POV-Ray : Newsgroups : povray.binaries.images : Antony Gormley simulation Server Time
27 May 2026 10:43:21 EDT (-0400)
  Antony Gormley simulation (Message 49 to 58 of 108)
Subject: Re: Antony Gormley simulation
Date: 29 Nov 2017 07:09:01
Message: <5a1ea35d$1@news.povray.org>
On 29-11-2017 9:44, Stephen wrote:
> On 29/11/2017 07:52, Thomas de Groot wrote:
>>> UV mapping a blob. Now there's a thought. :)
>> Hmmm... is that possible?
> After a quick test, yes.
> easily?
> No. It would need more testing and much more coffee.
> I got some results but not something recognisable as the image map.
> Blobs are not on the list of readily
>> uv_mapped objects.
Hmm... I shall leave that alone for the time being.
Date: 29 Nov 2017 07:14:11
Message: <5a1ea493$1@news.povray.org>
>> easily?
>>> uv_mapped objects.
Probably best
Regards
Date: 29 Nov 2017 09:47:02
Message: <5a1ec866$1@news.povray.org>
Am 29.11.2017 um 09:44 schrieb Stephen:
Not with POV-Ray.
You might not get an error message, but that doesn't mean you actually
get UV mapping.
Date: 29 Nov 2017 10:14:37
Message: <5a1ecedd@news.povray.org>
> Not with POV-Ray.
No error message in Ver 3.6
> get UV mapping.
It did not look the slightest like UV mapping when I tried it.
It might be possible to get the effect in Blender if the PovRay exporter
exports their metaballs as meshes.
Regards
Date: 29 Nov 2017 20:40:01
Message: <web.5a1f60f72471086b5cafe28e0@news.povray.org>
> Along those lines, you could build an array to store coordinates, "scan" the
> bounding box of the figure with an x-y-z nested loop and inside(object, vector)
> tests, and then use the pseudorandom selection process to pick known inside()
> points.
> The advantage there is that you could save the array to disk, and not have to
> test the same figure every single time you wanted to place objects.  You
> wouldn't even need to load the mesh for the figure either.
So, I managed to get this to work, and it seems like it gives fairly decent
coverage.
I think if I find the time, (and I'm reminded of this to-do item) I might try to
figure out a way to use a spline to give greater probability of selecting the
smaller volumes and less probability of selecting the larger volumes, resulting
in a more even distribution.
Meet ... Jack.  :D
Download '_jack.png' (592 KB)
Preview of image '_jack.png'
Date: 30 Nov 2017 03:04:35
Message: <5a1fbb93$1@news.povray.org>
>> points.
> coverage.
> Meet ... Jack.  :D
That is looking good indeed. I need to ponder this a bit more; I think I
know how to do this but I want to examine all the angles, so to speak. I
can see the advantage of this procedure and it would avoid the
subdividing of the container in discrete elements.
Saving the point locations is certainly an excellent idea. I shall
certainly come to that eventually.
Well done indeed.
Date: 30 Nov 2017 03:10:24
Message: <5a1fbcf0$1@news.povray.org>
>> Not with POV-Ray.
>> get UV mapping.
A big problem as I see it, would then be how to define the uv_map seams
and where to place them. That would have to be done in Blender too.
Date: 30 Nov 2017 03:14:25
Message: <5a1fbde1$1@news.povray.org>
Am 2017-11-29 20:37, also sprach Bald Eagle:
> Meet ... Jack.  :D
You're such a snowflake, Jack. Go to your safespace!
dik
Date: 30 Nov 2017 04:51:42
Message: <5a1fd4ae$1@news.povray.org>
>>> Not with POV-Ray.
>>> get UV mapping.
>> exporter exports their metaballs as meshes.
Just thinking out loud.
I think you could do it with a technique similar to using uv mapper.
Select a portion of the model and associate it with a part of the image
map. Quite laborious compared to using the "ready rolled" Poser ones.
Also Blender's metaballs have some differences from Pov's blobs. Or so
it seemed in the 15 minutes I took to look at it.
I don't really want to get distracted form what I am doing in Poser. I
am having problems getting clothes to fit a model in a crouching
position. The working title is: "How Christianity came to the Western
Isles."
BTW Do you (or anyone) know how to add a colour tint to a poser model?
Say, give a green or blue tint to a skin tone.
Regards
Date: 30 Nov 2017 05:05:21
Message: <5a1fd7e1$1@news.povray.org>
Never mind. It is easy to do in Poser. (Change the diffuse colour in the
material room.)
Regards
