POV-Ray : Newsgroups : povray.binaries.images : Clothed in light. Server Time
25 Jun 2026 04:02:48 EDT (-0400)
  Clothed in light. (Message 31 to 35 of 35)
Subject: Re: Not Clothed in light. So partial nudity
Date: 17 Nov 2017 08:00:01
Message: <web.5a0edc2e96756879c437ac910@news.povray.org>
> > > I'm sure some of us have some slightly richer looking wood floor macros lying
> > > about. ;)
> > As I implied to Thomas. The studio is a very old scene. At least ten
> > years old if I made it in Moray. So any contributions are welcome. :-)
> I'll see what I can isolate from the Secret Passage scene.
> You'd think there would be a well developed wood floor macro or include file -
> and having had to write the code to make an acceptable wood floor, I can see why
> there might not be one.
This probably needs to be prettied up to make it generally useful, but see how
this works.   (you may have to translate the floor -y*16*12)
// Planked Hardwood Floor with borders
// Bill Walker "Bald Eagle"  2014
// Some textures based on code supplied by Thomas deGroot
// and Nicolas Rougier
http://news.povray.org/povray.binaries.images/message/%3C54367691%241%40news.povray.org%3E/#%3C54367691%241%40news.povr
ay.org%3E
#version 3.7;
//######################## CONTROL PANEL SETTINGS ##########################
global_settings{
 assumed_gamma 1.0
 ambient_light rgb 0
 max_trace_level 7
 #if (Radiosity)
  radiosity {
   pretrace_start 1 //  0.08
   pretrace_end   1 //  0.04  //  0.01
   count 35    //  150
   nearest_count 5   //  10
   error_bound 1.8  //  0.5
   recursion_limit 2
   low_error_factor 0.5
   gray_threshold 0.0
   minimum_reuse 0.015   //  0.005
   maximum_reuse 0.2
   brightness 1
   adc_bailout 0.01    //  0.005
  }  // end radiosity block
 #else
  }// end global settings
#include "functions.inc"
#include "math.inc"
#include "metals.inc"
#include "rand.inc"
//#include "screen.inc"  //  perspective camera only
#include "shapes.inc"
#include "shapes2.inc"
#include "textures.inc"
#include "transforms.inc"
#include "woods.inc"
#declare Feet = 12;
  #declare Camera_Position = < -1.5*Feet, (18+6)*Feet,  -9*Feet> ;  // front
view
  #declare Camera_Look_At  = <  2*Feet,  16 *  Feet,  18*Feet> ;
  #declare Camera_Angle    =  65 ;
  location Camera_Position
         right    x*image_width/image_height
         angle    Camera_Angle
         look_at  Camera_Look_At
light_source {<1500, 750, -200> color rgb <1, 0.8, 0>*5}  //  Sun
 light_source {<0*Feet, 25*Feet, 4*Feet> color rgb <1, 1, 1>*0.3}
#declare PlankNormal = normal { gradient x 2
    slope_map {
     [0.00 <0, 1>]
     [0.05 <1, 0>]
     [0.95 <1, 0>]
     [1.00 <0,-1>]
    scale 2
#declare Tone = 1;
#declare YRotate = 0;
#declare DarkWood= rgb <71, 35, 1>;
//(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)(o)
(o)
(o)
#declare OakFloor = texture {
   pigment {bozo scale <1, 1, 10>
   color_map {
   //[0.4 rgb <0.9, 0.7, 0.4> * Tone]
   //[0.6 rgb <1.0, 0.8, 0.6> * Tone]
   [0.0 rgb <121/255,  52/255, 13/255> * Tone]
   [0.2 rgb <142/255,  73/255, 18/255> * Tone]
   [0.4 rgb <184/255, 115/255, 48/255> * Tone]
   [0.6 rgb <157/255,  81/255, 23/255> * Tone]
   [0.8 rgb <108/255,  45/255,  4/255> * Tone]
   [1.0 rgb <156/255,  72/255, 26/255> * Tone]
  turbulence 0.5
  scale <1, 1, 10> * 0.5
  rotate y*YRotate
 normal {
  average normal_map {
     [1 PlankNormal]
     [1 wood 0.5
      slope_map {
      [0.0 <0.0, 0>]
      [0.5 <0.5, 1>]
      [1.0 <1.0, 0>]
      }  // end slope map
     turbulence 0.5 scale <1, 1, 10> * 0.5]
    }  // end normal map
    rotate y * YRotate
  }  // end normal
   finish { specular 0.2 reflection 0.1 }  //  finish { specular 0.5 reflection
0.2 }
 }  // end texture
(o)
(o)
#declare Tone = <1.2, 1.2, 0.3>;
#declare OakFloor =
     wood
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone]
       [0.2 srgb <142,  73, 18>/255 * Tone]
       [0.4 srgb <184, 115, 48>/255 * Tone]
       [0.6 srgb <157,  81, 23>/255 * Tone]
       [0.8 srgb <108,  45,  4>/255 * Tone]
       [1.0 srgb <156,  72, 26>/255 * Tone]
     warp {turbulence <0.6, 0.1, 0.1>}
     scale <1, 1, 10>*0.5
     scale 0.3
     rotate 1*x
     rotate y*10
(o)
(o)
//============= NR_Wood (2003) =============
#declare NR_wood_grain =
   wood
   warp {cylindrical orientation y dist_exp 1}
   warp {turbulence 1.25}
   scale <0.5, 30, 1>
   warp {turbulence 0.25}
   scale <1, 10, 1>
   warp {
     black_hole <0, 0.5, 0>, 1
     falloff 2
     strength 1.5
     repeat 7
     turbulence 2
     inverse
#declare NR_wood_normal =
function {
     wood
     scale <0.5, 30, 1>
     scale <1, 5, 1>
     color_map {[0 rgb <0, 0, 0>] [1 rgb <1, 1, 1>]}
#declare NR_woodmap =
color_map {
     [0.00 srgb <0.949, 0.792, 0.514 >]
     [0.30 srgb <0.855, 0.651, 0.376 >]
     [0.60 srgb <0.831, 0.596, 0.275 >]
     [0.90 srgb <0.620, 0.447, 0.204 >]
#declare NR_woodmap2 =
     color_map {
       [0.1 srgb <142,  73, 18>/255 * Tone]
       [0.3 srgb <184, 115, 48>/255 * Tone]
       [0.8 srgb <157,  81, 23>/255 * Tone]
       //[0.8 srgb <108,  45,  4>/255 * Tone]
#declare Tone2 = Tone * 1.05;
#declare NR_woodmap3 =
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone2]
       [0.1 srgb <142,  73, 18>/255 * Tone2]
       [0.3 srgb <184, 115, 48>/255 * Tone2]
       [0.8 srgb <157,  81, 23>/255 * Tone2]
       //[0.8 srgb <108,  45,  4>/255 * Tone2]
       [1.0 srgb <156,  72, 26>/255 * Tone2]
#declare Tone3 = Tone * 0.95;
#declare NR_woodmap4 =
     color_map {
       [0.0 srgb <121,  52, 13>/255 * Tone3]
       [0.1 srgb <142,  73, 18>/255 * Tone3]
       [0.3 srgb <184, 115, 48>/255 * Tone3]
       [0.8 srgb <157,  81, 23>/255 * Tone3]
       //[0.8 srgb <108,  45,  4>/255 * Tone3]
       [1.0 srgb <156,  72, 26>/255 * Tone3]
#declare FloorNormal = 0.8;
#declare NR_Wood =
   pigment {NR_wood_grain
     color_map {NR_woodmap2}
     ramp_wave
   normal {
     function {NR_wood_normal(x,y,z).grey*FloorNormal
   finish {diffuse 0.6 specular 0.1 roughness 0.005}
#declare NR_Wood2 =
     color_map {NR_woodmap3}
     ramp_wave
   normal {
#declare NR_Wood3 =
     color_map {NR_woodmap4}
     ramp_wave
   normal {
(o)
(o)
//#declare OakFloor = texture {NR_Wood scale 1 rotate <90, 0, 0>};
#declare HalfWidth    =  19.0;
#declare MortarScale  =  0.99;  //  0.995;
#declare TunnelRadius =  1.5;
#declare RoomWidth    =  9.0;
#declare PlankScale   =  1.78;
#declare FloorBorder =
union {
 #declare BorderSize = 2;
 //Left
 box {<-(RoomWidth*Feet)+0, -0.1, -9*Feet>, <-(RoomWidth*Feet)+(2*BorderSize),
2.0, 18*Feet> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+(2*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(6*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52,
13>/255 * Tone3}}//texture {NR_Wood3 scale 1 rotate <90, 0, 0>}}
 #declare BlockRow = -(9*Feet);
 #declare Alternate = 1;
 #while (BlockRow < (18*Feet))
  #if (Alternate > 0)
   box {<-(RoomWidth*Feet)+(2*BorderSize+0.25), -0.1, BlockRow+0.25>,
<-(RoomWidth*Feet)+(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood
scale 1 rotate <90, 90, 0>}}
  #else
<-(RoomWidth*Feet)+(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood2
  #declare BlockRow = BlockRow + (1*BorderSize);
  #declare Alternate = -Alternate;
 box {<-(RoomWidth*Feet)+(6.0*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(7.5*BorderSize), 2.0, 18*Feet> texture {NR_Wood2 scale 1
rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+(7.5*BorderSize), -0.1, -9*Feet>,
<-(RoomWidth*Feet)+(8.0*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52,
13>/255 * Tone3}}
 // Right
 box {<(RoomWidth*Feet)-0, -0.1, -9*Feet>, <(RoomWidth*Feet)-(2*BorderSize),
 box {<(RoomWidth*Feet)-(2*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(6*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52, 13>/255
  #if (Alternate > 0)
   box {<(RoomWidth*Feet)-(2*BorderSize+0.25), -0.1, BlockRow+0.25>,
<(RoomWidth*Feet)-(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood
  #else
<(RoomWidth*Feet)-(6*BorderSize-0.25), 2.1, BlockRow+1.75> texture {NR_Wood2
 box {<(RoomWidth*Feet)-(6*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(7.5*BorderSize), 2.0, 18*Feet> texture {NR_Wood2 scale 1
rotate <90, 0, 0>}}
 box {<(RoomWidth*Feet)-(7.5*BorderSize), -0.1, -9*Feet>,
<(RoomWidth*Feet)-(8*BorderSize), 2.0, 18*Feet> pigment {srgb <121,  52, 13>/255
* Tone3}}
 // Back
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-0>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(2*BorderSize)> texture {NR_Wood2 scale 1
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(2*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(6*BorderSize)> pigment {srgb <121,  52,
13>/255 * Tone3}}
 #declare BlockRow = -(RoomWidth*Feet)+12;
 #while (BlockRow < (RoomWidth*Feet)-12)
  #if (Alternate > 0)
   box {<BlockRow+0.25, -0.1, 18*Feet-(2*BorderSize+0.25)>, <BlockRow+1.75, 2.1,
18*Feet-(6*BorderSize)-0.25> texture {NR_Wood  scale 1 rotate <90, 0, 0>}}
  #else
18*Feet-(6*BorderSize)-0.25> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(6.0*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(7.5*BorderSize)> texture {NR_Wood2 scale 1
 box {<-(RoomWidth*Feet)+12, -0.1, 18*Feet-(7.5*BorderSize)>,
<(RoomWidth*Feet)-12, 2.0, 18*Feet-(8*BorderSize)> pigment {srgb <121,  52,
13>/255 * Tone3}}
 // Front
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+0>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+4> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+4>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+8> texture {NR_Wood3 scale 1 rotate <90, 0, 0>}}
 box {<-(RoomWidth*Feet)+12, -0.1, -9*Feet+8>, <(RoomWidth*Feet)-12, 2.0,
-9*Feet+12> texture {NR_Wood2 scale 1 rotate <90, 0, 0>}}
 translate y*18*Feet
}  // end union
//  Wood Floor building loop
#debug "Building Floor \n"
#declare BL   = seed (113);
#declare Rx   = seed (356);
#declare Ry   = seed (876);
#declare Rz   = seed (159);
#declare Flip = seed (542);
#declare Offset = 10*Feet;
#declare Floor =
union {
 #declare Row = -RoomWidth*Feet;
 #while (Row < RoomWidth*Feet)
  #debug concat("Building Row#", str(Row, 3, 0), " \n")
  //#debug concat("Center: <" vstr (3, Middle, ", ", 0, 1), ">, Radius:",
str(Radius, 3, 4), " \n")
  #declare OverallLength = 0;
  #declare BoardNo = 1;
  #while (OverallLength < 27)
   #declare RotY = SRand(BL)*5;
   #declare Randx = rand(Rx) * Offset;
   #declare Randy = rand(Ry) * Offset;
   #declare Randz = rand(Rz) * Offset;
   #declare BoardLength = (int(rand (BL)*4)+1)*3;
   #if (rand (Flip) > 0.5)
    #declare Amt = 180;
   #else
    #declare Amt = 0;
   #if (rand (Flip) < 0.3)
   #elseif (rand (Flip) > 0.6)
    #declare OakFloor = texture {NR_Wood2 scale 1 rotate <90, 0, 0>};
   #else
    #declare OakFloor = texture {NR_Wood3 scale 1 rotate <90, 0, 0>};
   #debug concat("Board#", str(BoardNo, 3, 0)," | Rotation:", str(Amt+RotY, 3,
0), " | Overall:", str(OverallLength, 3, 0)," \n")
   #declare FloorPlank = box {<Row, 0, (OverallLength-9)*Feet>, <Row+4 -
(rand(Rx)*(1/4)), 1.99, ((OverallLength-9+BoardLength)*Feet) -
(rand(Rz)*(1/8))>}
   object {FloorPlank texture {OakFloor rotate y*RotY translate <Randx, Randy,
Randz>} }
   #declare OverallLength = OverallLength + BoardLength;
   #declare BoardNo = BoardNo + 1;
 #declare Row = Row + 4;
 box {<-RoomWidth*Feet, (18*Feet), -9*Feet>, <RoomWidth*Feet, (18*Feet)+1.99,
18*Feet>
  texture {OakFloor} texture {pigment {rgbt <0, 0, 0, 0.4>}} }  //  Dark cracks
between floorboards
}  // end union
object {Floor translate y*18*Feet}
object {FloorBorder}
Download 'woodfloor.png' (461 KB)
Preview of image 'woodfloor.png'
Date: 17 Nov 2017 08:48:00
Message: <5a0ee890$1@news.povray.org>
Thanks, that looks good. I'll need to modify it a bit as B3D doesn't
handle functions. But that shouldn't be too hard.
Regards
Date: 17 Nov 2017 08:52:58
Message: <5a0ee9ba@news.povray.org>
On 16/11/2017 10:24, Stephen wrote:
> * I have no idea why in this image the wings and clothes did not show.
> With the render time they should have been there.
Oops! the camera was inside the media container.
This is what it was meant to be like. After taking two hours with no AA
nor mirrors. I am posting it. ;-)
Regards
Download 'studio_vic2d_y_903at_1_0000.png' (355 KB)
Preview of image 'studio_vic2d_y_903at_1_0000.png'
Date: 18 Nov 2017 03:12:55
Message: <5a0feb87$1@news.povray.org>
On 17-11-2017 13:55, Bald Eagle wrote:
>>>> about. ;)
So. I /totally/ forgot about this :-O
Well done indeed. I need to update some of my files I believe ;-)
Date: 19 Nov 2017 02:57:15
Message: <5a11395b@news.povray.org>
I managed to look at your code.
I worked my way through it correcting the wrap text/CR-LF errors,
created by T/Bird. Then I substituted the Normals with their fancy
Functions. (B3D cannot handle Functions.)
When I imported the macro into B3D it showed that the scaling of the
studio is all to cock. So I will need to rebuild it before I can use
your macro. That is a shame as the border looks good. For simplicity
I've "borrowed" Warp's code from his "4 tips" tutorial and I've changed
the scale of the model to make it fit in better with the furniture and
props. So this will be the last image in this test.
Regards
Download 'studio_vic2d_y_905a_0000.png' (1109 KB)
Preview of image 'studio_vic2d_y_905a_0000.png'
