POV-Ray : Newsgroups : povray.binaries.images : Proximity Pattern testing Server Time
27 May 2026 07:44:09 EDT (-0400)
  Proximity Pattern testing (Message 27 to 36 of 56)
Subject: Re: Proximity Pattern testing
Date: 26 Sep 2017 03:38:29
Message: <59ca03f5@news.povray.org>
On 26/09/2017 08:11, Thomas de Groot wrote:
> ...and to support my case: I have been doing some little sculpture in
> between.
I'm seeing Giacometti, here. :-)
http://www.dailyartfixx.com/wp-content/uploads/2010/10/Walking-Man-Alberto-Giacometti.jpg
Regards
Date: 26 Sep 2017 03:40:08
Message: <59ca0458@news.povray.org>
On 26/09/2017 00:04, Bald Eagle wrote:
> Stephen <mca### [at] aolcom> wrote:
>> On 24/09/2017 07:52, Thomas de Groot wrote:
>>> Gentlemen, you make it almost compulsory for me to try and use
>> Time however does not get any longer. ;-)
> Au contraire.
> https://en.wikipedia.org/wiki/Time_dilation
> So, the faster Thomas works, the slower time will pass....  ;)
But for us it will seem to take forever.
Regards
Date: 26 Sep 2017 03:56:59
Message: <59ca084b@news.povray.org>
>> Au contraire.
That is more to the point indeed.
Date: 26 Sep 2017 07:05:50
Message: <59ca348e$1@news.povray.org>
>> between.
His cousin.
While testing some features in Silo, I started with a low poly bust
provided by them and got this. I think I shall add a few little things
and hone the textures.
Date: 26 Sep 2017 14:30:01
Message: <web.59ca9c4081230942883fb31c0@news.povray.org>
> I've had sporadic success with the "put the HDD in the freezer" technique.
> In theory, you should only need to get the drive working reliably _once_ for as
> long as you need to transfer the files to a shiny new drive(s).
Hmm, sounds a bit like 'Monty Python' science. Do I cast the Runes while doing
so, to see if the auspices are good? (Kidding, kidding. Sorry, I couldn't resist
;-P
I guess that's basically for a drive that's overheating(?) The trouble with mine
is that it no longer even starts or comes on electrically. I *think* the problem
stems from the fact that I dropped it onto a (rug-covered) floor, from a 3-foot
height off my desk. Dumb. But I didn't think such a minor(??) shock would affect
it so badly. A hard lesson learned.
> Following that logic, I'm sure that all of us here at news.povray.org would very
> much appreciate HD video of you transferring files from your drive while it's
> submerged in a Dewar filled with liquid nitrogen, argon, or helium.
I've already ordered the helium. Now I just need to build the Dewar...and the
pumps...
Date: 26 Sep 2017 15:05:00
Message: <web.59caa42681230942c437ac910@news.povray.org>
It's likely the hard drives are Made In China (TM), so you need to use the I
Ching.
No. I'm not sure _exactly_ why, but empirically it seems to work > 0% of the
time for people that Santa has on his Nice list.
I hate speculate, but, oh, well, if you insist...
I think it has something to do with the metal contracting in the cold, and
freeing up parts that are binding (bearings) or touching when they're not
supposed to be (platters & read/write heads}
Hmm.  I take _everything_ apart, and I'd say that 90% of the time it's bad
contacts.  In technical terms, "It's a loose wire", or with motors, it's usually
a filthy commutator and soot-caked graphite brushes.
This is different than having a brush with a filthy communist.
You can get head lice from that.
That's a pattern of proximity you don't want to repeat (or initialize).
[just to stay on-topic  ;) ]
So I'd say disconnect any ribbon cables or connectors, and re-seat them,
possibly after wiping or rinsing with electrical cleaner, isopropyl alcohol, or
just a dry paper towel or cotton swab.
Excellent!   The boil-off ought to spectacularly enhance your girlish squeals of
delight when my ingenious plan comes to fruition!
"Large Thermos bottle" / styrofoam cooler
....and the
> pumps...
I'm not sure where you're going with that, but it sounds NSFW....
:P
Date: 26 Sep 2017 15:15:00
Message: <web.59caa66581230942c437ac910@news.povray.org>
I guess it depends on the vintage.
Yours is likely Digitalais nouveau...
(That's different than digitalis, which is a cardiotoxic glycoside from the
heart-stoppingly beautiful foxglove.)
https://www.pcworld.com/article/3035017/storage/that-old-freezer-trick-to-save-a-hard-drive-doesnt-work-anymore.html
https://www.google.com/search?q=hard+drive+in+freezer&rlz=1C1CHFX_enUS633US634&oq=hard+drive+in+freezer&aqs=chrome.0.0l
6.3498j0j7&sourceid=chrome&ie=UTF-8
I actually have 2 old IDE Western Digital HDD's that I need to see if I can
transfer the data from one to the other (or any other drive)
One looks good, and the other is slightly corroded...
I'd explain why, but it's a long and terrifying story - because reality is
SOOOOO much stranger than fiction.
Date: 26 Sep 2017 15:36:51
Message: <59caac53@news.povray.org>
You're pushing your metaphors. ;)
I was going to mention the freezing the HDD. But the above put me off.
You're other advice about cleaning contacts, is spot on. :)
I used to use an old fashioned eraser if no one was looking.
Yes, that's an acceptable reason not to say. :)
Regards
Date: 26 Sep 2017 15:38:19
Message: <59caacab$1@news.povray.org>
On 26/09/2017 20:36, Stephen wrote:
> You're other
Sorry. :(
Regards
Date: 26 Sep 2017 17:17:45
Message: <59cac3f9$1@news.povray.org>
Am 26.09.2017 um 21:01 schrieb Bald Eagle:
How about liquid nitrous oxide as an alternative? Sounds like you have
some experience with that ;)
