (Message 1 to 10 of 21)
Subject: Distant Haze - How To?
Date: 31 Mar 2018 06:49:14
Message: <5abf67aa@news.povray.org>
Hi, please have a look to the attached photo. It shows, here from orbit,
the distant haze at the horizon that makes the horizon line less visible.
I am working on my 1850s Mississippi Paddle-Wheel Steamboat, and need
such a horizon-affecting distant haze, too. But i tried ground fog and
regular fog already, and did not achieve the desired effect.
Does anyone of us POV-Ray community citizens have some tricks that can
do that? Maybe a huge torus with some sort of media in it? That would be
my guess (I however have almost no clue how to create media). Doing it
at the moment with Photoshop only...
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Download 'button_titan_110km.jpg' (11 KB) Download 'sl - mississippi paddle-wheel steamer - prow - side.jpg' (530 KB)
Preview of image 'button_titan_110km.jpg'
Preview of image 'sl - mississippi paddle-wheel steamer - prow - side.jpg'
Subject: Re: Distant Haze - How To?
Date: 31 Mar 2018 12:24:17
Message: <5abfb631$1@news.povray.org>
> http://www.avg.com
Using fog, you probably need to increase the distance parameter.
Otherwise, I'd use some atmospheric scattering media using the mie_haze
or mie_murky model. You need to use a low density. A sample count of 3
to 5 should be enough.
Don't forget to provide some actual back plane behind that fog or media.
It can be a simple plane with pigment{rgbt 1}.
Date: 31 Mar 2018 13:53:23
Message: <5abfcb13$1@news.povray.org>
Thanks. But would atmospheric scattering media not be hazy to all
directions? I still want to see the deep-blue sky (sphere), just at the
horizon i want to have that blurred stripe of hazy distance haze.
http://www.avg.com
Date: 31 Mar 2018 13:54:01
Message: <5abfcb39$1@news.povray.org>
I still give a try, always curious. :-D
http://www.avg.com
Date: 31 Mar 2018 14:30:50
Message: <5abfd3da@news.povray.org>
Am 31.03.2018 um 19:53 schrieb Sven Littkowski:
For realistic results, I alwasy recommend to consider reality:
In reality, the reason why the haze is only visible toward the horizon
is because the atmosphere gets less dense as you go up.
So that's exactly what I'd do with the media.
(I'd use two different media, one just for the blue with density
corresponding to atmospheric density to model some clear air, and
another one more strongly confined to lower altitudes for a white-ish
hazy air. For the blue component, Rayleigh scattering should be used
because that's what happens in the atmosphere, and for the white-ish
component one of the haze scattering modes is probbably best suited,
modelling larger dirt particles.)
Date: 1 Apr 2018 03:03:46
Message: <5ac08452$1@news.povray.org>
You could try this code, changing the colours of the media of course to
white or very light grey.
//start code
#local SkyScale = 100;
#local Density_out =
density {
   bozo  //agate
   density_map {
     [0.2 rgb 1.0]
     [0.5 rgb 0.2]
     [0.8 rgb 1.0]
   scale 0.05 //0.1
   warp {turbulence <0.5 0.4, 0.5>*2}
#local MistSphere =
difference {
   sphere { <0, 0, 0>, 1}
   plane {-y, 0 translate 10/SkyScale*y}
   texture {pigment {rgb 0 transmit 1} }
   hollow
   interior {
     media {
       intervals 1
       absorption <0.10, 0.10, 0.12>
       scattering {1, rgb <1, 1, 0.8>*1.4/SkyScale}
       samples 50
       confidence 0.9999
       variance 1/1000
       ratio 0.9
       density {
         spherical
         density_map {
           [0.880 Density_out]
           [0.960 rgb 0]
   scale SkyScale
   translate CamLoc
MistSphere
//end code
Date: 25 Apr 2018 14:25:28
Message: <5ae0c818$1@news.povray.org>
Working with this feature now, trying to make some changes. I need the
haze at the horizon, but not too much higher than it. Changing the
spherical density map to a gradient density map, maybe that can do the
trick.
http://www.avg.com
Date: 26 Apr 2018 12:15:53
Message: <5ae1fb39@news.povray.org>
Okay, for the amusement, I am posting now some of my results of creating
a "horizon haze". Not finish yet, but the first results are from ...
some other dimension (the image with the black fragments).
The second image shows ground fog, but the disadvantage here is that
this fog makes the water whitish with its own light color. Is there a
way to cut away any part of the ground fog that is below -0.75?
http://www.avg.com
Download 'horizon haze - 01.jpg' (96 KB) Download 'horizon haze - 02.jpg' (47 KB)
Preview of image 'horizon haze - 01.jpg'
Preview of image 'horizon haze - 02.jpg'
Date: 26 Apr 2018 12:29:43
Message: <5ae1fe77$1@news.povray.org>
Am 26.04.2018 um 18:15 schrieb Sven Littkowski:
IIRC you can set up "negative" ground fog to counteract the positive one.
Date: 27 Apr 2018 03:42:46
Message: <5ae2d476$1@news.povray.org>
The following has worked fairly well for me in the past. Tweak, by all
means!
#declare NearFogColor = <0.799, 0.799, 0.80>*1.2; //Blueish color
#declare FarFogColor  = <0.90, 0.90, 0.90>; //Light gray horizon color
//Near fog
fog {distance 4000 fog_type 2 fog_offset 25 fog_alt 20 color srgb
NearFogColor}
//Distant fog
fog {distance 8000 fog_type 2 fog_offset 25 fog_alt 20 color srgb
FarFogColor-NearFogColor}
