POV-Ray : Newsgroups : povray.binaries.images : Method. Visible surface at a distance from light source. Server Time
17 Aug 2025 17:45:38 EDT (-0400)
  Method. Visible surface at a distance from light source. (Message 1 to 6 of 6)
Subject: Method. Visible surface at a distance from light source.
Date: 14 Jan 2018 11:55:44
Message: <5a5b8b90@news.povray.org>
There was recently a post to povray.general about getting ray path
lengths. Less recently, Christoph suggested the idea of using a negative
spotlight within a positive one which spurred some negative light play
images. There too have been questions/github patch work for depth maps.
An idea popped into my head this morning related to those threads.
By using a positive light and a negative light at the same position
where the fade distance of the negative light is slightly inside the
positive one, and where both have very high fade powers, we can 'see'
what non-shadowed surfaces are at a certain distance from the light
source position.
Unsure if such a 'spherical shell of light at a radius' method really
useful in practice, but a trick for the bag in any case.
The bright parts of the attached image represent the surfaces both
visible to the camera position and at 0.8+-0.01 from the light source at
<0.5,0.5,-0.5>. Example code below.
Bill P.
//------------------ Example ----------------------
#version 3.8;
#default { finish {ambient 0.02 diffuse 0.98} }
#declare Grey40 = srgb <0.4,0.4,0.4>;
background { color Grey40 }
#declare Camera00 = camera {
     perspective
     location <2.5,2.5,-2.501>
     sky y
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare VarDist = 0.8;
#declare VarDistRes = 0.02;
#declare VarDistPos = VarDist+(VarDistRes/2);
#declare VarDistNeg = VarDist-(VarDistRes/2);
#declare White = srgb <1,1,1>;
#declare Light00 = light_source {
     <0.5,0.5,-0.5>, White
     fade_distance VarDistPos
     fade_power 1000
#declare Light01 = light_source {
     <0.5,0.5,-0.5>, White*-1
     fade_distance VarDistNeg
     fade_power 1000
#declare Red = srgb <1,0,0>;
#declare CylinderX = cylinder { -x, x, 0.01 pigment { color Red } }
#declare Green = srgb <0,1,0>;
#declare CylinderY = cylinder { -y, y, 0.01 pigment { color Green } }
#declare Blue = srgb <0,0,1>;
#declare CylinderZ = cylinder { -z, z, 0.01 pigment { color Blue } }
#declare Plane00 = plane { y, 0 pigment { color White } }
//--- scene ---
camera { Camera00 }
light_source { Light00 }
light_source { Light01 }
object { Plane00 }
object { CylinderX }
object { CylinderY }
object { CylinderZ }
Download 'the.png' (34 KB)
Preview of image 'the.png'
Subject: Re: Method. Visible surface at a distance from light source.
Date: 14 Jan 2018 14:05:01
Message: <web.5a5ba90d66dce5e65cafe28e0@news.povray.org>
> source position.
Hi Bill,
That's a very cool idea!  :)
Just to raise the bar a bit - is there any way that you can think of to simulate
an interference pattern?  Is there a way to [de facto] define a pattern for the
light_source such that one can [faux]cancel the other?
Off the top of my head, I'd say that it would have to be standard light source,
and a distance function-based pigment like Christoph suggested coupled with a
sin function...
But:  Couldn't you just enclose the entire scene into a union, and use an onion
pattern?
Define a color map with a narrow band of white, and the rest is rgbt 1, and then
scale it to highlight the desired distance.
I suppose you could also define a color map for the onion pattern going from 0
to 1, and then scaling it to the maximum desired radius.  The color value at any
point would then be the distance from wherever you translated the center of the
onion pattern to.
At the moment, I think the only way to indirectly find the total ray path length
is the formula method suggested by Christoph, but that's only for direct
lighting.  The ray path length for a light reflected from a mirror that hits an
object and then travels to the camera (ok, it's the reverse of that for
raytracing...) I think might presently be a challenging task.
Let me know if any of this has merit, or I'm in error.
Date: 15 Jan 2018 11:25:09
Message: <5a5cd5e5$1@news.povray.org>
>> source position.
> Hi Bill,
> sin function...
> pattern?
> onion pattern to.
It's impossible to apply any pattern to the light. The only ways to
spatially modulate the light is with light fading or by using spotlight,
cylindrical or projected_through.
You may try using negative fade_distance or negative fade_power... I've
never tried that.
Date: 15 Jan 2018 12:46:52
Message: <5a5ce90c$1@news.povray.org>
Thanks. And, I see I attached the image for distance 0.707 instead of
the 0.8 I intended...
If multiple lights are projected onto a surface you can get
'interference effects' in POV-Ray. If you look at this code attachment:
http://news.povray.org/povray.binaries.images/attachment/%3C59c91c45%241%40news.povray.org%3E/utf-8
to the Calling the Doctor - nighttime - 16:9 thread:
http://news.povray.org/povray.binaries.images/thread/%3C59c067a6%40news.povray.org%3E/?mtop=417998
and just uncomment both lights you'll get an interference pattern from
both 'sphere/pattern enclosed' lights as seen on a plane. It's a
technique useful for creating image maps, height fields etc. Long
doable, but oh so much easier with the new 3.8 user_defined{} feature of
pigment{}.
With the technique I posted you can use more dual lights of differing
color to, for example, answer questions like what surface regions are
equidistant from two points in space.
Your following ideas - at least in some form - can work too I think
depending on what you want to do.
> pattern?
> onion pattern to.
Such approaches are the easiest by changing the pigment over distance,
having finishes of ambient 1 or emission 1 and taking care to
view/access/write linearly stored 'distance' values.
Note. You can change effective color of a light source over distance
using the positive/negative light method. For example update the two
light sources in my example code to read:
//  fade_distance VarDistPos
//  fade_power 1000
     <0.5,0.5,-0.5>, Blue*-1
     fade_power 1
The result is yellow up to VarDistNeg, then fading to white the further
you get from the dual light source position.  Also note that the
intensity of the light 'seen' on the plane fades too as the angle of
rays becomes less and less perpendicular to the plane surface.
Agree.
Aside: I find myself wondering what happens with pos/neg light sources
in media. Would both the positive and negative rays be sampled/scattered
identically?
Bill P.
Date: 16 Jan 2018 21:40:48
Message: <5a5eb7b0@news.povray.org>
> Agree.
> identically?
> Bill P.
Why would they be sampled differently?
The algorithm don't care what the value of the light is, just that there
is some light shining at any given point.
Date: 18 Jan 2018 09:33:02
Message: <5a60b01e$1@news.povray.org>
>> sampled/scattered identically?
Likely true. Thanks.
Bill P.
