![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 09/09/2017 12:04, Thomas de Groot wrote:
> On 9-9-2017 9:25, Stephen wrote:
>> That is really good. I like the weathering/dirt on the stonework and
>> Wattle and daub. If that is what it was made of.
> The original stone image_map was not good enough, so I selected a
> different one. For the arcs and the steps I used a different stone texture.
I did not notice that it was repetitive until just now. It slipped past me.
> I am rather pleased with the wattle and daub too. It is a
> pigment_pattern based texture (in POV-Ray of course).
You got it right. :-)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 9/8/2017 8:02 AM, Thomas de Groot wrote:
> I am now almost finished with the high-poly model
> reconstruction from that on (see second image)
> I improved on details, left some out and introduced new ones, and in a
> number of cases used different image_maps. Of course, I also used
> POV-Ray textures. Over all, I intended the house to look more like a
> real one and not like the toy model the original looked like somehow.
i like the texture on the tower tops ... looks like weathered copper
maybe that texture would look good on the other roof ornaments too
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Really beautiful; it could not have been easy to do.
I would suggest some more weathering, specifically underneath all of the
horizontal wood beams of the house. Something like rainwater dirt, that would
drip down the walls over many years. Overlayed alpha-channel image map(s),
perhaps? Although, the effect might be done more easily with procedural pigments
of some kind, with turbulence.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you. You have extended the project for a couple of months more :-)
This is an interesting suggestion I need to study a bit longer, but it
will certainly have a follow up.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> I am now almost finished with the high-poly model reconstruction from
Thank you, yes, I thought the tower tops needed a weathered copper top
and I found this image_map somewhere on the net. The original top was
just a dull greenish.
By the way, if you google "Gutenbach house" you will find images of the
model as built by De Espona in high poly version. I used those images
for my own reconstruction, based on the low poly version I owned.
Surprisingly, they show some sloppy uv-mapping I would not have expected
from a professional.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> that would
>> map(s),
>> procedural pigments
IIRC you were experimenting on this subject a few years ago using
Edouard's DF3 Proximity Pattern.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4aa83e6a37d8ab92c83e2c410%40news.povray.org%3E/?mtop=323317
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> that would
>>> map(s),
>>> procedural pigments
>> :-) This is an interesting suggestion I need to study a bit longer,
>> but it will certainly have a follow up.
Correct, but in this particular case this will be much more difficult
because of the uv_mapping of the wood beams.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ug! The thought of painting the UV maps.
On my todo list is to try to make a transparent merged copy of the
object. Scale it up slightly centred on the centre of mass. Then do A
Proximity Pattern on that and combine them.
Just a thought experiment.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
17
I would really like to experiment with this, but I can't (yet) find the actual
code or macro(?), when doing a search of the newsgroups. *Is* it a macro or
include file--or is it a stand-alone program or fork of POV-Ray?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> 17
Nor can I find it. And unfortunately I can't find a copy of the download
on either my PC or my laptop. But I bet a pound to a penny that Thomas
has one. :-)
Failing that I do have an include directory that has the include file
but not the instructions or examples. I might have it on one of my older
laptops. So might be able to reconstruct it.
Lets wait until tomorrow to see if the Master of the Archives (Thomas)
has it. If not I shall scrape the dust of my old machines and have a
look. Or go through what I do have and try to get a working copy.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
