POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
17 Feb 2026 00:47:23 EST (-0500)
  QUESTION: Bump not showing? (Message 1 to 10 of 91)
Subject: QUESTION: Bump not showing?
Date: 15 Jul 2017 20:40:24
Message: <596ab5f8@news.povray.org>
I never actually used bump_maps before. Now I try to use one, but not
seeing any effect. Can someone assist me?
The scene contains a stratosphere helium balloon, and the bump_map
should have created the typical balloon surface. However, I don't see
the surface changed. Before posting any images, I show you the scene
file. is there any error the way I do it?
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *10.0
#declare MyRadius = 200.0;
#declare MyOuterBalloonFinish = finish
// reflection   0.00
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
- Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
  translate -0.5
  rotate < 90.0, 0.0, 0.0 >
  scale MyRadius*2
 normal
  bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" gamma 1.8
bump_size 150.0 }
  translate -0.5
  scale MyRadius*2
 finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside }
 object
  scale 0.99999
  texture { MyInnerBalloonTexture }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 000.0, 0.0 > }
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 180.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: Bump not showing?
Date: 16 Jul 2017 16:10:38
Message: <596bc83e$1@news.povray.org>
Am 16.07.2017 um 01:40 schrieb Sven Littkowski:
I don't see you adapting the texture to the shape of the balloon (such
as by the use of `map_type`, spherical warp, or UV mapping).
Date: 24 Jul 2017 01:50:03
Message: <web.59758a1a9f453b979c5d6c810@news.povray.org>
Here's what I managed to do with it, changed many things so your scene file will
look different. See whole scene file text below.
I discovered something, caught me by surprise, when using a planar mapping for a
bump map the opposite side will invert the normal. Well, not too surprising if
on a plane {y,0} for example, but I didn't think about the inversion for a
spherical shape like your balloon.
That might not be so much a problem, because I easily solved that by using
opposite scale (as you will see in SDL changes). The real problem I encountered
is how the vertical portions of balloon lose bumpiness. I realize it could be
dealt with by using a non-planar mapping, or maybe warp (that I was unsuccessful
with), but the image file is not usable as such.
Someone else might be able to alter it but I didn't try more than applying
spherical and cylindrical warp {} to the planar image/bump map.
Including enhanced image file here too. It was indeed low contrast before, which
can be bad for this kind of thing. You should be able to see how the bumpiness
is shown now, mainly for upper and lower parts of balloon, yet flattens out on
the sides as I said.
Remember I changed things like lights, textures, too so you are going to need to
do whatever changes you want to this. At least I think you should see the
bumpiness anyhow.
#version 3.7;
//#include "colors.inc"
//#include "finish.inc"
//#include "textures.inc"
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   normal on // added
   pretrace_start 0.08
   pretrace_end   0.02
   count 123
   error_bound 0.75
   recursion_limit 2
 //subsurface        {}
 //adc_bailout       0.0039
 ambient_light     0.06//rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1
 max_trace_level   4
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < 0.0, 200.0, -500.0 >
 look_at < 0.0, -150.0, 0.0 >
 right image_width/image_height*x
light_source
 < 12500.0, 1500.0, -500.0 >,
 rgb < 0.72265625, 0.8046875, 0.80859375 > // *10.0
plane {y,-1000 pigment {rgb <0.9,0.95,1>}}
 brilliance   1.50
 phong albedo 0.05
 phong_size 5
 specular 0.5
 roughness 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   {0.050,0.15}
 brilliance   1.50
 phong albedo 0.05
 phong_size 5
 specular 0.5
 roughness 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
#declare PositiveBump=
normal {
bump_map {
 png "spaceballoon2bumpmap" map_type 0 interpolate 2
bump_size 0.1
 translate -0.5
 scale MyRadius*2
#declare NegativeBump=
normal {
bump_map {
bump_size 0.1
 translate -0.5
 scale -MyRadius*2
 pigment
  image_map { png "spaceballoon2bumpmap" gamma 1
    map_type 0 interpolate 2 once transmit all 0.5}
  translate -0.5
  scale MyRadius*2
 normal { gradient y
 normal_map {
   [0.5 PositiveBump]
   [0.5 NegativeBump]
 } // end normal_map
 scale <1,MyRadius*2,1>
} // end normal
 pigment { color rgb < 0.7686275, 0.7607843, 0.7333333 > transmit 0.5 }
 normal { gradient y
 normal_map {
   [0.5 PositiveBump]
   [0.5 NegativeBump]
   } // end normal_map
} // end normal
//Launcher Radius: 10 m
 95.0, 105.0
 sphere { < 0.0, 0.0, 0.0 >, MyRadius }
 cylinder { < 0.0, 0.0, 0.0 >, < 0.0, MyRadius+0.001, 0.0 >, MyRadius+0.001 }
 object
  scale 0.99999
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 >, < 0.0, (MyRadius+0.001), 0.0 >, 3.5
 union
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 >, < 0.0, MyTop, 0.0 >, 3.5 }
  box { < MyLength, -MyHeight, -0.1 >, < -MyLength, MyTop, 0.1 >
rotate <0.0, 000.0, 0.0 > }
rotate <0.0, 045.0, 0.0 > }
rotate <0.0, 090.0, 0.0 > }
rotate <0.0, 135.0, 0.0 > }
rotate <0.0, 180.0, 0.0 > }
rotate <0.0, 225.0, 0.0 > }
rotate <0.0, 270.0, 0.0 > }
rotate <0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 >,
< 0.0, MyTop+0.001, 0.0 >, 3.3 }
 union
  cylinder { < 0.0, 0.0,  2.5 >, < 10, 0.0,  2.5 >, 0.20 }
  cylinder { < 0.0, 0.0, -2.5 >, < 10, 0.0, -2.5 >, 0.20 }
 union
  sphere { < 10.0, 0.0, 2.5 >, 0.35 }
  sphere { < 10.0, 0.0, -2.5 >, 0.35 }
  finish { emission rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.25, 0.0, 2.5 >,
   rgb 1//< 0.7, 0.0, 0.0 > // *10.0
   fade_distance 15.0
   fade_power 2
  light_source
   < 10.25, 0.0, -2.5 >,
   rgb 1//< 0.7, 0.0, 0.0 > // *1.0
   fade_distance 15.0
   fade_power 2
rotate < 0.0, 000.0, 0.0 > }
rotate < 0.0, 045.0, 0.0 > }
rotate < 0.0, 090.0, 0.0 > }
rotate < 0.0, 135.0, 0.0 > }
rotate < 0.0, 180.0, 0.0 > }
rotate < 0.0, 225.0, 0.0 > }
rotate < 0.0, 270.0, 0.0 > }
rotate < 0.0, 315.0, 0.0 > }
union
 object { Launcher }
// object { PositionLights }
Download 'spaceballoon2bumpmap.png' (3960 KB)
Preview of image 'spaceballoon2bumpmap.png'
Date: 24 Jul 2017 03:50:00
Message: <web.5975a1d69f453b979c5d6c810@news.povray.org>
"omniverse" <omn### [at] charternet> wrote:
>  normal { gradient y
>  normal_map {
>    [0.5 PositiveBump]
>    [0.5 NegativeBump]
>  } // end normal_map
> } // end normal
Mistakes... And wouldn't surprise me if it's still wrong somehow. I get confused
easily.  ;)
Replace both normal statements for outer and inner textures with this:
 normal { gradient y
 normal_map { /* 0.175 equates to 105/2 or balloon top (torus half vertical
scale) height from 0 */
   [0.175 PositiveBump]
   [0.175 NegativeBump]
 } // end normal_map
 scale <1,1.5*MyRadius,1> // rescale only y to fit whole balloon
And maybe it will be right. I neglected to see the 1.5 times rescale later on
for the balloon object.
And that flattened torus top (scale <1,0.5,1>) was simply being overlooked
because I was only thinking in terms of the gradient y
going upward and downward from 0, or starting at the max width part of balloon,
and not about actual distances for the gradient.
BTW, the gamma 1 for image file was arbitrarily chosen to brighten it for the
sake of seeing the bump map. You may have also noticed I changed the original
light source from 10 times to 1.5 times.
Date: 24 Jul 2017 19:38:16
Message: <597684e8@news.povray.org>
On 24.07.2017 03:46, omniverse wrote:
> normal_map {
>    [0.5 PositiveBump]
>    [0.5 NegativeBump]
>  } // end normal_map
Hi. Now I am irritated, I admit. :-)
Did you see the bump images I added to the GENERAL group (same topic there)
However, someone else mentioned I should size down the bump image and
increase the contrast between bright and dark areas, and also to make it
16bit. I now did all this, still no success.
Please have a look to the attached bump image, this might help you to
know more about my problem and errors I do. Lots of thanks for your help!
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (314 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Date: 24 Jul 2017 19:41:23
Message: <597685a3@news.povray.org>
Thanks a lot for your assistance, so far. But I admit, I am now irritated.
Did you see the bump image I posted inside the other group (GENERAL)
with the same topic? Someone there told me to reduce the image size,
make it 16bit, and increase the contrast between dark and bright areas
there. I did that all. Still - no success.
I attached the new bump image, please have a look. It should give you a
better understanding of what I want to achieve (and maybe what I am
doing wrong).
Sven
http://www.avg.com
Date: 24 Jul 2017 19:47:53
Message: <59768729$1@news.povray.org>
Another problem: The same thread exists inside the GENERAL section. I
posted here at first before making up my mind that it might be a GENERAL
topic. Now we have two identical threads. I think, we all should just
use the GENERAL thread there, not this one.
http://www.avg.com
Date: 24 Jul 2017 20:30:01
Message: <web.597690689f453b979c5d6c810@news.povray.org>
From general group message:
> Here's the updated bump image. I reduced its size, made it 16bit, and
> increased the contrast between dark and bright areas. Still - no
> success.   :-(
> Another problem: The same thread exists inside the IMAGE section. I
> posted there at first before making up my mind that it might be a
> GENERAL topic. Now we have two identical threads. I think, we all should
> just use THIS thread here, inside GENERAL.
I was avoiding general group because of image uploads not being accepted there,
so I'm not sure how you were able to do that.
Showing the render here that I was able to make using *your updated* bump_map
file, along with the SDL I posted here before (including fixed normal
statements).
And I regret uploading my version of the bump_map in PNG while leaving the
resolution size large, made almost 4 MB download file. Sorry!
I did not use reflection and radiosity, and also removed the image_map to use
only color rgb 1 which allows seeing only the bumpiness without any other visual
effects other than light source shadowing.
If you could show your resulting render here, to compare with this, it might
help figure out why you can't get "success". Must be an answer anyhow.
Download 'test-bump_map-balloon.jpg' (34 KB)
Preview of image 'test-bump_map-balloon.jpg'
Date: 25 Jul 2017 00:28:50
Message: <5976c902$1@news.povray.org>
Am 25.07.2017 um 01:42 schrieb Sven Littkowski:
> My e-mail client seems to ignore if I try to stop an unfinished posting.
> Please ignore the above posting with the wrong contents.
Select the posting in question, then open the "Nachricht" menu (Alt-N),
and choose "Beitrag zurückziehen" (Alt-Z).
Date: 25 Jul 2017 00:34:05
Message: <5976ca3d$1@news.povray.org>
Am 25.07.2017 um 01:41 schrieb Sven Littkowski:
I hope you're just "confused" ("irritiert"), not "irritated" ("verärgert").
