POV-Ray : Newsgroups : povray.binaries.images : Antony Gormley simulation Server Time
27 May 2026 11:54:58 EDT (-0400)
  Antony Gormley simulation (Message 71 to 80 of 108)
Subject: Re: Antony Gormley simulation
Date: 3 Dec 2017 08:20:00
Message: <web.5a23f9592471086b5cafe28e0@news.povray.org>
Hey!
I like the results you're getting.
In fact, I like the holes in the mesh so much, that maybe you could think about
exploiting that effect by randomly creating holes in the mesh to give a
"spiking" effect - I think that would be an excellent Gormley-inspired
methodology.
I think this is something Stephen would have fun playing with, and I'd have to
think about how to make it apply to DF3 files.
On the flip-side, if you wrote the points of the array to a DF3-format, then you
could create DF3 point clouds from any solid mesh or CSG construct, which would
be very cool indeed   :)
I have some explanatory comments on the code below to speed you along in your
studies.
> #declare Min = min_extent (Object);
> #declare Max = max_extent (Object);
obviously this just gives the opposing bounding box coordinates
> #declare MinZ = floor(Min.z);
> #declare MinY = floor(Min.y);
> #declare MinX = floor(Min.x);
> #declare MaxZ = ceil(Max.z);
> #declare MaxY = ceil(Max.y);
> #declare MaxX = ceil(Max.x);
Then we do some rounding up and down
> #declare Step = 0.5;
> #declare ZRange = (MaxZ - MinZ)/Step;
> #declare YRange = (MaxY - MinY)/Step;
> #declare XRange = (MaxX - MinX)/Step;
This compensates for any "off-origin" positioning
> #declare ArraySize = XRange*YRange*ZRange;
> #declare TestArray = array [ArraySize];
> #declare N = 0;
> #for (Z, MinZ, MaxZ, Step)
>  #for (Y, MinY, MaxY, Step)
>   #for (X, MinX, MaxX, Step)
>    #if(inside (Object, <X, Y, Z>))
>     #declare TestArray [N] = <X, Y, Z>;
If the point being scanned is inside the object, stick that point on the array
"stack", and increment the stack pointer / array position.
If not, just keep scanning.
>     //#debug concat ( "Point ", str (N, 3, 1), " = ", vstr(3, TestArray[N], ",
> ", 3, 0), " \n")
>     #declare N = N +1;
>    #end
>   #end
>  #end
> #end
> #declare InSize = N - 1;
Nudge this back down to the pre-increment value to avoid unknown array element
error.
> #declare Stream  = seed (123456789);
> #declare Stream1 = seed (456123789);
> #declare Stream2 = seed (789456123);
> #declare Stream3 = seed (135791113);
> #declare Stream4 = seed (987654321);
> #declare Stream5 = seed (987654321);
> #declare ScaleRange = 3;
Random seeds and a varying scale between 1 and ScaleRange
> #declare Tries = 2000;
How many objects do you want to populate the inside of the arrayed space with?
> #for (N, 1, Tries)
>  #declare P = int(rand (Stream5)*InSize);
Since rand() returns 0-1, and Insize is the number of points in the array, you
get a position somewhere in that array.
>  #declare rx = rand(Stream1)*90;
>  #declare ry = rand(Stream2)*90;
>  #declare rz = rand(Stream3)*90;
>  #declare Scale = rand(Stream4)*ScaleRange;
>  #declare TexNum = int (rand (Stream4) * dimension_size (TexArray, 1) );
I just had an array here to vary the textures of the jacks randomly
>  object {Jack rotate <rx, ry, rz> scale Scale translate TestArray [P] texture
> {TexArray[TexNum]} }
Put an object at the randomly selected array position.  It gets rotated some
random amount around x, y, and z, and given a random texture before translation.
> #end
Date: 4 Dec 2017 03:11:31
Message: <5a250333$1@news.povray.org>
On 3-12-2017 14:17, Bald Eagle wrote:
> Hey!
> methodology.
For the time being I treat them as artefacts.
Stephen, your turn ;-)
> studies.
> [snip]
ah-HA! I see. Thanks indeed.
Date: 4 Dec 2017 05:02:23
Message: <5a251d2f$1@news.povray.org>
>> Hey!
>> think about
>> methodology.
>> have to
>> which would
I don't think writing the points from the array to a df3 would give you
the results you want. I think it would just give you a surface with
holes in it.
If you used the slicing method to create a df3. You would get spikes in
the direction of the inside vector extending to the edge of the container.
I have been thinking of trying to do the same with bullet physics. But I
am having PC problems.
Regards
Date: 4 Dec 2017 06:40:01
Message: <web.5a2533b22471086b5cafe28e0@news.povray.org>
> holes in it.
Well, I scan the entire solid, so it ought to give more than that.
Ah, yes.  The inside_vector.   Good point.
I think Thomas was merely suggesting that you poke a few holes in a mesh for
testing purposes.
Apparently I'm having "PC issues" as well.   ;)
Date: 4 Dec 2017 07:17:09
Message: <5a253cc5$1@news.povray.org>
>> holes in it.
I've not been following the technical side of the discussion. I thought
you were scanning a mesh. Which generally only defines a surface. At
least Poser ones do.
> testing purposes.
I had better read the thread again. Something is not meshing. ;)
Indeed. One man's humour can be another man's deceleration to war. :)
Regards
Date: 4 Dec 2017 07:40:33
Message: <5a254241$1@news.povray.org>
>> Hey!
>> think about
>> methodology.
I don't know what those spikes represent finally. I closed the model and
still the eyes show them, except if I increase minutely the Step
parameter. Any idea?
Date: 4 Dec 2017 07:49:40
Message: <5a254464@news.povray.org>
Finally, as first approximation, I found it more expedient to randomise
the points in the array when reading them.
Download 'antony gormley sim.png' (409 KB)
Preview of image 'antony gormley sim.png'
Date: 4 Dec 2017 07:50:00
Message: <web.5a25437f2471086bc437ac910@news.povray.org>
They are, until you define an inside_vector, and then it's a solid.
POV-Ray squawked about the mesh I was using not being a solid object when I
tried to use inside() until I defined an inside_vector.
> > testing purposes.
You're either not sober and should be, or sober and shouldn't be.
Date: 4 Dec 2017 08:25:01
Message: <web.5a254b812471086bc437ac910@news.povray.org>
Hmmm.
Without seeing how you're going about that, I'm not sure I understand the
advantage of that over selecting a (pseudo)random point in an ordered array.
I do think that one thing that could be done is add a bit of randomization to
the point itself - since they are all regularly spaced in a cubic grid.
("cubic" is just easier to say/write than "rectangular solid")
So, perhaps define half the grid spacing as a multiplier (M), and randomly
translate along x, y, and z by rand_between (-M and M).
Add a rotation if you're using an asymmetric filler.
Or draw a cylinder between the original point and a randomly translated or
chosen outside point.
It's certainly looking more evenly filled - which I think is what you wanted.
Date: 4 Dec 2017 09:02:59
Message: <5a255593$1@news.povray.org>
I need to look at your code and hope I can see what you are doing.
I don't recognise that warning/error. But I always use PoseRay to
convert OBJ files to Mesh2 and it always includes an inside vector.
What version of Pov are you using?
>>> testing purposes.
I resemble that remark. :(
Regards
